http://pioneerfaq.info/english/dv490.php?player=DV-490V&question=Firmwares
Håkan V5.0
Based on YDB6C18A
Firmware is untested, please report bugs!
Håkan V5.0
Based on YDB6C18A
- Fixed bug with .SRT and .IDX/SUB Subtitles timing
- The pointer stays as it was in File browser and is not reseted any more
- Play Mode with MP3 activated!
- Multiregional when Enter is pushed until the player turns off.
- Original region setting restorde when Clear is pushed until player turns off.
- Show all caracters in filename, foldername and when Display button is pushed instead of "_"*
- Bigger font for Subtitles in MPEG4
- Support for 42 chars in File Browser (CP1252*);
- White MPEG4 Subtitles outlined with black;
- Removed grey background in MPEG4 Subtitles;
- New File Browser image to support longer file names;
- JPEG Preview disabled;
- Shuffle function for MP3 under "Surround" button. For V.Surround hold buton longer!
- Fonts used for subtitles in DivX made by MTZ
- Replaced Screensaver
- Dont play new file on FF or FR, its hard to explain, just play some file, press FF key move selection bar to other file, press "play" or "enter" and check results
- Filbrowser names centerd
- A new font for file browser
- Changed subtitle window.
- Dimmer function under 0 key. Hold longer to obtain: On, ½-light and Off.
- White subtitles with black outline and transparent background
- Bigger font for CP1252 as default.
- Supports Greek now in subtitles for DivX/Xvid
- Display extensions in file browser
- Pan & Scan enabled for all DVDs
- Disabled UOPs (User Operations Prohibitet), but only partially
[*] Based on new original firmware, YDB6C18A
[*] New icons made by Dinderi
