- 27 January 2011
- 50
Συγχωρέστε με αν το τοποθετώ στην λάθος κατηγορία, αλλά το κάνω για να εγείρω τις συγκρίσεις του εν λόγω μηχανήματος για το οποίο κατενθουσιάστηκα, με το πολυσυζητημένο Ultra. Παραθέτω ότι πληροφορίες από το επίσημο site της zotac. (copy paste):
ZOTAC ZBOX Intel Atom D525 1.8 GHz Dual-Core w/ Blu-ray All-in-One
DETAILS
Experience stunning high-definition Blu-ray 3D video playback in glorious 1080p with the ZOTAC® ZBOX Blu-ray 3D ID36 Plus powered by Next-Generation NVIDIA® ION™ technology with 512MB of DDR3 video memory. NVIDIA® PureVideo™ HD technology enables the ZOTAC® ZBOX Blu-ray 3D ID36 Plus to deliver immersive Blu-ray 3D video playback using the integrated slot-load Blu-ray drive with native 1080p 3D video output to let users experience movies the way directors intended. An Intel® Atom™ D525 joins the Next-Generation NVIDIA® ION™ graphics processor to form an energy-efficient duo able to deliver a premium computing experience with rich audio, video and web capabilities with the ZOTAC® ZBOX Blu-ray 3D ID36 Plus. Class-leading expansion capabilities equip the ZOTAC® ZBOX Blu-ray 3D ID36 Plus with room to accommodate one mini-PCI Express slot in addition to the standard two USB 3.0, USB 2.0 port, combo eSATA 3.0 Gb/s and USB 2.0 port, DVI, HDMI, S/PDIF optical outputs, 6-in-1 memory card reader and 802.11n WiFi – a 250GB hard drive and 2GB of DDR3 memory are included.
ADDITIONAL INFORMATION
Model ZBOX-ID36BR3D-PLUS-U
Chipset Intel® NM10 Express
Cooler Type Fan (Single Slot)
CPU Socket N/A (Integrated CPU)
Dimensions 7.36in x 11.02in x 1.5in - 187mm x 280mm x 40mm
Form Factor No
FSB 800 MHz
Memory Size 1 x 2GB Installed (up to 4GB)
Memory Slots 2 x 204-pin DDR3-800 SO-DIMM
Memory Type DDR3 800 SO-DIMM
Onboard Audio Analog Stereo, 8-channel via HDMI, Digital S/PDIF output
Onboard LAN 10/100/1000Mbps, WiFi 802.11n/g/b (300Mbps)
Onboard Video Next-Generation NVIDIA ION™ w/512MB DDR3
Package Contents 1 x ZOTAC ZBOX Blu-ray ID36 PLUS
1 x VESA mount
1 x DVI-to-VGA adapter
1 x AC adapter
1 x Power cord
1 x Warranty card
1 x User manual
1 x Driver CD
1 x Cyberlink PowerDVD w/Blu-ray 3D playback
PATA No
PCI No
PCI Express x1 No
PCI Express x16 No
Power Connector DC19V
RAID No
SATA 250GB 5400RPM HDD
USB 2 x USB 3.0 (1 back panel, 1 front panel) 1 x USB 2.0 (1 Combo eSATA / USB 2.0 back panel, 1 front panel)
Video Ports HDMI, Dual-link DVI
Weight No
Warranty 1-Year Standard
Είναι κάτι παραπάνω από πανέμορφο από πλευράς desing (το έχω ερωτευτεί). Έχει ενσωματωμένο bluray με δυνατότητα αναπαραγωγής 3D! Περνάει 7.1 HD ήχο από την HDMI του και έρχεται με 250GB HDD και 2GB DDR3 ram. Το βρήκα σε ελληνικό eshop μόλις 500Ε!! Τα συμπεράσματα δικά σας και τα σχόλιά σας να τα ακούσουμε...!!!
DETAILS
Form Factor No
FSB 800 MHz
1 x VESA mount
1 x AC adapter
1 x Power cord
1 x Warranty card
1 x User manual
1 x Driver CD
PATA No
PCI No
PCI Express x1 No
PCI Express x16 No
RAID No
Weight No
