Vivitek H9080FD
メーカーpdf
Hands-on with world's first LED DLP home theater projector, undercuts three-chip rivals | Home Cinema Choice
Vivitek shows world's first Full HD LED projector - whathifi.com
Vivitek
Vivitek H9080FD DLP Projector Specifications General Aspect Ratio 16:9 (Native) 4:3 Brightness (ANSI Lumens) 800 ANSI Lumens Contrast Ratio 100000:1 Display Type 0.95" DMD DLP Resolution (Native / Max) HD (1920 x 1080) Video Compatibility NTSC, NTSC 4.43, PAL (B, G, M, N), SECAM, HDTV (480i, 480p, 720p, 1080i, 1080p) Size Dimensions (WxHxD) 20.5in. x 8.8in. x 21.6in.
(52.07cm x 22.35cm x 54.86cm) Weight 36.0 lbs. (16.33 kg) Connectivity Inputs 2 x HDMI
1 x Component
1 x BNC
1 x VGA D-Sub 15pin
1 x S-Video
1 x Composite Control 1 x RS-232C
2 x Screen Trigger
1 x Wired Remote Jack Operation Power Supply 100 ~ 240 V / 50 ~ 60 Hz Power Consumption 175W (Normal)
1W (Standby) Audible Noise 25 dB Projection Lens Lamp Type LED Lamp Life 20000 hrs Lens Shift Vertical: +/- 120%
Horizontal: +/- 30% Projection Mode Front, Rear, Ceiling Projection Screen Size (Diagonal) 23in. ~ 300in. (58.42cm ~ 762cm) Throw Ratio 1.85 ~ 2.4:1 Optical Zoom 1.3:1 Other Menu Languages English, French, German, Spanish, Portuguese, Italian, Simplified Chinese, Traditional Chinese, Russian, Polish, Chile, Czech, Sweden, Denmark, Turkish, Hungary In The Box Items Power Cord
HDMI Cable
User Manual
Remote Control
Batteries
O πρωτος led full hd dlp projector,ειναι γεγονος.
:drummer:
メーカーpdf
Vivitek
1 x Component
1 x BNC
1 x VGA D-Sub 15pin
1 x S-Video
2 x Screen Trigger
HDMI Cable
User Manual
Remote Control
Batteries
:drummer:
