USB-C 2.1 Coming – 240W Power Delivery, USB4 and DisplayPort 2.0 | CineD
The upcoming USB-C 2.1 standard supports USB Power Delivery Extended Power Range (EPR) that can charge your devices up to 240W.
USB-C 2.1 – What’s new?
So what’s new with USB-C 2.1 compared to the current version? Well, in terms of transfer speeds, you won’t get any major improvement.The main changes are around charging capabilities. With USB-C, you have several charging modes available, including 5V/1.5A that is used to charge a smartphone at 7.5W, as well as a 5V/3A mode to charge it at 15W.
In short, with USB-C Power Delivery, you can currently charge any device up to 20V and 5A. If you do the maths, this is why you can energize a 100W laptop with USB-C PD.
However, some very powerful laptops require more than 100W to be charged. This is precisely what USB-C 2.1 will solve, with a maximum 48V/5A charging capability, which means up to 240W. To ensure all your devices will be compatible with this new high output standard, there will be a new norm called USB Power Delivery Extended Power Range (EPR).
To avoid problems and make consumers’ lives easier, the USB-IF mentions that manufacturers will have to put a specific “EPR” label on their cables/chargers for easy identification.
USB4 and Alternative Mode 2.0
USB-C 2.1 also wants to further continue implementing USB4 and DisplayPort 2.0 connectivity with Alternative Mode 2.0.DisplayPort 2.0 is “embedded” inside USB4, and it can support video stream up to 16K (15 360 x 8 460) at 10bits/60Hz/30fps as well as 8K (7 680 x 4 320) at 10bits/120Hz/60fps which is massive. Indeed, DisplayPort 2.0 has a maximum bandwidth of up to 77.4 Gbps and is also supported by Thunderbolt devices.
We should start seeing USB-C 2.1 devices by the end of this year or early next year, opening new possibilities for manufacturers.
