Nikon D400
Greg61
Όπως δείχνουν τα πράγματα, μάλλον έφθασε ο καιρός για τη νέα ναυαρχίδα του DX της Nikon, τη Nikon D400
Απο το Nikon Rumors: http://nikonrumors.com/2012/06/13/some-fresh-nikon-d400-rumors.aspx/
Nikon D400 specs:
  • Sensor: 24.2 MP DX CMOS, 3.82µ pixel pitch (same as on the D3200)
  • Sensor Size: 23.2 x 15.4mm
  • Resolution: 6,016 × 4,000
  • Native ISO Sensitivity: 100-6,400
  • Boost Low ISO Sensitivity: 50
  • Boost High ISO Sensitivity: 12,800-25,600
  • Processor: EXPEED 3
  • Metering System: 3D Color Matrix Meter III with face recognition and a database of 30,000 images
  • Dust Reduction: Yes
  • Weather Sealing/Protection: Yes
  • Body Build: Full Magnesium Alloy
  • White Balance: New White Balance System
  • Shutter: Up to 1/8000 and 30 sec exposure
  • Shutter Durability: 200,000 cycles, self-diagnostic shutter
  • Camera Lag: 0.012 seconds
  • Storage: 1x CF slot and 1x SD slot
  • Viewfinder Coverage: 100%
  • Viewfinder Magnification: 0.94x Approx.
  • Speed: 8 FPS, 9 FPS with optional battery pack and Nikon D4 or alkaline batteries
  • Exposure Meter: 91,000 pixel RGB sensor
  • Built-in Flash: Yes, with Commander Mode, full CLS compatibility
  • Autofocus System: Advanced Multi-CAM 3500DX with 51 focus points and 15 cross-type sensors
  • AF Detection: Up to f/8 with 9 focus points (5 in the center, 2 on the left and right)
  • LCD Screen: 3.2 inch diagonal with 921,000 dots
  • Movie Modes: Full 1080p HD @ 30 fps max
  • Movie Exposure Control: Full
  • Movie Recording Limit: 30 minutes @ 30p, 20 minutes @ 24p
  • Movie Output: MOV, Compressed and Uncompressed
  • In-Camera HDR Capability: Yes
  • Two Live View Modes: One for photography and one for videography
  • Camera Editing: Lots of in-camera editing options with HDR capabilities
  • GPS: Not built-in, requires GP-1 GPS unit
  • Battery Type: EN-EL15
  • Battery Life: ~900 shots
  • USB Standard: 3.0
  • Weight: 800g (body only)
  • Price: $1,799 MSRP
_________________________________
Η πρώτη πληροφόρηση προέρχεται απο
http://mansurovs.com/nikon-d400-announcement-this-fall
αν ισχύει αυτό το f8.0 στο AF τότε θα κλάψουν μανούλες σε άλλα συστήματα....
αυτό σημαίνει οτι φοράς τηλεφακό 4.0 με τον TC 2.0 και έχεις ακόμα AF ή έχεις ένα φακό όπως ο SIGMA 500 4.5 και εχεις AF με το TC AF 1.7 . Δηλαδή έχεις 500Χ1,5 =750 Χ 1,7 δηλ. εστιακή απόσταση 1.275 !!!! με AF έστω ζορισμένο.... . ή άνετο AF Με το TC 1,4 κι εστιακή απόσταση 1050 !!!!! . και 8 καρέ με πλήρη εστίαση. Μμμμμμμ....
Άν ισχύσουν όλα τα παραπάνω, τότε μάλλον θα ισχύσει και το f8.0 στο AF, δεδομένου οτι το σύστημα λειτουργεί ήδη στην D4 και νομίζω και στην D800.
Και όντως Βλάση, έχεις δίκιο: Αυτό αποτελεί μεγαλύτερη επανάσταση απο τα 125.000 ISO... διότι πλέον με ένα ακριβό σώμα και οξείς φακούς της τάξης του 18-200 ή του νέου 18-300, θα μπορούμε ίσως να έχουμε απογευματονυχτερινές λήψεις που, μέχρι τώρα, χρειαζόμασταν φακούς 2.8 για να τις πάρουμε.
Ειδικά άν το ISO 6400 που αναφέρεται, θα μπορεί να είναι χρησιμοποιήσιμο (βλ D3200) ταυτόχρονα με τη δυνατότητα εστίασης στο f/8.0, τότε μάλλον αυτή η μηχανή θα βρεθεί να καλύπτει όλα όσα εγώ θα ήθελα μέχρι σήμερα.
Ίδωμεν...
Άλλως, πάω για έναν 24/1.4 κι αλλάζω σώμα με την έλευση του επόμενου μοντέλου.
Πάντως, το μπάτζετ για φέτος έχει 2.500 με 3.000 ευρώ για ξόδεμα σε φωτογραφικά. Διαφορετικά... έχει "παντόφλα"!
[off topic]
Με την ευκαιρία, η πλατφόρμα που άλλαξε, μας τα έκανε σκ.... !
Αναζητούσα κάποτε κάτι και το εύρισκα.
Πατούσα νέα μηνύματα στην κατηγορία και μου τα εμφάνιζε. Τώρα πατώ νέα μηνύματα και μου εμφανίζει όλα τα άσχετα που δέν μ' ενδιαφέρει να τα δώ εδώ.
Έψαχνα προηγουμένως το "Ναί αγάπη μου ή... παντόφλα!" για να το λινκάρω στο παρόν, αλλά... πάπαλα! Μου έβγαλε 17 σελίδες άχρηστα για μένα μηνύματα.
Αυτός είναι ο βασικότερος απο τους λόγους που πλέον, συγκαταλέγομαι μάλλον στους "κομήτες" αυτού του φόρουμ... και βεβαίως, ίσως αυτό να μήν ενδιαφέρει και κανέναν!
[/off topic]
[off topic]
[/off topic]
[επίσης off topic]καμιά φορά είναι πιο εύκολο να βρεις κάτι από το google...
tip αναζήτησης: "φράση" site:avclub.gr
[/off topic]
.................αρκετά ακριβή για τις μέρες που ζούμε, δεν νομίζετε?
Σίμο δεν είναι μια συνηθισμένη κάμερα... είναι κάμερα ειδικά φτιαγμένη για όσους επιθυμούν να χρησιμοποιούν τηλεφακούς ή υπερτηλεφακούς και κυρίως αυτούς που χρησιμοποιούν και tcs. Αλλιώς όλες οι κάμερες έχουν AF που λειτουργούν με f5.6 ή έστω 6.3 άρα καλύπτουν όλους τους φακούς AF. Για σπορ υπάρχει η d4 αλλά για πολλούς πέφτει "κοντή". Όμως μια τέτοια κάμερα σαν την d400 θα δώσει τη δυνατότητα σε αυτούς που χρειάζονται πολύ μακρείς φακούς να μπορέσουν να δουλέψουν πολύ καλύτερα σε σχέση με το παρελθόν. Π.χ. μπορεί εγώ να μη χρειάζομαι το lighting fast AF της D4 αλλά να χρειάζομαι να γεμίσω το θέμα από πολύ μεγάλη απόσταση. Π.χ. ένα βυζί ή ένα πορτρέτο σε απόσταση 80 μ. από μένα κάτι που δεν γίνεται ακόμα και με την D4 και τον 600. Ή μια αρκούδα στν απέναντι λόφο. Μου έτυχε φέτος τον προηγούμενο μήνα και με τον 80-200 πάνω σε ff πήρα μια φωτο με διαστάσεις 750Χ500 πίξελς. Αστείο δεν είναι; Ή πουλιά...
Για όλους τους άλλους που χρειάζονται μια μηχανή στα όρια της επαγγελματικής, η d7000 είναι μια χαρά μηχανή.
Α, υπάρχει κι ακόμα ένας λόγος.... η CANON 7D είναι ΠΟΛΥ ΚΑΛΗ ΜΗΧΑΝΗ!!!!
Απάντηση: Re: Nikon D400
Άν θυμηθείς πόσο κόστιζε -και κοστίζει ακόμη- η D3x με τα 24ΜΡ και της αυτής κατασκευαστικής φιλοσοφίας σώμα... τότε μάλλον είναι πολύ φθηνή για τα ΜΡ αυτά πλέον.
Το άν κάποιος μπορεί να την αγοράσει και σήμερα τόσο εύκολα όσο άλλοτε... είναι ένα διαφορετικό ερώτημα.
Γρηγορη σκεψου και τον νεο 28mm/f1.8G. Oι πρωτες αναφορες μιλουν για εναν πολυ καλο φακο, οξυς ανοιχτος και γρηγορος στην εστιαση και μαλιστα 'φθηνος'!! (600 λιανικη).
Παρεα με την φημολογουμενη D600 θα κανεις ενα καλο σετακι και μαλιστα σε λογικη τιμη
Ναι ο φακός φαίνεται πολύ καλός, στο fredmiranda έχουν ανέβει αρκετές φωτό.
Δεν σας εχω μιλισει (φωτογραφικα) για τις παραλιες της Σλοβακιας μου φαινεται... :flipout:
Ασε που ο racer, μονο λογια ειναι... απο φωτο... κατι χωραφια απο ψηλα μας εβαλε και ειναι ηδη πολιτης ποσες μερες τωρα... αν ειναι να παρει την 400ρα για τετοια χρηση, ας κατσει με την... κοντή (την 700)... :flipout:
:grinning-smiley-043
Εγώ πάντως θα κάνω τον χαζό αν τα θέματα παρουσιάζουν "καλλιτεχνικό ενδιαφέρον" :jester:
ΙΙΙΕΕΕΕΕΠΠΠΠ !!!!!
Ξεφύγαμε απ' το θέμα! :slapface: :argue:
Και... για να το δούμε αλλοιώς, το θέμα αυτό μάλλον θα αποκτήσει αρκετά πόστς λόγω του ενδιαφέροντος που θα εκδηλωθεί για τη D400.
Άς μή φέρνουμε λοιπόν σε δύσκολη θέση ΦΙΛΟΥΣ ΜΑΣ, που θα πρέπει να σβήσουν μηνύματά μας.
Λεωνίδα, ΔΕΝ θα πάω για FF. Για τους γνωστούς δικούς μου λόγους που έχουν αναφερθεί εκτενώς παλαιότερα, σε άλλα νήματα εδώ. Ταξιδιωτική - αναμνηστική φωτογραφία κάνω στο 90% των κλίκς, οπότε το μικρό σώμα με το χτίσιμο και όλες τις δυνατότητες των μεγάλων (πλήν FF και υψηλών ISO) , φάνηκε στην πράξη οτι είναι αυτά που μου χρειάζονται όσο ακόμα φεύγω πολυήμερα ταξίδια με τη μοτοσυκλέτα. Αργότερα που θα μεγαλώσω :7SFGSFG: και θα πηγαίνω με "τουτού", :flipout: ...εεε τότε θα υπάρχει και χώρος για σύστημα FF.
Αυτό για το οποίο "ξερογλύφομαι", είναι κατ' αρχήν το πακετάκι D400 + 18-300 VRII. Όπως έγραψα και παραπάνω, εφόσον φανεί οτι τα αρχεία της D400 στα 6400 ISO είναι αξιοποιήσιμα και αντίστοιχα μ' αυτά της D300 στα 1600 ISO, ικανοποιείται ένα μεγάλο μέρος των απαιτήσεών μου που, η πράξη απέδειξε οτι μου έλειπαν. Άν επίσης φανεί οτι η ικανότητα εστίασης της D400 με f/8 είναι αντίστοιχη αυτής που έχω τώρα με f/4 και f/5.6, τότε θα διερευνήσω επι πλέον τη δυνατότητα χρήσης ενός TC X2 με το παραπάνω πακέτο.
Δέν χρειάζομαι κάτι παραπάνω Λεωνίδα. Και πέραν αυτών, το πακετάκι αυτό είναι μέσα στο όριο των 3.000 Ε που έθεσα, ή άντε να ξεφύγουμε και καναδυό κατοστάρικα παραπάνω άν προστεθεί και το TC.
Και για να μήν ξεχνιόμαστε, ένα μόλις χρόνο πρίν απο τώρα που μιλάμε, για να έχεις λήψη 24ΜΡ στα 450mm χρειαζόσουν εξοπλισμό αρκετών δεκάδων χιλιάδων ευρώ. Σήμερα, μ' αυτά τα 3 χιλιάρικα, δέν αγοράζεις ούτε τη D3x σκέτη, άν μιλήσουμε για αντίστοιχες δυνατότητες σε FF. Με αυτά τα (μόλις) τρία χιλιάρικα όμως, μπορούμε πλέον να έχουμε τις δυνατότητες αυτές σε DX και μέ φθηνότερους φακούς, ελέω δυνατότητας εστίασης και με f/8.
Όσον αφορά στον 24mm/1.4: Αποτελεί εναλλακτικό στόχο και θα αγορασθεί τώρα, μόνο σε περίπτωση μή αγοράς του νέου σώματος, προκειμένου να μου δώσει αυτά τα 2 στόπ που μου λείπουν σε τουριστικές - αναμνηστικές νυχτερινές σήμερα. Άλλως, ο 24-70/2.8 πάνω στη D400 και με ωφέλιμο ISO στα 6400, νομίζω οτι θα μου κάνει μιά χαρά τη δουλειά μου.
Αυτά είναι τα πλάνα εν γένει. Και δέν βιάζομαι. Άς βγεί πρώτα η μηχανή, να δούμε "τί πουλιά πιάνει" απ' όσα φημολογούνται και... το βλέπουμε στην πορεία.
New wave of Nikon announcements coming in August/September, D400 a possibility
Φρέσκα νέα μου ήρθαν μόλις πρίν λίγο με το rss.
Άντε να δούμε...
Τα περισυνά Nikon D400 specs που ελπίζω οτι θα αλλάξουν προς το καλύτερο:
Processor: EXPEED 3
Dust Reduction: Yes
USB Standard: 3.0
Price: $1,799 MSRP
Μαλιστα, ειναι γεγονος οτι κατι 'ψηνεται'..
Δειχνει να ειναι η αναμενωμενη αλλα η μονη παρατηρηση που εχω να κανω ειναι οτι -δυστυχως- με τις μεχρι τωρα φημες δειχνει η Νικον να εχει κολλησει στο Multi-CAM 3500DX επταετιας πλεον το οποιο εχει ξεπεραστει απο το αντιστοιχο κορυφαιο της canon.
Ελπιζω σε κανενα μηνα τα νεα να ειναι πολυ καλυτερα και η ΝΙΚΟΝ να μας(με) εκπληξει ευχαριστα....
