Fuji XT-2 φωτογραφία
tiniakos
7 August 2007
16,146
Τήνος / Ελλάς
Μια εβδομάδα έμεινε για τον διάδοχο.
Σήμερα διέρρευσαν και τα χαρακτηριστικά.
Και έλεγα να μην πάρω μηχανή σύντομα.
Full Specs Χ-Τ2 Google translated
– 24.3MP CMOS sensor
– Image processing engine X Processor Pro
– Video 4K30fps. Full HD60fps
– Video of the bit rate is 100Mbps
– The maximum speed of the shutter is 1/8000 seconds. 1/32000 sec electronic shutter
– Synchro speed of the flash is 1/250 seconds
– AF 325 points can be selected intelligent hybrid phase difference AF
– The body is in a magnesium alloy, improve the durability of the dial. Dust and water specification
– EVF is 2.36 million dots. Refresh rate 100fps
– 3-way tilting 3 inches 1.62 million dot LCD monitor
– Dual SD card slot. UHS-II support
– AF-C custom settings
– ISO range is ISO200-12800 (RAW)
– Wi-Fi built-in. Remote shooting correspondence. Instax Share printer support
– 16 kinds of film simulation modes, including the ACROS
– That can customize the settings screen β€œMy Menu”
– Normal / boost mode switching
– 14bit RAW lossless compression. Camera RAW development
– Exposure compensation +/- 5EV
– 256-segment metering (multi-spot average, spot, center-weighted)
– Interval Shooting
– 13 kinds of creative filter
– The battery is NP-W126S. The number of possible shots 350 sheets
– 3.5mm microphone jack. 2.5mm remote terminal. USB3.0 terminal. Micro HDMI terminal
– You can use all of Fujinon X mount lens group
When the vertical position power booster grip use of the option, can use a plurality of battery at the same time, continuous shooting is speeding up, the shooting interval, shutter time lag, the image disappearance time is shortened. In addition, 4K of recording time is extended up to 30 minutes.
http://www.fujirumors.com/fujifilm-x-t2-full-specs-images-leaked/
Anetheron
9 August 2013
1,208
Re: Fuji XT-2
Αρκετές και ουσιώδεις βελτιώσεις, ειδικά στο video και στην εργονομία (iso dial-joystick)
Δε μου αρέσει που για το maximum πρέπει να τα σκάσεις για το grip. Θα πρέπει να είναι επιπέδου D500 το autofocus και την αναφέρω λόγω παρόμοιας τιμής και μεγέθους με το grip κοτσαρισμένο.
Επίσης χωρίς touchscreen (γιατί βρε fuji) και με το ίδιο OVF (αν και παραμένει κορυφαίο).
Όσον αφορά το βίντεο μεγάλη αναβάθμιση αλλά χωρίς σταθεροποίηση σε πολλούς φακούς (ακόμα και στον 16-55).
Τα δείγματα πολύ ωραία αλλά βλέποντας σύγκριση στο Dpreview με την Pentax Κ1 θεωρώ ότι κάποιος για στατικά, macro και landscapes πάει εκεί ασυζητητί με λίγα παραπάνω χρήματα.
Τέλος είναι και η X-T1 η οποία θα έρχεται σχεδόν στα μισά λεφτα με την κυκλοφορία της Χ-Τ2.
_tzo_
Banned
18 November 2007
11,985
Re: Fuji XT-2
Μου άρεσε πολύ η πρωτοποριακή διπλά σπαστή οθόνη, και σε portrait.
http://www.dpreview.com/news/2952778073/hands-on-review-fujifilm-x-t2-mirrorless-camera?slide=9
sokos
19 January 2007
2,316
Re: Fuji XT-2
Μου ήρθε και μένα email σήμερα διαθέσιμη στις 1300 λίρες.
Χάρηκα λέω, βρήκα την τέλεια κάμερα!
https://www.youtube.com/watch?v=xABrbD1xo8A&feature=youtu.be
Διαβάζω μετα οτι δεν έχει Touch screen και ξενέρωσα.
Κρίμα γιατί αυτά τα χρώματα της Fuji δεν τα έχει κανείς.
Μα είναι δυνατόν 2016 και σε Flagship μοντέλο να μήν βάζεις touch-screen?
Και καλά όσοι δεν ξέρουν, αλλά αυτός που έμαθε σε touch screen (ειδικά στο Focus) πως να κάνει τέτοιο πισωγύρισμα.
karamela
6 November 2013
10,576
Re: Fuji XT-2
Όπως τα λες αν θες στατικά, macro και landscapes πας σε Pentax k1 και αν θες sport φωτογράφιση Nikon D500.....
Συνολικά πάντως πολύ καλή αναβάθμιση της Xt1, αν είχε και touch οθόνη θα ήταν εξαιρετική λύση.....ουσιαστικά δεν έχω κάτι κακό να πω για αυτή την μηχανή, με την τιμή που έχει όμως δυστυχώς απευθύνεται σε πολύ λίγους....αρκετοί θα την σχολιάσουμε, λιγουρευτούμε, δούμε άλλα ελάχιστοι θα την αποκτήσουμε....
Υ.Γ. Θετικό το γεγονός ότι θα πέσει η τιμή της xt1 και ίσως πάρει με αναβαθμίσεις κάποια από τα καλούδια της xt2!!!
Anetheron
9 August 2013
1,208
Re: Fuji XT-2
Και η Xpro2 λογικά θα πάει βουτιά, αφού δεν υπάρχει πλέον λόγος αγοράς πλην ragefinder.
karamela
6 November 2013
10,576
Re: Fuji XT-2
Καλά η xpr2 είχε εξαρχής υπερβολική τιμή χωρίς ιδιαίτερο λόγο...η xt2 θεωρώ ότι δεν είναι υπερβολική η τιμή της απλά είναι κάπως τσιμπημένη, θα έπρεπε να είναι 200-300 ευρώ ποιο κάτω σαν αρχική τιμή...το θετικό με την xt2 είναι ότι θα συμπιεστούν οι τιμές στις άλλες μηχανές fuji....
alzazira69
17 June 2012
2,261
Re: Fuji XT-2
Νομίζω ότι έχει διαφορά στην ποιότητα κατασκευής.
kbouk
8 January 2010
22,235
ΠΕΙΡΑΙΑΣ
Απάντηση: Re: Fuji XT-2
νομίζω ότι εδώ έκανε διανα η Fuji , μεγαλη συρταρωτη μπαταρία όπως ειχε η παλιά Ε-1 μου και ξεχναγα να αλλάξω μπαταριες, ποιοτικα δεν βλέπω να υστερεί απο την Χ-pro2, εργονομική φαινεται να είναι και βελτιωμένη σε όλα τα σημεία που πόναγε (οκ λειπει η οθονη αφής...), ακόμη και στον τομέα του φλάς που υστερουσε το συστημα συντομα τον Σεπτέμβρη θα κυκλοφορήσει το EF-X500 με guide number 50m στα ISO 100 (supports high speed sync, includes a video lamp and covers a range of 24-105mm (or down to 20mm with the included wide panel). It'll be priced at $449)
Μάλλον σε άκουσαν και ετοιμάζουν αντικαταστάτη ...
http://www.fujirumors.com/fujifilm-patents-xf16-55mmf2-8-ois/
_tzo_
Banned
18 November 2007
11,985
Re: Απάντηση: Re: Fuji XT-2
Δύο πρόσθετες μπαταρίες παίρνει το γκριπ, συν την εσωτερική μπαταρία της μηχανής σύνολο τρεις μπαταρίες.
Anetheron
9 August 2013
1,208
Re: Fuji XT-2
Έπρεπε να τον είχαν βγάλει αρχικά έτσι αλλά κάλιο αργά παρά ποτέ. Με το grip θα έχει ικανοποιητικό balance στην X-T2 παρά το (λογικά) αυξημένο βάρος και μέγεθος.
22 June 2006
34,779
NEO HRAKLEIO
Re: Fuji XT-2
Ωραια και ακριβη.... καλοδεχουμενες οι αλλαγες της Fuji, καταλαβε επιτελους οτι μια συγχρονη υβριδικη μηχανη πρεπει να εχει και καλο βιντεο.
Skywriter55
11 January 2015
952
Re: Fuji XT-2
Είναι κοινό μυστικό ότι η τιμή θα πέσει αργά (μέσω προσφορών,cash back κλπ) ή γρήγορα (grey markets) .Οι περισσότεροι περίμεναν 200-300 ευρώ φθηνότερο το σώμα και 200-300 ακριβότερο το grip ,αλλά έγινε το αντίθετο .200 λίρες το grip αν το αγοράσεις μαζί με τη μηχανή,δηλαδή περίπου όσο είχε το παλιό! Οι fuji guys πάντα τραβάνε τα βίντεο τους με fuji ,αν είναι τραβηγμένο με x-t2,έχω μείνει λίγο...
https://www.youtube.com/watch?v=11C50vCC2s8
karamela
6 November 2013
10,576
Re: Fuji XT-2
Και η πρώτη em1 όταν είχε βγει από όσο θυμάμαι 1.500 ευρώ είχε αρχική τιμή, εδώ στο Ελλάδα ακόμα την πουλάνε πάνω από 1.000 ευρώ!!!...όσο περνάει ο καιρός όλο και ανεβαίνουν οι αρχικές τιμές των καινούριων High End μοντέλων των εταιριών....
