JVC DLA-X700R
Browser
10,575
[h=5]The JVC DLA-X700R Sets New Standards with 4K e-shift3[/h] The DLA-X700R combines JVC's exclusive 4K e-shift3 technology which accepts Native 4K 60P through the 4K enabled HDMI inputs and a class leading 120,000:1 Native Contrast Ratio to produce images that pop off the screen.
Like all JVC Procision Projectors, the DLA-X700R uses three DILA devices to produce a stable image with no flicker. In addition, the DLA-X700R is certified by THX and licensed by ISF, and has met or exceeded all of their high standards. For 2014, JVC added an Intelligent Lens Aperture which results in a Dynamic Contrast Ratio of 1,200,000:1.
[h=5]The Competitive Advantage[/h]
  • Improved 120,000:1 Native Contrast Ratio
  • New Intelligent Lens Aperture for Dynamic Contrast Ratio of 1,200,000:1
  • New 4K e-shift3 provides 3840x2160 projected image
  • New Native 4K HDMI inputs that accept
    • 3840x2160 at 24P, 25P, 30P and 60P
    • 4096x2160 at 24P
  • New Clear Black Processing improves local area contrast
  • New Upgraded Clear Motion Drive works in 2D, 3D and 4K
  • New Adobe sRGB provides expanded color space
    • Great for viewing still images on-screen
  • Improved Multi Pixel Control (MPC) with New Auto Mode
    • MPC improves 2K to 4K up-conversion
  • New 6th Generation 1920x1080 DILA devices
    • 40% smaller pixel gap and improved brightness and contrast ratio
  • THX Certification ensures precise reproduction of 2D AND 3D at home
  • ISF C3 Licensed—Qualified installers can calibrate the X700R to your room
  • Supports 3D content and display using Active Shutter 3D
    • Accepts Frame Sequential, Side-by-Side, and Top-Bottom
    • 3D Anamorphic Capable, 3D Crosstalk Cancellation
    • 2D to 3D Conversion System, 3D Parallax Adjustment
    • Optional RF Active Shutter 3D Glasses (PK-AG3G) and RF 3D Emitter (PK-EM2G)
  • New Smartphone App for operational control, image adjustment and more
  • Lens Memory with 10 user adjustable presets
  • Motorized Auto Lens Cover and Motorized 2X Zoom Lens (1.4:1 – 2.8:1)
  • 7-Axis Color Management System (R,G,B,C,M,Y,Orange)
  • Customized Gamma Control
  • 230 Watt NSH Lamp, 1300 Lumens
  • Inputs & Outputs
    • Dual 4K/60P HDMI Inputs with Deep Color and CEC
    • 3D Compatible (Blu-ray, Side-by-Side, Top-and-Bottom)
    • RS-232C
    • RJ45 LAN Connection
    • 12V Trigger
    • 3D Synchro
  • Ultra Quiet Operation (21db/Low Lamp)
  • 2 Year Warranty
http://procision.jvc.com/product.jsp?modelId=MODL029314&pathId=71&page=10
Babis K.
28,667
Αν και τα screenshots, το έχουμε πει χίλιες φορές,είναι πιο πολύ για την πλάκα μας, κάποια απ´αυτά, τα σκοτεινά, είναι λίγο ψαρωτικά. :beatnik2:
Browser
10,575
Αμα ειναι λιγο, καλα εισαι :ernaehrung004:
Babis K.
28,667
Δεν χρειάζεται να πάς σ´αυτόν, πάρε τον 500 (και κρατάς και τη βάρκα...:ernaehrung004:)
Ntinos P
26 June 2006
22,938
Απλα για ενημερωση ρωταω....
Εχω υποσχεθει στον εαυτο μου να αλλαξω προβολεα μολις γραψει αυτος που εχω πανω απο 2000 ωρες...
(δεν τις εχω φταζει ακομη απο τον Μαρτη του 2007....)
σορυ για το οφτοπικ....
spcav
18 August 2006
16,598
Βαλτον να παιζει τα βραδυα ρε παιδι (εδω αλλοι κι αλλοι επιστρατευουν γυναικοπαιδα για να δικαιολογησουν τις αναβαθμίσεις)
Στη χειρότερη, πουλα και το DP καλώδιο
:p
Ntinos P
26 June 2006
22,938
εχω παρει εναν benq 705 απο το (προ) περασμενο καλοκαιρι για την βεραντα....
Δεν εχω ιδεα που στο καλο τον εχω....
Browser
10,575
Απάντηση: Re: JVC DLA-X700R
Το σωστό θα ήταν να κάνεις bypass και να περιμένεις σε ένα χρόνο τους native 4K
Γιατι? Για να δει 4κ υλικο? Δε νομιζω. Το υλικο ειναι το θεμα με το 4κ , οχι τα μηχανηματα.
Και στο τελος θα μεινει με 2κ υλικο να βλεπει απο 4κ μηχανημα......
Εγω παντως, και μιλαω σοβαρα, το 4κ το εχω ξεχασει για ταινιες τουλαχιστον για αλλα 3 χρονια.
vadergr
17 August 2007
27,469
Μεταμορφωση
Re: Απάντηση: Re: JVC DLA-X700R
Από την στιγμή που βγαίνουν 4κ τηλεοράσεις, θα βγει σαφέστατα και υλικό.
Το αργότερο σε 2 χρονάκια θα έχουμε φλομώσει από 4κ μηχανάκια και υλικό .
vadergr
17 August 2007
27,469
Μεταμορφωση
http://www.highdefdigest.com/news/s...ng/Samsung_Predicts_4K_Blu-ray_for_2014/13546
Αρχιζω και το σκεφτομαι για καναν 9200 και βλεπουμε του χρονου για 4Κ....
Όλο με ζημιαρικα θες να μπλεκεις...
Δες τον BenQ w7500 που θα έχει εξαιρετικό 3d, καθώς και τον optoma 91 που θα βγει.
Έκτος αν φυσικά σε νοιάζει μόνο το απόλυτο νούμερο που θα γράψει στο on/off contrast.
spcav
18 August 2006
16,598
Μήπως να πάρω και κανά Dune;
Babis K.
28,667
Κατάλαβα...
Ρούλη, μ´αυτούς που έμπλεξες, ξεκίνησες για Victoria Secret και θα καταλήξεις με PRETTY bra.... -bye-
spcav
18 August 2006
16,598
lol @ Babs
Εμ, με αυτα που συμβαινουν ειναι λογικο να το σκεφτομαι σοβαρα.
Η JVC θα πρεπε να ειναι πιο προσεκτική - ειδικα φετος.
Από τη στιγμη που εχει έτοιμα 4Κ τσιπάκια (εξ ου και η βελτίωση στα 2Κ τσιπ) και αποφάσισε να μη βγάλει 4Κ μηχανήματα αλλα να μας ξεζουμίσει για άλλον έναν χρονο με το τυράκι της ίριδας, θα έπρεπε να προσέξει να τα κάνει όλα τέλεια.
Και μαλλον κατάφερε ακριβώς το αντίθετο. Το πιο προβληματικό launch νεου της μοντέλου ever.
Σε καθε περιπτωση, μιλαω για 'προσωρινη' λυση, ενος έτους (του χρονου θα παω στα 4Κ - αν και βεβαια την εχω την JVC, πλεον, ικανή το 1ο της 4Κ μοντέλο να μην εχει αυτοματη ιριδα....)
Χρηστο, νήμα για τον 9200 έχουμε; Δεν είδα κάτι. Δεν ανοιγεις ένα να έχουμε να λέμε εκεί;
ΥΓ Δέχτηκα προτάσεις και για τον benq 7500 (που ''πλεον φοράει DC 3'' - LoL από το DC4 προς 15ετίας τώρα αναβαθμίστηκαμε στο DC3 - ειναι για γέλια οι τύποι) :p
