δεν νομίζω ότι χρειάζεται να πούμε πολλά λόγια για τον γνωστο σε ολους Rotel RMB-1075 και την μουσικοτητα του...!!! ΣΕ ΑΡΙΣΤΗ ΛΕΙΤΟΥΡΓΙΚΗ ΚΑΙ ΕΜΦΑΝΙΣΙΑΚΗ ΚΑΤΑΣΤΑΣΗ!!....μαζι δίνονται και 5 Ultimax Professional Audio hi-end RCA Interconnection Cable
Τιμη 800 ευρω...!!!
Features
Τιμη 800 ευρω...!!!
Features
THX-Ultra certification. Large 1,500 VA Toroidal transformer. Eight 10,000 μF British-made Slit Foil capacitors. 20 high-current output devices, 4 per channel. Gold plated RCA and DB-25 input connectors. Separate 12 volt βtrigger β input and output jacks. Specifications Frequency Response: 15Hz - 100kHz +0.5dB, -3dB DIN Power Output (1 kHz, 1%): 5x200 watts per channel at 4 ohms Five-Channels rated at 200 Watts per channel at 4 ohms Total Harmonic Distortion (20 Hz - 20 kHz, 8 ohms): 0.03% maximum Damping Factor (20 - 20,000 Hz, 8 ohms): 180 Signal to Noise Ratio (IHF A network): 116dB Input Impedance/Sensitivity: 1.0 V / 33 kOhms Power Requirements: 230 Volts, 50 Hz Power Consumption: 800 Watts |
