Blackmagic URSA Mini Pro 12K
evanfotis
26 March 2008
5,475
Blackmagic Design has just announced a new production camera – Blackmagic URSA Mini Pro 12K. It has a super35 sensor and shoots BRAW full-sensor in 12K up to 60fps, 8K up to 120fps, 6K up to 120fps, or 4K 120fps. In Super16 crop mode, it can shoot up to 220fps. There is a USB-C slot for recording on external drives.
BLACKMAGIC URSA MINI PRO 12K FEATURES
12,288 x 6480 12K Super 35 sensor.
Use for feature films, VFX and high end TVC’s.
14 stops of dynamic range and native 800 ISO.
New Blackmagic RAW for real time 12K editing.
Blackmagic RAW optimized for Metal, CUDA and OpenCL.
Generation 5 Color Science with new film curve.
Shoot up to 60 fps in 12K, 110 fps at 8K and 220 fps at 4K.
Dual card CFast recording at up to 900MB/s.
PL mount included, EF and F mounts available.
SuperSpeed USB-C for recording to external disks.
Includes DaVinci Resolve Studio for post production.
Compatible with new Blackmagic URSA Mini Recorder.
https://www.youtube.com/watch?v=LMZEjG4Nd3M
The camera has a super35 sensor with 12,288 x 6480 resolution and DCI 17:9 ratio. Grant Petty explained Blackmagic went for 12K so that filmmakers can easily reframe shots for 8K or 4K delivery. The sensor is brand new, it has a new color science, and according to Blackmagic Design, it is the first sensor designed especially for BRAW.
New Blackmagic URSA Mini Pro 12K. Source: Blackmagic Design
From outside, the camera looks the same as older URSA models, but the internals is brand new according to Blackmagic Design. The camera comes with PL-mount but offers an interchangeable lens mount to Canon EF mount.
The sensor’s native resolution is 12K but it can record in lower resolution without crop and without binning as well. The supported full-sensor recording modes in Blackmagic RAW are as follows:
12K up to 60fps
8K up to 120fps
6K up to 120fps
4K 120fps
The camera has internal ND filters, Dual cFast cards, 12G SDI output, and USB-C port for recording on external SSDs. An interesting feature is that the camera can record on both cFast cards at the same time which offers up to 900MBps recording speed. Dual card recording means that every second frame gets saved on each card. If you lose one card, you still get a usable file, but with only half the frame rate.
Blackmagic RAW has been updated as well. There is a new film curve for BRAW – generation 5. BMD says it should offer better highlight roll-off, better skin tones, and more flexibility in post. Grant Petty also demonstrated how he edits the 12K footage on a laptop and in multi-cam mode on a Mac Pro.
The price will be $9,995. The updates for DaVinci Resolve to work with 12K are coming soon.
evanfotis
26 March 2008
5,475
Απάντηση: Blackmagic Design Pocket Cinema Camera 4K
Δε κατάλαβα, ο αισθητήρας δεν ειναι bayer, λέει rgb, εννοεί σαν foveon?
evanfotis
26 March 2008
5,475
κατι δε παει καλα με τα bitrates...πολυ μικρα για 8Κ Q0...
Blackmagic RAW Q0 - 241 to 578 MB/s. oσο το 5:1 περίπου... Blackmagic RAW 5:1 - 578 MB/s
Kosh
7 September 2006
91,142
Εκεί ψηλά.....
The new 12K sensor has equal amounts of red, green and blue pixels and is optimized for images at multiple resolutions. You can shoot 12K at 60 fps or use in-sensor scaling to allow 8K or 4K RAW at up to 110 fps without cropping or changing your field of view. The new 12K sensor was designed around using 12-bit BRAW.
BRAW records at a constant bitrate with encoding options of 5:1, 8:1, 12:1, and the new 18:1 are designed to give you the best possible images with predictable and consistent file size.
Kosh
7 September 2006
91,142
Εκεί ψηλά.....
Re: Απάντηση: Blackmagic URSA Mini Pro 12K
Δεν θα ελεγα τιποτα αν δεν το δω. Μιλαμε για εντελως νεο αισθητηρα. Θαναι πολυ ενδιαφερον τι εστηναν τοσο καιρο.
Υποψιν οτι εδω και μηνες ξεραμε απο μεσα οτι ετοιμαζουν 8k καμερα.
Το οτι παρουσιασαν τελικα mini ursa pro 12k !!! μου αφηνει ενα παραθυρο αισιοδοξιας οτι μπορει να παρουσιασουν και νεα Pocket 8k καποια στιγμη.
tiniakos
7 August 2007
16,146
Τήνος / Ελλάς
12Κ και ακόμη στο λαιμό μου έχει κάτσει το 4Κ.
Τι να τα κάνεις όμως όλα αυτά αν δεν έχει ibis.
Πέρα από την πλάκα λέγαμε για τα κινητά με τα 100mp και μας έσκασε η μαύρη μαγεία με τα 80.
Η τιμή επίσης είναι σκάνδαλο.
kbouk
8 January 2010
22,233
ΠΕΙΡΑΙΑΣ
Αφού γονάτισε την ημιεπαγγελματική κατηγορία με δυο προϊόντα σταθμός σε ασυναγώνιστη τιμή κάνει το ίδιο και στην φουλ επαγγελματική κατηγορία της παραγωγής. Στοχευμενα προϊόντα σε καλή τιμή σε συγκεκριμένο κοινό. Και με πόρους μικρότερους από άλλες εταιρίες Αυτό είναι το μυστικό και αυτοί εκεί στην ΒlackMagic βλέπω το έχουν καταλαβει εδώ και καιρό.
Kosh
7 September 2006
91,142
Εκεί ψηλά.....
12Κ και ακόμη στο λαιμό μου έχει κάτσει το 4Κ..
Η ΒΜ ακομα και το 4k RAW καταφερε να το "χωρεσει" σε καλυτερα παπουτσια πιο ανετα και με τιμη που δεν υπαρχει στον ανταγωνισμο. Ειμαι βεβαιος οτι και στα μεγεθη χωρητικοτητας του 12k θα εχουν βρει λυση.
nicksoti
14 April 2013
1,911
Εγώ υποθέτω μια χαρά πόρους έχει η BM πλέον, απλά ξοδεύει εκεί που πρέπει. Εύκολα θα μπορούσαν να κάνουν ένα event και ένα promo video βαρύγδουπο με φωτισμούς περίεργους και εφέ, "έφτασε", "τα αλλάζει όλα", "how big is big enough", "game changer" κλπ κλπ κλπ.
Αντ αυτού ένα live στο youtube, σε ένα δωμάτιο στον πάγκο εργασίας. Εϊναι θέμα νοοτροπίας λοιπόν.
geozigo
24 May 2007
142
Δεν νομίζω να υπάρχει φακός που να μπορεί να αξιοποιήσει τα 80mp του αισθητήρα βέβαια. Πχ ο Otus 85mm έχει κάπου 36mp διακριτική ικανότητα αν δεν κάνω λάθος. Λόγω diffraction και σφαλμάτων πρέπει να είναι πολύ οριακά τα πράγματα.
evanfotis
26 March 2008
5,475
Απάντηση: Re: Blackmagic URSA Mini Pro 12K
Ενα μικρο promo video δε μπορούσαν να βγάλουν;
μετά τη παρουσίαση.
Μιλάμε για μηχανή 10 χιλιάρικα στα 15 μόλις την εξοπλίσεις με τα αξεσουάρ.
Να δείξουν τις δυνατότητες, το νέο ασιθητήρα με όλα τα sub pixels κλπ... Δε χρειάζεται ακριβή παραγωγή, ενα σποτάκι ενοσ δυο λεπτών...
Ακόμα και με στατικές εικόνες απο το site τους στο AE...
Kosh
7 September 2006
91,142
Εκεί ψηλά.....
Το ποτε θα ανακοινωθει μια καμερα το επιλεγουν κυριως βασει management.
Δεν θα μου εκανε εντυπωση η καμερα να ολοκληρωνεται αυτες τις ημερες αλλα να ηθελαν να την ανακοινωσουν μετα τον "παταγο" των 8k της Canon και πριν τις ανακοινωσεις της Sony για να μην ασχοληθει κανεις μαζι τους.
Ε μεταξυ επαγγελματιων στριφογυριζει αυτη η ιδεα....με τετοια προσοντα.
Η δε κινηση αυτη που μαλλον επιασε με τα βρακια κατω ολη την κινηματογραφικη πιατσα (Θυμιζω οτι η RED Komodο που μολις βγηκε κοστιζει 3 χιλιαρικα πιο φτηνα απο την mini ursa προ 12κ και εχει μονο την μιση της !!!! αναλυση ) μοιαζει πολυ με την RED ONE καποτε εσπασε την πιατσα προσφεροντας καμερα 4k με 17000$ ενω για μια Sony 1080p τοτε επρεπε να σκασεις πανω απο 100000 . Το δε RAW ηταν αγνωστη λεξη στους μηχανικους της Sony.
Ελπιζω να μην εχει την πορεια της RED και η ΒΜ.
