- 11 June 2008
- 2,487
Η "αξιόπιστη" Xtreamer φυσικά δεν μπορούσε να μείνει έξω από το χώρο των Android Media Players...
έχουμε και λέμε...
Xtreamer Multi Console
http://www.xtreamer.net/MultiConsole/specs.html
στα 129 λένε χωρίς VAT και λοιπούς φόρους...
Chipset:
Processor: RK 3818 Quad-Core Cortex A9 Processor (1.6GHz)
GPU: Quad-Core Mali 400
Memory:
Memory: 2GB DDR3
Internal Storage: 16GB NAND Flash
OS:
Android™ Jelly Bean 4.2.2
Size:
Weight: 210 grams including WIFI antenna
Size: 98 x 98 x23mm
Wireless Connectivity:
802.11 b/g/n Dual-Band Wi-Fi (2.4GHz / 5.0GHz)
AirPlay, Miracast and DLNA support
Bluetooth 4.0
Video Output:
HDMI™ 1.4a, Full HD 1080p
Audio Output:
HDMI™ 1.4a
Power:
DC 5V, 2A adapter included (CE, FCC, CCC certified)
Supported Video Format:
AVI/RM/RMVB/MKV/WMV/MOV/MP4/WEBM/DAT(VCD format)
VOB(DVD format)/MPEG/MPG/FLV/ASF/TS/TP/3GP…etc
Sound:
Supported Audio Format: MP3/WMA/WMV/APE/OGG/FLAC/AAC…etc
DTS upto 5.1 CH
DTSHD & Dolby Digital 7CH not supported
Peripheral Interface:
RJ-45 Ethernet jack (10/100Mbps), SD/MMC card reader (SD 3.0, MMC V4.41)
USB 2.0 HOST port x 2
Multilingual support:
Google JellyBean supported languages
System optimization:
Airplay & DLNA by Airpin
Busybox
Clockworkmod Recovery
Root Access
Init.d Scripting
CIFS mount
XBMC Plugins & Repo
OTA Update
Setup Wizard
Kids Mode
Tweaks:
Gameloft
nfs support with auto-mount on startup scripts
build.prop tweaks
patched libmedia.so for DTS
Patched Kernel
Camera:
Not included
we recommend Logitech Cams
Gamepad:
Not included we recommend MOGA Pro
AirMouse:
Included
Emulators:
Require user to install manually BIOS
Games Rom files not included
Voice Activated Interface:
Requires BT headset paired
not included.
Requirements:
Gmail account, Minimum WiFi or LAN may be required to activate
Xtreamer Multi-Console features/updates with online services.
Package Content:
Xtreamer Multi-Console (Dual WiFi 802.11n Antenna included)
HDMI 1.4 Cable
5V 2A Power Adapter
AirMouse (remote control) with built in rechargeable battery
USB Slave cable
Quick start guide
Πάλι καλά δεν υποσχέθηκαν 7.1 ήχο σε Android....
:2thumb22sup:
έχουμε και λέμε...
Chipset:
Memory:
Memory: 2GB DDR3
OS:
Size:
Size: 98 x 98 x23mm
Bluetooth 4.0
Video Output:
Audio Output:
HDMI™ 1.4a
Power:
Sound:
DTS upto 5.1 CH
Busybox
Root Access
Init.d Scripting
CIFS mount
XBMC Plugins & Repo
OTA Update
Setup Wizard
Kids Mode
Tweaks:
Gameloft
build.prop tweaks
Patched Kernel
Camera:
Not included
Gamepad:
AirMouse:
Included
Emulators:
not included.
Requirements:
Package Content:
HDMI 1.4 Cable
5V 2A Power Adapter
USB Slave cable
Quick start guide
:2thumb22sup:
