Google Android™ 6.0 Marshmallow
airb
25 May 2008
15,115
Λιβαδειά
Contextual Assistance
  • Now on Tap: get assistance without having to leave what you’re doing—whether you’re in an app or on a website. Just touch and hold the home button.
  • Do more with your voice. Now you can have a dialogue with any of your apps that support the new voice interaction service. For example, if a user says “play some music on TuneIn,” TuneIn will respond by asking “What genre?”.
  • Direct Share: a fast and easy way to share to the right person in the right app.
Battery
  • Doze: when your device is at rest, Doze automatically puts it into a sleep state to increase your standby battery life.
  • App Standby: no more battery drain from seldom used apps; App Standby limits their impact on battery life so your charge lasts longer.
  • USB Type C support*: Quickly transfer power and data all through the same cable. Lightning fast charging gives you hours of power in just minutes.
Privacy & Security
  • On an Android Marshmallow device, apps designed for Android Marshmallow only ask for permission right when it’s needed. You can deny any permission and still continue to use the app.
  • Advanced controls to turn permissions on or off for all your installed apps.
  • Verified boot: when your Android device boots up, it will warn you if the firmware and Android operating system have been modified from the factory version.
  • Use fingerprint sensors* to unlock your device, make purchases in Google Play, authenticate transactions in apps, and pay in stores.
Android Runtime (“ART”)
  • Improved application performance and lower memory overhead for faster multi-tasking.
Productivity
  • Bluetooth™ stylus support*, including pressure sensitivity and modifier keys.
  • Improved typesetting and text rendering performance.
  • Smarter text selection, built-in undo/redo, and text actions closer to your fingers.
  • Text selection actions such as a new Translate option that lets you translate text from one language to another right on the spot. (Note: requires Google Translate app installed)
  • Save paper with duplex printing support.
System usability improvements
  • App links: enables installed apps to automatically handle their web URLs so you can jump right into the app, rather than the mobile web site, as appropriate.
  • Easily toggle and configure Do Not Disturb from quick settings.
  • If someone calls you twice within 15 minutes, you can choose to allow the call to ring through while Do Not Disturb is enabled.
  • Use automatic rules to enable Do Not Disturb for as many custom time blocks as you like or around events on your calendar.
  • Simplified volume controls allow you to manage notification, music, and alarm volumes easily from anywhere with the touch of your volume keys.
  • Streamlined Settings let you manage an app’s settings all in one place, from battery and memory usage, to notifications and permissions controls.
  • Google Now Launcher app list refreshed with search, fast alphabetic scrolling, and predictive App Suggestions.
Connectivity
  • More power efficient Bluetooth Low Energy (“BLE”) scanning for nearby beacons and your accessories.
  • Hotspot 2.0: Connect to compatible Wi-Fi networks seamlessly and securely.
  • Bluetooth SAP: Make calls from your carphone using your phone’s SIM.
  • Portable Wi-Fi hotspot now supports 5GHz frequency bands.
Expandable storage
  • Flex Storage: makes using SD cards or external storage devices as encrypted expanded storage for your apps and games on Android Marshmallow a whole lot easier.
Device setup and migration
  • Easily transfer your accounts, apps and data to a new device.
  • During setup, you can add an additional personal or corporate email account (e.g., IMAP)
  • Auto backup for Apps: seamless app data backup and restore.
  • Backup/restore of additional system settings such as your Sync settings, preferred apps, Do Not Disturb settings, Accessibility settings and enabled IMEs.
Media
  • MIDI support: create, consume, and perform music using your Android device with USB MIDI devices, MIDI over BLE, and software-based MIDI devices.
Internationalization
  • Android is now available in 74+ languages with 6 new additions: Azerbaijani, Gujarati, Kazakh, Albanian, Urdu, and Uzbek.
Android for Work
  • When receiving calls or viewing past messages, you can now see the full work contact details even if you’re not logged into your work profile.
  • Work status notification: A status bar briefcase icon now appears when you’re using an app from the work profile and if the device is unlocked directly to an app in the work profile, an alert is displayed notifying the user.
  • VPN apps are now visible in Settings > More > VPN. Additionally, the notifications that VPNs use are now specific to whether that VPN is configured for a work profile or the entire device.
airb
25 May 2008
15,115
Λιβαδειά
Την επόμενη εβδομάδα η αναβάθμιση των Nexus
Η Google πραγματοποίησε σήμερα το μεγάλο event όπου μεταξύ άλλων ανακοίνωσε επίσημα τα πολυαναμενόμενα
Nexus 6P και Nexus 5X. Οι νέες ναυαρχίδες έρχονται με Android 6.0 Marshmallow out of the box και ανακοίνωσε
ότι η αναβάθμιση για τα παλαιότερα Nexus θα ξεκινήσει την επόμενη εβδομάδα.​
Από την επόμενη εβδομάδα θα αναβαθμιστούν σε Android Marshmallow τα Nexus 5, Nexus 6, Nexus 7 και Nexus 9.
Όσον αφορά στα features, to Google Now on Tap μπορεί να απαντήσει σε ερωτήσεις και να αντιληφθεί την καθημερινή
γλώσσα, το Doze αυξάνει την διάρκεια ζωής της μπαταρίας, τα notifications είναι περισσότερο διακριτικά καθώς μπορείτε
να τα κάνετε swipe να κρυφτούν χωρίς να εξαφανιστούν.
[via] . [via]
(Sent from Galaxy S6)
airb
25 May 2008
15,115
Λιβαδειά
Από ότι φαίνεται τα Stagefright bugs (δείτε σχετικές αναρτήσεις εδώ και εδώ) θορύβησαν τόσο την
Google, την Samsung όσο και την LG που υποσχέθηκαν να προσφέρουν ενημερώσεις ασφαλείας σε
μηνιαία βάση. Η HTC πάντως πιστεύει ότι η μηνιαία αυτή δέσμευση, δεν είναι ρεαλιστική.​
Ο Πρόεδρος της HTC America, Jason Mackenzie, χρησιμοποίησε τον λογαριασμό του στο Twitter για
να απαντήσει σε έναν developer που ρώτησε γιατί η εταιρεία του δεν ακολουθεί τις Google, Samsung
και LG στην διάθεση μηνιαίων ενημερώσεων ασφαλείας στους χρήστες της. “Θα κάνουμε ότι μπορούμε,
αλλά είναι μη ρεαλιστικό για τον καθένα να λέει ότι είναι εγγυημένο κάθε μήνα”.
Η απάντηση του Mackenzie έβαλε τόσο τον ίδιο όσο και την HTC στο “στόχαστρο” ορισμένων χρηστών
και δεν ήταν λίγες οι διαμαρτυρίες και τα καυστικά σχόλια, αλλά αξίζει να σημειώσουμε ότι οι πάροχοι
κινητής τηλεφωνίας που πρέπει να εγκρίνουν τις αναβαθμίσεις αποτελούν μερικές φορές εμπόδιο για
τους κατασκευαστές smartphones στην διανομή ενημερώσεων.
Ακριβώς για αυτόν τον λόγο ο Mackenzie επανήλθε στο Twitter για να διευκρινίσει ότι κάτι τέτοιο δεν
συμβαίνει με τις ξεκλείδωτες συσκευές. “Οι Nexus και οι ξεκλείδωτες συσκευές είναι διαφορετική ιστο-
- ρία. Αν ένα προϊόν απαιτεί έγκριση από τρίτους δεν είναι στον πλήρη έλεγχο μας” διευκρίνισε.
[via] . [via]
airb
25 May 2008
15,115
Λιβαδειά
Motorola ανακοίνωσε τις συσκευές που θα αναβαθμιστούν
Μετά την ανακοίνωση της νέας έκδοσης του Android, 6.0 Marshmallow, διάφοροι κατασκευαστές συσκευών με
Android ξεκίνησαν να δημοσιεύουν τις λίστες με τα smartphones που θα αναβαθμιστούν.​
Η Motorola ήταν από τους πρώτους κατασκευαστές που έσπευσαν να ανακοινώσουν την λίστα με τις συσκευές,
ωστόσο η εταιρεία παρέλειψε να αναφερθεί σε οτιδήποτε έχει σχέση με ημερομηνίες.
Έτσι, μετά τις 12 συσκευές που ανακοίνωσε η HTC, η Motorola ανακοίνωσε την δική της δεκάδα, η οποία
αποτελείται από τα μοντέλα:
  • 2015 Moto X Pure Edition (3rd gen)
  • 2015 Moto X Style (3rd gen)
  • 2015 Moto X Play
  • 2015 Moto G (3rd gen)
  • 2014 Moto X Pure Edition στις ΗΠΑ (2nd gen)
  • 2014 Moto X στην Λ. Αμερική, Ευρώπη και Ασία (2nd gen) (η αναβάθμιση για Κίνα, βρίσκεται ακόμα κάτω από εκτίμηση)
  • 2014 Moto G και Moto G με 4G LTE (2nd gen) (η αναβάθμιση για Κίνα, βρίσκεται ακόμα κάτω από εκτίμηση)
  • DROID Turbo
  • 2014 Moto MAXX
  • 2014 Moto Turbo
Σύμφωνα πάντως με διευκρίνιση που έκανε η εταιρεία μέσω του επίσημου λογαριασμού της στο Twitter, ορισμένες
αναβαθμίσεις θα εξαρτηθούν από τους παρόχους κινητής τηλεφωνίας, και ενδέχεται ορισμένα κινητά να μην αναβα-
-θμιστούν. Εντύπωση προκαλεί η απουσία του σχετικά νέου Moto E (2nd gen) από την λίστα, κάτι που σίγουρα θα
απογοητεύσει τους κατόχους της συσκευής.
[via] . [via]
maddoctor
29 October 2007
480
Κυκλοφορεί και μία πιο επεκταμένη λίστα για τα ποια κινητά θα πάρουν marshmellow, αλλά να δούμε στο τέλος...
airb
25 May 2008
15,115
Λιβαδειά
H Sony επιβεβαίωσε τις συσκευές που θα αναβαθμιστούν σε Android 6
Μετά από έντονη φημολογία, η Sony τελικά ανακοίνωσε τις συσκευές που θα αναβαθμιστούν στην τελευταία
έκδοση του λειτουργικού συστήματος της Google, Android 6.0 Marshmallow.​
Η Sony θα φροντίσει για την αναβάθμιση των σειρών Xperia Z2, Z3, Z4 και Z5, αλλά δυστυχώς αφήνει εκτός
λίστας συσκευές όπως τα Xperia Z1, Z1 Compact και Z Ultra, κάτι που είναι μάλλον άδικο αν κρίνουμε από το
ότι δεν υπάρχουν σημαντικές διαφορές στο SoC (Snapdragon 801 έναντι Snapdragon 800 στην περίπτωση
των Xperia Z2 και Z1 ή Z Ultra).
Η Ιαπωνική εταιρεία δεν έχει ανακοινώσει ακόμα τις ημερομηνίες διάθεσης των ενημερώσεων για κάθε
μοντέλο, ωστόσο λογικά δεν θα αργήσει να το κάνει.
Οι συσκευές που θα αναβαθμιστούν στην 6η έκδοση του Android είναι οι:
  • Xperia C4
  • Xperia C5 Ultra
  • Xperia M4 Aqua
  • Xperia M5
  • Xperia Z2
  • Xperia Z2 Tablet
  • Xperia Z3
  • Xperia Z3 Compact
  • Xperia Z3 Tablet Compact
  • Xperia Z3+
  • Xperia Z4 Tablet
  • Xperia Z5 Compact
  • Xperia Z5 Premium
  • Xperia Z5
[via] . [via]
(Sent from Nexus 6)
airb
25 May 2008
15,115
Λιβαδειά
Βαρέθηκα να περιμένω για το πότε θα έρθει και την πέρασα μόνος μου σήμερα το μεσημέρι στο Ν6!
Πολύ καλή είναι! Καλύτερη μπαταρία, μνήμη ραμ (1.9 free).
Αρκετές αλλαγές είδα και στις "ρυθμίσεις"
sfortis
Administration Team
3 August 2006
11,396
t3.large
και εμενα εχει ερθει στο N5, αλλα οι πρώτες εντυπώσεις οσον αφορά την απόδοση οχι και τοσο καλές...απο ενα εντελώς lag-free τηλέφωνο, τωρα πλεον υπαρχει έντονο lag σε πολλές περιπτώσεις.
θα δείξει στις επόμενες μέρες.
qwerty1gr
23 February 2007
3,762
Γηραιά Αλβιώνα
κανε ενα φορματ την cache και δες αν στρωσει.
Σ' εμενα ειναι οπως πριν σε ταχυτητα, αλλα βελτιωθηκε η διαχειρηση της μνημης (τα 2Gb του Ν5 ειναι πλεον οριακα). Εχω την εντυπωση πως η μπαταρια ειναι λιιιγο χειροτερη με την 6 σε σχεση με την 5.
sfortis
Administration Team
3 August 2006
11,396
t3.large
ναι ξεχασα να το γράψω, εκανα wipe την cache λιγες ωρες μετά και εχει στρώσει. Η μπάταρία μεχρι στιγμής ειναι στα ίδια επίπεδα με την 5, δηλαδή βγάζω περίπου ολη τη μέρα και το βράδυ ειμαι στο 20-30%.
airb
25 May 2008
15,115
Λιβαδειά
Samsung: Η λίστα των συσκευών που θα αναβαθμιστούν σε Android 6.0 Marshmallow
Διανύουμε την περίοδο, που όπως κάθε χρόνο, έτσι και φέτος η Google παρουσιάζει μια νέα έκδοση του Android, στη
προκειμένη περίπτωση την Android 6.0 Marshmallow και κάθε χρήστης ανυπομονεί αν και πότε η συσκευή του θα ανα-
-βαθμιστεί σε αυτήν. Η Samsung δεν είναι από τις εταιρείες οι οποίες δημοσιεύουν επίσημες λίστες των συσκευών που
θα αναβαθμιστούν, για αυτό ο διεθνής τύπος προσπαθεί να αποσπάσει κάποιες πληροφορίες εκ των έσω, όπως έγινε
και στην προκειμένη περίπτωση.​
Συγκεκριμένα έχουμε στη διάθεσή μας μια λίστα των συσκευών για τις οποίες η Samsung διεξάγει δοκιμές, προκειμένου
αυτές να αναβαθμιστούν στη νέα έκδοση του Android. Όπως ήταν ήδη αναμενόμενο, ο κατάλογος περιλαμβάνει κάποιες
flagships συσκευές από την προηγούμενη χρονιά, όπως τα Galaxy S5, Galaxy Note 4 και Galaxy Note 5. Στη λίστα ξε-
-χωρίζει και η παρουσία του Galaxy S5 Neo. Ωστόσο θα πρέπει να αναφερθεί ότι αν η συσκευή σας δεν αναφέρεται, δεν
σημαίνει απαραιτήτως ότι δεν θα λάβει την αναβάθμιση. Ο κατάλογος είναι πρώιμος και στη λίστα ίσως προστεθούν και
άλλες συσκευές μελλοντικά.
Υπενθυμίζουμε ότι η Android 5.0. Lollipop κατέφθασε σε πολλές συσκευές smartphones και tablets της Samsung,
κάτι τέτοιο αναμένεται να γίνει και με την Android 6.0.
[via] . [via]
DimAsi
25 July 2007
5,816
Αττικό βουνό
Αφού ήρθε και δω το 6.0 μπορώ να πω ότι η μπαταρία συνήλθε και δεν έχει καμία μα καμία σχέση με πριν .Πολύ καλύτερη η αυτονομία της .
tolias
5 March 2011
3,745
Απάντηση: Android Phone News
Ήρθε προχθές ΟΤΑ αναβάθμιση για το LG K10 μου, το ευρωπαϊκό μοντέλο Κ420Ν που έχω, γιατί υπάρχουν και άλλες εκδόσεις από άλλες αγορές. Παρεπιπτόντως ποτέ δεν κατάλαβα γιατί οι ευρωπαίοι είμαστε οι πιο ριγμένοι και έχουμε την πιο αδύναμη έκδοση. Πάντως στην Ελλάδα υπάρχουν και άλλες εκδόσεις, κυρίως η ρώσικη Κ430DS, που είναι αρκετά πιο πλούσια.
Η ρωσική έκδοση έρχεται κατευθείαν με android 6 Marshmallow, το ευρωπαικό ήταν με 5.1.1 Lollipop, προχθές ήρθε αναβάθμιση. Μέγεθος αναβάθμισης 773 MB, αν θυμάμαι καλά. Πολύ μεγάλη. Που σημαίνει ότι δεν είναι απλό συμπλήρωμα σε υπάρχον λογισμικό, αλλά μεταφορά σε Marshmallow.
Καλό είναι ότι σε ένα μεσαίο μοντέλο όπως είναι το LG K10 έρχεται αναβάθμιση σε νεότερη έκδοση android. Οι σημειώσεις του νέου λογισμικού λένε για αρκετές αλλαγές, κυρίως σε χειρισμό ειδοποιήσεων, χειρισμό και απενεργοποίηση αδειών σε εφαρμογές (κάτι που δεν είχα δει παλιότερα κατευθείαν σε λογισμικό, αν και εγώ είχα βρει ήδη κρυφό μενού για αυτό με την χρήση του Quick Shortcut Maker ήδη και στην Lollipop), μερικές αλλαγές σε εφαρμογές της LG, και κυρίως βελτίωση της κατανάλωσης μπαταρίας, κάτι που έχω διαβάσει και για άλλες συσκευές με Marshmallow. Αλλά επειδή ήμουν παθών στο παρελθόν, προτίμησα πρώτα να κάνω hard reset στην συσκευή για να γίνει καθαρή εγκατάσταση. Άδειασα μάλιστα και την κάρτα μνήμης πρώτα από κάθε αρχείο που είχε τοποθετήσει το τηλέφωνο. Οπότε χωρίς να βλέπω αρχικά κανένα πρόβλημα, δεν μπορώ όμως να συγκρίνω άμεσα τα δύο λογισμικά γιατί πρέπει πρώτα να ξαναστήσω το τηλέφωνο όπως ήταν πριν το reset για να συγκρίνω. Ένα πράγμα που είδα είναι ότι δεν δουλεύει το αγαπημένο μου SeePU που με βοήθαγε τόσα χρόνια. Πρέπει να ψάξω να βρω κάτι ανάλογο.
tolias
5 March 2011
3,745
Ένας χρόνος πέρασε από το τελευταίο μήνυμα του θέματος, έχει βγει ήδη η έκδοση android 7, αλλά η έκδοση 6 Marshmallow δεν θεωρείται ακόμα ξεπερασμένη. Ακόμα πωλούνται συσκευές με android 5, και πολλές συσκευές βγαίνουν με Marshmallow, ή έρχονται αναβαθμίσεις σε συσκευές που από android 5 τις αναβαθμίζουν σε android 6 Marshmallow.
Έτσι έγινε και με το δικό μου LG K10 που πριν λίγες μέρες ήρθε αναβάθμιση από android 5 σε 6.
Εμφανίστηκε λοιπόν στην συσκευή μου ένα μεγάλο bug που υπάρχει στην 6 Marshmallow.
Δεν είναι τόσο τραγικό, απλά μπορεί να δυσκολέψει κάποιον που δεν ξέρει πως να το παρακάμψει. Αν δεν ξέρει πως να το παρακάμψει, μπορεί να βρεθεί σε αδιέξοδο και να απενεργοποιηθούν κάποιες εφαρμογές, ή να μην μπορεί να ενεργοποιήσει κάποιες άλλες που θέλει να εγκαταστήσει.
Έτσι και εγώ, ήθελα να εγκαταστήσω το πρόσθετο Tesla Unread που δείχνει αριθμό αδιάβαστων κλήσεων και μηνυμάτων όταν χρησιμοποιείς τον Nova Launcher, και μετά ήθελα να εγκαταστήσω τον FX File Manager. Είναι εφαρμογές που για να λειτουργήσουν χρειάζονται να εγκρίνεις κάποιες έξτρα δυνατότητες, στην ουσία να ενεργοποιήσεις κάποιες άδειες. Δεν ζητάνε όλες οι εφαρμογές που εγκαθιστάς τέτοια έξτρα τροποποίηση, αλλά στις εφαρμογές που που σου ζητάνε να ενεργοποιήσεις κάτι, τότε εμφανίζεται το bug.
Το bug είναι ότι δεν επιτρέπεται να ενεργοποιήσεις κάτι, γιατί κάποια από τις υπάρχουσες εφαρμογές έχει την άδεια να εμφανίζει κάτι, για παράδειγμα ένα floating παράθυρο μέσα σε άλλη εφαρμογή, ή έχει την άδεια να αλλάξει τις ρυθμίσεις της οθόνης. Για παράδειγμα κάποια antivirus που βγάζουν ενημερωτικά παράθυρα ακόμα και μέσα σε άλλες εφαρμογές, ή κάποιες εφαρμογές που υπάρχουν για να "απαλύνουν" τα χρώματα της οθόνης. Αν υπάρχει τέτοια εφαρμογή, τότε καμία άλλη εφαρμογή που χρειάζεται έξτρα άδεια ή ενεργοποίηση δεν μπορεί να πάρει την έξτρα άδεια, δηλαδή δεν μπορεί να λειτουργήσει! Πρέπει πρώτα να απενεργοποιηθεί η άδεια της πρώτης εφαρμογής, αν και μετά μπορεί να ξαναεργοποιηθεί. Το πρόβλημα είναι ότι βγαίνει ένα παράθυρο που κάτι σου λέει για "επικάλυψη οθόνης" (screen overlay), κάτι να κάνεις, αλλά δεν σου εξηγεί τι, και αν δεν ξέρεις δεν βγάζεις άκρη.
Υπάρχουν άνθρωποι (όπως διαπίστωσα μετά από αρκετό γκουγκλάρισμα) που μετά την αναβάθμιση σε android 6 είδαν πχ ότι δεν μπορούν να ανεβάσουν φωτογραφίες στο Facebook, επειδή (όπως είδαν μετά) κάποιο antivirus ή κάποια εφαρμογή για να "απαλύνουν" το φως της οθόνης είχε προλάβει την άδεια, και πολλοί ακόμα δεν ξέρω αν κατάλαβαν τι πρέπει να κάνουν.
Εγώ το διάβασα για αρκετά LG, το δικό μου Κ10, αλλά και G4, Nexus 5 (αν και εκεί από ότι ξέρω έχει αρχίσει να πηγαίνει η android 7), αλλά όπως λέει και το παρακάτω άρθρο αφορά και αρκετά Samsung, Motorola κτλ.
Η λύση είναι πανεύκολη, αλλά αν δεν την ξέρεις μπορείς να πελαγώσεις. Οπότε ας την ανεβάσω για όποιον τυχόν δει να εμφανίζεται το ίδιο πρόβλημα.
https://www.androidpit.com/how-to-fix-screen-overlay-detected-error
