Panasonic G100 - G100D
evanfotis
26 March 2008
5,475
Πρώτη φορά PDAF σε Panasonic?
Εναλλάξιμοι φακοί και μεγαλύτερος αισθητήρας απο τη Σονυ αλλά χειρότερη σταθεροποίηση βλέπω.
Lumix DC-G100
Resolution:20.30 Megapixels
Sensor size:4/3
(17.3mm x 13.0mm)
Kit Lens:2.67x zoom
12-32mm
(24-64mm eq.)
Viewfinder:EVF / LCD
Native ISO:200 - 25,600
Extended ISO:100 - 25,600
Shutter:1/16000 - 60 sec
Max Aperture:3.5 (kit lens)
Dimensions:4.6 x 3.2 x 2.1 in.
(116 x 83 x 54 mm)
Weight:14.8 oz (419 g)
includes batteries, kit lens
MSRP:$750
kbouk
8 January 2010
22,241
ΠΕΙΡΑΙΑΣ
Στα χαρακτηριστικά που ανέβασα εχθες απο Nokishita γραφει : Contrast AF system DFD technology
Image sensor size
17.3 x 13.0 mm (in 4:3 aspect ratio)
Lens mount
Micro Four Thirds mount
Type
Live MOS Sensor
Total pixels
21.77 megapixels
Camera effective pixels 20.30 megapixels
Color filter
Primary color filter
Dust reduction system No
Latitude
12 stops (V-Log L)
Image Stabilization System 5-axis HYBRID I.S.
Recording File Format: Still image JPEG (DCF, Exif 2.31)
RAW
Recording File Format: 4K PHOTO
MP4 (H.264/MPEG-4 AVC
Audio format: AAC (2ch))
Extracted still images: JPEG (DCF, Exif 2.31)
Recording File Format: Motion picture MP4 (H.264/MPEG-4 AVC
Audio format: AAC (2ch)) Aspect ratio
4:3 3:2 16:9 1:1
Image quality Raw
Raw+Fine Raw+Standard Fine
Standard
Color space sRGB
AdobeRGB
File size (Pixels): Still image
4:3: 5184x3888(L) / 3712x2784(M) / 2624x1968(S) / 3328x2496(4K Photo)
3:2: 5184x3456(L) / 3712x2480(M) / 2624x1752(S) / 3504x2336(4K Photo)
16:9: 5184x2920(L) / 3840x2160(M) / 1920x1080(S) / 3840x2160(4K Photo)1:1: 3888x3888(L) / 2784x2784(M) / 1968x1968(S) / 2880x2880(4K Photo)
File size (Pixels): Motion picture MP4: [4K] 3840x2160
4K/30p: 100Mbps 4K/24p: 100Mbps [Full HD] 1920x1080: FHD/60p: 28Mbps FHD/30p: 20Mbps FHD/24p: 24Mbps [HD] 1280x720 HD/30p: 10Mbps
File size (Pixels): Slow & Quick MP4: [Full HD] 1920x1080
60p, 28Mbps (Sensor output is 120fps / 30fps / 15fps / 8fps)
30p, 20Mbps (Sensor output is 120fps / 60fps / 15fps / 8fps / 4fps) Type
LCD Live View Finder Pixels
Approx. 3,680k dots equivalent Field of view / Magnification
Approx. 100% / Approx. 1.46x / 0.73x (35mm camera equivalent) with 50 mm lens at infinity; -1.0
m-1
Eye point / Diopter adjustment
Approx. 20 mm / -4.0 - +2.0 (dpt) Eye sensor
Yes Type
TFT LCD monitor with static touch control Monitor size
Free-angle, 3.0-inch (7.5cm), 3:2 aspect Pixels
Approx. 1,840k dots Field of view
Approx. 100% Type
Yes
Focus mode
AFS (Single)
AFF (Flexible) AFC (Continuous) MF
AF mode Face
Eye Detection Tracking 49-Area Custom Multi 1-Area Pinpoint
AF detective range
EV -4 - 20 (ISO100 equivalent)
Starlight AF Yes
AF assist lamp Yes
AF lock
Set the Fn button in custom menu to AF lock
Post Focus / Focus Stacking Yes / Yes
Others
AF-ON,Shutter AF, Half Press Release, Focus/Shutter Priority, Quick AF, Continuous AF (during motion picture recording), Eye Sensor AF, AF+MF, MF Guide, MF Assist, Touch MF Assist, Focus Peaking, Touch AF/AE Function, Touch Pad AF, Touch Shutter, Focus Switching for Vert/Hor, Focus Ring Lock, Loop Movement Focus Frame, Lens Focus Resume
Light metering system
1728-zone multi-pattern sensing system
Light metering mode Multiple
Center Weighted
Spot Metering range
EV 0 - 18 (F2.0 lens, ISO100 equivalent) Exposure mode
Program AE Aperture Priority AE Shutter Priority AE Manual Exposure
Exposure compensation
1/3 EV step, +/-5EV ( +/-3 EV for motion picture) AE lock
Set the Fn button in custom menu to AE lock White balance
AWB
AWBc
AWBw Daylight Cloudy Shade Incandescent Flash
White Set 1, 2, 3, 4
Color temperature setting 1, 2, 3, 4 White balance adjustment
Blue/Amber bias, Magenta/Green bias Color temperature setting
2500-10000K in 100K Type
Electronically-control focal-plane shutter Shutter speed
Still image: Time (Max. 60 second), 1/16,000 - 60 Motion picture: 1/16,000 - 1/25
Creative Video M mode / MF mode: 1/16,000 - 1/2
Live View Composite 1/2 - 60
Self timer
10sec, 3 images / 2sec / 10sec
Silent mode / Shutter type
Yes / Yes (Auto / Electronic front curtain / Electronic)
AE bracket
3, 5, 7 images in 1/3, 2/3 or 1 EV step, max. +/-3 EV, single/burst
Aperture bracket
3, 5 or all positions in 1 EV step
Focus bracket
1 to 999 images, focus steps can be set in 10 levels
White balance bracket
3 images in blue/amber axis or in magenta/green axis, color temperature setting
Burst speed
Electronic first curtain shutter:
AFS/MF: H: 6 frames/sec, M: 4 frames/sec (with Live View), L: 2 frames/sec (with Live View) AFF/AFC: H: 5 frames/sec, M: 4 frames/sec (with Live View), L: 2 frames/sec (with Live View)
Electronic shutter
AFS/MF: H: 10 frames/sec, M: 4 frames/sec (with Live View), L: 2 frames/sec (with Live View) AFF/AFC: H: 10 frames/sec, M: 4 frames/sec (with Live View), L: 2 frames/sec (with Live View)
Number of recordable images
RAW / RAW+JPEG: More than 20 images
JPEG: More than 480 images (When using a card with SD Speed Class with "UHS-I UHS Speed Class 3 (U3)".)
Burst speed
30 frames/sec
Exif information
Yes (Each JPEG image cropped out of the 4K burst file complies with EXIF)
Time Lapse Shot Yes
Stop Motion Animation Yes
Flash type
TTL Built-in-Flash, GN5.1 equivalent (ISO200 m) / GN3.6 equivalent (ISO100 m) (Reference), Built-in Pop-up
Flash mode Auto
Auto/Red-eye Reduction Forced On
Forced On/Red-eye Reduction Slow Sync
Slow Sync./Red-eye Reduction
Forced Off Synchronization speed
Less than 1/50 second Flash output adjustment
1/3EV step +/-2EV Flash synchronization
1st. Curtain Sync.
2nd Curtain Sync. Wireless control
Yes (When using DMW-FL200L / FL360L / FL580L (sold separately)), Wireless Channel:
1ch/2ch/3ch/4ch Digital zoom
2x
Extra Tele Conversion
Still image: 1.4x (EX M), 2.0x (EX S) Motion picture: 2.7x (FHD), 4.0x (HD)
Other functions
Level Gauge, Real-time Histogram
Guide Lines (3 patterns)
Center Marker
Highlight display (Still image / motion picture) Zebra Pattern (Still image / motion picture) Frame Maker
REC Frame Indicator
Live View Boost
Self Shot mode
Yes (Still image / motion picture)
Shutter
Shutter Button
Touch
Face Shutter Buddy Shutter
Effect
Soft Skin: 10 levels
Filter Select: Expressive / Retro / High Key / Monochrome / Toy Effect Background Control: Defocus / Clear
Slimming Mode: 10 levels
Direction Detection Function Yes
Rec
4K PHOTO / Exposure Comp. / Wi-Fi / Q.MENU / Video Record / LVF/Monitor Switch / LVF/Monitor Disp. Style / AF/AE LOCK / AF-ON / Preview / One Push AE / Touch AE / Level Gauge / Focus Area Set / Zoom Control / Operation Lock / Focus Ring Lock / Dial Operation Switch / Photo Style / Filter Effect / Aspect Ratio / Picture Size / Quality / Metering Mode / Burst Rate / Self Timer / Live View Composite / Bracket
Rec (Contd.)
Focus Mode / Highlight Shadow / i. Dynamic / i. Resolution / Min. Shtr Speed / HDR / Shutter Type / Flash Mode / Flash Adjust. / Wireless Flash Setup / Ex. Tele Conv. / Digital Zoom / Stabilizer / E-Stabilization (Video) / 4K Live Cropping / Snap Movie / Motion Pic. Set / S&Q Effect / Picture Mode in Rec. / Sound Rec Level Adj. / Sound Rec Level Disp. / Built-in Mic / Mic. Directivity Adjust
Rec (Contd..)
Silent Mode / Peaking / Histogram / Guide Line / Frame Maker / Zebra Pattern / Monochrome Live View / Constant Preview / Live View Boost / Rec Area / Step Zoom / Zoom Speed / Sensitivity / White Balance / AF Mode/MF / Drive Mode / Rec/Playback Switch / Off / Restore to Default
Play
Wi-Fi / LVF/Monitor Switch / Rec/Playback Switch / Send Image (Smartphone) / 4K PHOTO Play / Delete Single / Protect / Rating 1, 2, 3, 4, 5 / RAW Processing / 4K PHOTO Bulk Saving / Off / Restore to Default
Photo Style
Standard / Vivid / Natural / Scenery / Portrait / Monochrome / L. Monochrome / L. Monochrome D / Cinelike D / Cinelike V / V-Log L / Custom
Filter
Expressive / Retro / Old Days / High Key / Low Key / Sepia / Monochrome / Dynamic Monochrome / Rough Monochrome/ Silky Monochrome / Impressive Art / High Dynamic / Cross Process / Toy Effect / Toy Pop / Bleach Bypass / Miniature Effect / Soft Focus* / Fantasy / Star Filter/ One Point Color / Sunshine
Direct print
PictBridge compatible
USB
USB 2.0 Micro-B
HDMI
MicroHDMI TypeD / VIERA Link
Video: Auto / 4K/30p / 1080p / 1080i / 720p / 480p Audio: Stereo
External microphone input
Dia. 3.5mm (Stereo/Lens Auto/Shotgun/Super Shotgun/Manual is selectable when attaching DMW-MS2 (sold separately).)
Microphone
Stereo, Wind Noise Canceller: OFF / Low/ Standard / High
Speaker Monaural
Wi-Fi
IEEE 802.11b/g/n, 2412 MHz - 2462 MHz (1-11 ch), Wi-Fi / WPA / WPA2, Infrastructure mode
Bluetooth
Bluetooth v4.2 (Bluetooth Low Energy (BLE))
Battery
Li-ion Battery Pack (7.2V, 1025mAh, 7.4Wh)
Battery life (CIPA standard)
Approx. 270 images (rear monitor), 250 images (LVF), 900 images (Power Save LVF mode) with H-FS12032
Actual recordable time (Motion picture) 4K/30p:
Approx. 40 min (rear monitor), 35 min (LVF) with H-FS12032 Operating temperature
0 Degree C to 40 Degree C Operating humidity
10%RH to 80%RH
Recording media
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Dimensions (W x H x D)
Approx. 115 x 82.5 x 54.2mm
Weight
303g (body only)
412g (including lens, SD card, and battery)
514g (including lens, SD card, battery, and tripod)
karamela
6 November 2013
10,577
Εν έτη 2020 βγάζουν Vlog Μηχανή με τεράστιο crop στο 4Κ, απουσία 4Κ60p, απουσία IBIS, όριο 10 λεπτά στο 4Κ και contarst εστίαση, μόνο σαν τρολάρισμα μπορώ να το εκλάβω, και μετά λένε γιατί ο κόσμος αγοράζει κινητά. Απαράδεκτοι απλά και ντροπή για μια εταιρία σαν την Panasonic.
kbouk
8 January 2010
22,241
ΠΕΙΡΑΙΑΣ
Προδιαγραφές και συμβατότητα του νέου Tripod Grip (DMW-SHGR1)
A compact, lightweight handgrip / mini tripod allowing start/stop video recording and shutter release via USB connection.
Compatibility: DC-G100, GH5*,GH5S*,G9*, G95** and G85*
*Firmware update of the camera is required. It connects to the remote terminal of the camera using a bundled conversion cable. Sleep button cannot be used.
karamela
6 November 2013
10,577
Η Panasonic με κάθε νέα μηχανή βρίσκει κάτι να μας ξενερώσει, μέχρι τώρα το έπαιρνα στην πλάκα, τώρα όμως πραγματικά ''προσβάλλομαι'' με τέτοια προϊόντα σαν καταναλωτής φωτογραφικών ειδών. Προσβάλει την νοημοσύνη μου και είναι το λιγότερο ντροπή. Το βίντεο που έβαλες και ευγενικό είναι θα έλεγα. Πριν 5-7 χρόνια ίσως να ήταν super η μηχανή τώρα μόνο γέλιο προκαλεί και θλίψη για την κατάντια που έχουν φτάσει η Panasonic και όχι μόνο.
Υ.Γ. Η awkward στιγμή που συνειδητοποιείς ότι τι κινητό σου (iphone SE) που δεν είναι και ναυαρχίδα είναι καλύτερα εξοπλισμένο σε βίντεο από μια μηχανή (της Panasonic μάλιστα) που απευθύνεται σε vloggers και γενικά για βίντεο.
kbouk
8 January 2010
22,241
ΠΕΙΡΑΙΑΣ
G100 Firmware Version 1.2
  1. Added functions
– Users can choose to add or not to add camera orientation information in [Vertical Position Info (Video)] menu to prevent unintended image rotation in playback.
– The camera can be recognized when it is connected to the PC via the USB power supply port.
  • Apple and ProRes are trademarks or registered trademarks of Apple Inc. in the United States and/or other countries.
  • Ninja V / ATOMOS are registered trademarks of ATOMOS Limited.
  • Other trademarks and trade names are those of their respective owners.
  • Design and specifications are subject to change without notice.
cacau
7 June 2008
20,345
Διαδικαστικά και μόνο, αναφέρω ότι τελικά η... διάδοχος - λέμε τώρα - G100D τελικά θα διατεθεί και στην Ευρώπη. Στην Γερμανία (όπου η panny έχει ισχυρή παρουσία), δέχονται προπαραγγελίες, σώμα + κιτ 12-32 στα 699€ και διάφοροι άλλοι συνδυασμοί...
Και το σύντομο επίσημο βίντεο - παρουσίαση:
Οι μόνες διαφορές σε σχέση με την υπάρχουσα G100 είναι η θύρα φόρτισης USB-c και το καλύτερο EVF.
isin
19 October 2011
461
Ένα πράγματα με χαλούσε από την αρχή στη μηχανή αυτή... Δεν έχει IBIS αλλά μόνο Electronic Stabilization. Ούτε αυτό δεν πρόσθεσαν...
Βλέπουμε συχνά πλέον τέτοια πολύ μικρά - ασήμαντα upgrade. Όπως και με την OM System TG7 πρόσφατα που περίμενα κάποια αναβάθμιση αλλά την έβγαλαν με USB-C μόνο.
Εντωμεταξύ βάζουν και το TypeC και δεν σου δίνουν και φόρτισμα και λειτουργία ταυτόχρονα. Το έχεις και δεν το εκμεταλλεύεσαι...
