Ferguson Ariva T650i
Η υποστήριξη ελληνικών στις πληροφορίες προγράμματος (EPG) προστέθηκε στην έκδοση λογισμικού V1.01B4
Main Features
STB Type: DVB-T Receiver
Main Chipset: ALI M3801
Special Features
Encrypt: ASIC Type
TUNER Type: Silicon Tuner
SMPS Type: Separate SMPS
Mechanical
Dimension: W:17.0 cm,D:11 cm,H:3.5 cm
Net Weight: 0.6 kg
Main Chip Sets
CPU frequency: 594 MHz
Flash Memory: 1PC 62 Mbit / 8 MB
SDRAM Memory: 1PC 64X16 Mbit / 128 MB DDR3-1066
DVB-T tuner
Tuner Type: MAXLINER603
Frequency Range: 177.5~227.5 MHz;474~858 MHz;
Input Impedance: 75Ω
Active Ant Power: 5VDC @ 50mA MAX, Overload Protection
Input Level Range: 64QAM:-78.5dBm~-8.75dBm~16QAM:-84.1dBm~-8.75dBm;QPSK:-90.3dBm~- 8.75dBm
ANT Loop-Through: 51MHz~858MHz full Band loop through
TS Demux
Demultiplexer: MPEG2 ISO/IEC 13818-1
Input Bit Rate: Max 100Mbit/s
Video Decode
Video Decode: MPEG2 ISO/IEC 13818-2 MP@ML, H.264(MPEG4 part 10) main and high profile level 4.1/MPEG-2 MPEG2 ISO/IEC 13818-2 MP@ML, H.264(MPEG4 part 10) main and high profile level 4.1/MPEG-2
Aspect Ratio: 4:3, 16:9
Video Resolution: 1920×1080, 1280×720, 720×480
Audio Decode
Audio Decode: MPEG-1 layerI/II, MPEG-2 layer II, MPEG-2, MPEG-4 LC 2ch/5.1chMPEG-1 layerI/II , PCM downmix , IEC958 SPDIF , Dolby 5.1 channel , Dolby downmix 2 channel , Dolby Prologic2
Sampling Frequency: 32 kHz, 44.1 kHz, 48 kHz
AV Output
Video Bandwidth: SD:5.0 MHz (-3dB), HD:30 MHz (-3dB)
Video Impedance: 75Ω
Video Voltage Level: 1.0 Vp-p
Audio Freq. Range: 20 ~ 20 kHz
Audio Impedance: 600Ω
Audio Voltage Level: 2V rms(5.6Vp-p)
Environment
Input Voltage: AC 175~250V~50Hz/60Hz
Consumption: Max 10 W
Temperature: 0~40℃
Humidity: <95%
Special Features
Encrypt: ASIC Type
Mechanical
Net Weight: 0.6 kg
Main Chip Sets
DVB-T tuner
TS Demux
Video Decode
Audio Decode
AV Output
Environment
Temperature: 0~40℃
Humidity: <95%
O Ariva T650i είναι ο νέος δέκτης της Ferguson. Αυτή τη φορά προτιμήθηκε το τσιπ ALI M3801. Οι δυνατότητες του είναι οι βασικές παρόμοιων δεκτών με μία διαφορά: o δέκτης δέχεται WiFi stick για σύνδεση με το Δίκτυο! Η Ferguson έχει βάλει και το πανέμορφο OSD του 250Combo!
Ανυπομονώ να τον δω απο κοντά!
Ελληνική γλώσσα στο EPG: http://avclub.gr/forum/showthread.p...-T650i?p=1057065937&viewfull=1#post1057065937
Αναβάθμιση firmware 1.13B4: http://www.mediafire.com/download/9tj8kpwkr3ak2xr/T650i_V1.13B4_20160721.zip
