[Επίσημο] HTC HD 2
Φρα.Πε.
6,443
Ελευσίνα
Έφτασε γεμάτο καλούδια που δεν το αφηνουν να περναει απαρατηρητο
ξεχωρίζω
-capacative oθόνη (ok καλοδεχούμενο αν και παει η ακρίβεια)
-4.3 inch 480 X 800
-1ghz επεξεργαστής
-G-Sensor, Footprints, Digital Compass
-Διαστασεις 11mm ΠΑΧΟΣ!!! Χ67Χ120mm!! (παντοφλαρα αλλα η τεράστια οθόνη αντάλλαγμα)
-5mp camera με διπλο flash
Full Specs
• Processor:
Qualcomm® MSM8250™, 1 GHz
• Operating System:
Windows Mobile® 6.5 Professional
• Memory:
ROM: 512 MB / RAM: 448 MB
• Display:
4.3-inch TFT-LCD touch-sensitive screen with 480 X 800 WVGA resolution
• Network:
HSPA/WCDMA: Europe/Asia: 900/2100 MHz - Up to 2 Mbps up-link and 7.2 Mbps down-link speeds
Quad-band GSM/GPRS/EDGE: 850/900/1800/1900 MHz
(Band frequency, HSPA availability, and data speed are operator dependent)
• GPS:
Internal GPS antenna
• Connectivity:
Bluetooth® 2.1 with Enhanced Data Rate and A2DP for wireless stereo headsets
Wi-Fi®: IEEE 802.11 b/g
3.5 mm stereo audio jack
Standard Micro-USB (5-pin micro-USB 2.0)
• Camera:
5 megapixel color camera with auto focus and dual LED flashlight
• Audio supported formats:
.aac, .amr, .m4a, .mid, .mp3, .mp4, .qcp, .wav, .wma
• Video supported formats:
.wmv, .asf, .mp4, .3gp, .3g2, .m4v, .avi
• Battery:
Rechargeable Lithium-ion battery
Capacity: 1230 mAh
Talk time: Up to 320 minutes for WCDMA / Up to 380 minutes for GSM
Standby time: Up to 390 hours for WCDMA / Up to 490 hours for GSM
(The above are subject to network and phone usage)
• Expansion Slot:
microSD™ memory card (SD 2.0 compatible)
• AC Adapter:
Voltage range/frequency: 100 ~ 240V AC, 50/60 Hz
DC output: 5V and 1A
• Dimensions (LxWxT):
120.5 X 67 X 11 mm (4.74 X 2.64 X 0.43 inches)
• Weight:
157 grams (5.54 ounces) with battery
• Special Features:
G-Sensor, Footprints™, Digital Compass
preview (παει σφεντόνα!!!)
http://www.youtube.com/watch?v=N63otP9Gu-4
http://www.youtube.com/watch?v=P0DlNKfqzYk&feature=related
αντε να το δουμε και απο κοντά...
airb
25 May 2008
15,116
Λιβαδειά
Απάντηση: hTC HD 2, γιατι εχθρός του καλού ειναι το καλύτερο
Και εγώ περιμένω να το δω από κοντά.. αλλά φοβάμαι ότι θα είναι πολύ μεγάλο (4,3" οθόνη) :frown:.
Με το παλιό HD που είχε και 3,8" οθόνη το αγόρασα και το πούλησα μέσα στην εβδομάδα
λόγο μεγέθους!! Το νέο βέβαια HD2 μπορεί να το σώσει το πάχος του... Ίδωμεν :grandpa:
pontios
6,736
Clermont-Ferrand, France
Τέτοια αριστουργήματα δυστηχώς μπορούμε να τα εκτιμήσουμε πολύ λίγοι. Το επόμενο τηλεφωνάκι που περιμένω με αγωνία. Και άσε τα παιδάκια να παίζουνε με το crappyphone.
Φρα.Πε.
6,443
Ελευσίνα
χαχαχχα εγω κρατήθηκα πάντως δεν εκανα κανένα σχόλιο για την αντίπαλη όχθη !!! -bye-
23,740
Μόνο που αν δεν υπήρχε το crappyphone θα έκαναν πολλά χρόνια να ξυπνήσουν οι εταιρείες να βγάλουν τέτοιες συσκευές κυρίως στο θέμα interface......
Υ.Γ. Για να πω την αλήθεια μου, το μόνο που ζηλεύω είναι το 4.3" :worshippy:
pontios
6,736
Παιδιά μπήκε Applehackerάς, φάτε τον ζωντανό.
Τάσο όντως το iphone ξύπνησε πολλούς. Ξεπεράστηκε όμως πολύ γρήγορα και έγινε ακόμα ένα apple επίτευγμα που τραβιέται όσο γίνεται χωρίς ουσιαστηκές αλλαγές.
Όταν θα έχω το απίστευτο αυτό εργαλείο στα χέρια μου, θα κάνω και παρουσίαση αλλά είστε και καλοδεχούμενος να το δεις και να καταλάβεις τι σημαίνει πραγματικό Business-Fun-Play-Touch-Ultimate phone.
=silent=
2 August 2006
11,095
Homeless
Re: hTC HD 2, γιατι εχθρός του καλού ειναι το καλύτερο
Και σε ενα μηνα δεν θα ασχολείται κανένας με αυτο το τηλέφωνο όπως έγινε και με τον προκάτοχο του.
spcav
18 August 2006
16,598
Ας αλλάξει καλύτερα ο τίτλος σε ''hTC HD 2, γιατι εχθρός του ΑΡΓΟΥ ειναι το ΑΡΓΟΤΕΡΟ'' :p
Μακαρι τα 6.5 να κάνουν τη διαφορά αλλά δεν ελπίζω σε πολλά....
Χωρίς να έχω καταλήξει στο ότι το γυρίζω σε iphone, εχω καταλάβει απλώς ότι αν δεν σου λείπει κάτι συγκεκριμένο από το τελευταίο, σε επίπεδο εφαρμογής, δεν έχεις λόγο να μείνεις με win mob.
pontios
6,736
Μέχρι τη άλλη Παρασκεύη θα το έχω στα χέρια μου. Εντυπώσεις λοιπόν λίαν συντόμως. ενημερωτικά στο Ελλάντα θα έρθει τέλος Δεκέμβρη αποκλειστικά σε ένα πάροχο. Κα όχι αυτόν που θέλουμε.
lykman
29 June 2006
5,798
Aθήνα
Δελτίο Τύπου
11/11/2009
Το HTC HD2 αποκλειστικά από τη Vodafone
Η Vodafone, πιστή στις υποσχέσεις της, συνεχίζει να προσφέρει πρώτη και αποκλειστικά τις πιο δημοφιλείς συσκευές λανσάροντας στην ελληνική αγορά το HD2 της HTC.
Το HD2 αποτελεί το πρώτο κινητό τηλέφωνο με λειτουργικό Windows Mobile 6.5, HTC Sense™ και οθόνη αφής 4.3 ιντσών, τεχνολογίας capacitive, χάρη στην οποία η προβολή, η μεγέθυνση και η αλλαγή της διάστασης ιστοσελίδων, αρχείων Microsoft® Office, PDF και φωτογραφιών πραγματοποιείται με ένα απλό άγγιγμα των δαχτύλων.
Η μεγάλη οθόνη επιτρέπει την ταχύτατη εισαγωγή κειμένου, με χαρακτηριστική ακρίβεια. Παράλληλα, ο νέος επεξεργαστής Qualcomm, με ταχύτητα χρονισμού στο 1GHz, με τον οποίο είναι εξοπλισμένο το HTC HD2, προσφέρει απαράμιλλη ανταπόκριση στις εντολές και αυξημένη ταχύτητα σε παιχνίδια, βίντεο, αλλά και σε οποιαδήποτε εφαρμογή, καθώς και στις νέες υπηρεσίες My Phone και Windows Marketplace for Mobile της Microsoft.
Το HD2 θα είναι διαθέσιμο από την αλυσίδα καταστημάτων Vodafone από τις αρχές Δεκεμβρίου, με τιμή 699 (λιανική τιμή με ΦΠΑ) και δώρο το πρόγραμμα φωνητικής πλοήγησης NDrive.
Έως τότε οι ενδιαφερόμενοι θα μπορούν να εκδηλώνουν ενδιαφέρον για την απόκτησή του, μέσα από τα καταστήματα Vodafone, την ενότητα μελλοντικές συσκευές και καθώς και τα καταστήματα ΠΛΑΙΣΙΟ και το www.plaisio.gr.
http://www.vodafone.gr/portal/client/eshop/details-42000.action
Φρα.Πε.
6,443
Ελευσίνα
Η τιμή ειναι σχετικά καλή αν σκεφτούμε τον ανταγωνισμό και τι...δίνει σε σχέση με το HD2
pontios
6,736
Σήμερα παραλαμβάνω οπότε θα σας πω και εντυπώσεις.
airb
25 May 2008
15,116
Λιβαδειά
Review στο myPhone από των -αξιόπιστο- Ζαχαράκη..
ποστ.1 said:
δυστυχως η 1η εντυπωση με το τηλεφωνο,εκτος απο την ποιοτητα κατασκευης που δειχνει στιβαρη,ειναι αρνητικες....
πολλες προχειροτητες και τσαπατσουλιες...
βιαστηκανε να το βγαλουνε και τα κανανε πουτ...ανα :blush:
πραγματικα γρηγορο εως σφαιρατο αλλα οσοι εχετε χοντρα δαχτυλα η χερια σαν τα δικα μου με σκληρο καταπονημενο δερμα....
ΞΕΧΑΣΤΕ ΤΟ τουλαχιστον για τωρα.....στην μορφη που ειναι...
δεν μπορω να γραψω κατι συγκεκριμενο μιας και εχω απογοητευτει αρκετα σε σημειο που δεν ξερω απο που να αρχισω και που να τελειωσω....
φευγω για δουλεια σε λιγο και το παραταω ...αργα το βραδυ θα εχετε νεα μου...
η ελλειψη stylous ειναι ΑΙΣΘΗΤΗ τουλαχιστον για τα χερια τα δικα μου....
δεν ειναι κακη συσκευη αλλα ΔΕΝ ΕΙΝΑΙ ΕΤΟΙΜΗ για να βγει στην αγορα και να κανει αυτα που υποσχεται...η τουλαχιστον που νομιζαν οι γατοι της htc οτι θα εκανε :flipout:
μια ζωη μαλκιες....
ποστ.2 said:
δεν ξερω αν θελει κανεις να ακουσει τι γινεται αλλα προσπαθησα αρκετα να ποσταω απο το λεο πολλες φορες κ με τον explorer αλλα κ με τον οπερα.
Επιτελους τα καταφερα κ με τεραστια ευκολια !!!!
Κ ξερετε τι λαθος εκανα;;;
Ειχα παρει λαθος συσκευη····
ετσι πηρα το μηλοφωνο και επιτελους ποσταρω μια χαρα....
Ενα μπου......ρδ··ελο κ μισο το λεο φιλοι μου .....
Δεν μπορεις να κανεις ουτε τα αυτονοητα ευκολα.....
Δεν μπορω να καταλαβω γιατι κανεις δεν μιλαει .....
Μονο εγω τα βλεπω η ειμαι τοσο περιεργος;;;
Μαλλον φταιει που εχω κ το iphone παραλληλα κ εχω καλομαθει...
Η ρομ που φοραει η συσκευη ειναι με τεραστιες τρυπες κ ελλειψεις παιδικες...
Δεν μπαινω σε λεπτομερειες ακομη μιας κ δεν μου φτανει ολο το myphone για να τα γραψω....
Αν παιζεις με φωογραφιες και το μανιλα ολα πανε σφαιρα.... Και γενικα οτι εχει να κανει με το ui του touch flo...μολις ομως μπεις στα windows αρχιζει το πανυγηρι
ποστ.3 said:
Δεν νομιζω να περιμενε κανεις οτι θα ευλογησω τα γενια της htc....
Το τηλ το κραταω μονο κ μονο γιατι ειναι τουμπανο απο harware...
Ολα τα υπολοιπα ειναι μλκιες.
Εν αναμονη λοιπον hspl κ καποιας αλλης ρομ.
Δεν θα κατσω να σκασω με την μλκια που πηγα κ πηρα. Στο συρταρι κ σβηστο!!
Θελουν ΠOΛΛA KAPBEΛIA AKOMH NA ΠΛHΣIAΣOYN οχι να φτασουν TO MHΛO οι assholes της htc!
Τελος οποια αναφορα απο εμενα για το τηλ!οσοι θελουν να το παρουν να ειναι σιγουροι πρωτα οτι εχουν γερο στομαχι κ μετα να προβουν σε οποια αγορα αυτης της συσκευης Παραγωγης τρελας....
Κατα τα αλλα
ποιοτητα κατασκευης πολυ καλη
οθοναρα
hardware απο αλλο πλανητη
καμερα μακραν οτι πιο γρηγορο κ καλυτερο εχω δει σε τετοιες συσκευες
σημα δικτυου πολυ καλο
gps γρηγορο κ σταθερο,μου θυμισε καιζερ
μανιλα τουρμπο κυριολεκτικα!!
Αισθηση οθονης κορυφαια αλλα πισω απο του μηλου
διαυγεια/χρωματα οθονης παρα πολυ καθαρα κ ζωντανα
το ιδανικο gatzet να σε φερει στα προθυρα του εγκεφαλικου με τις απαραδεκτες ελλειψεις του αλλα κ με την ελλειπεστατη σχεδιαση του λογισμικου του
airb
25 May 2008
15,116
Λιβαδειά
Προσωπικά πάντως το review του Δημήτρη (zaharaki) μου είναι υπέρ αρκετό
Να μην προβώ στην αγορά του συγκεκριμένου τηλεφώνου!!!!!
lykman
29 June 2006
5,798
Aθήνα
τώρα αυτά που μεταφέρθηκαν θεωρούνται "review"? Καταρχήν προσωπικά εγώ θα ντρεπόμουν να τα ποστάρω, μόνο και μόνο από το ύφος της γραφής... Ούτε από ουσία μπορώ να δω κάτι που να παραπέμπει σε "review"... Κάτι σε υβρεολόγιο ίσως...
Φρα.Πε.
6,443
Ελευσίνα
Ελλειψεις?? ΠΛΑΚΑ ΜΑΣ ΚΑΝΕΙ????
εαν εχει ελλειψεις αυτη η συσκευή τοτε το iphone (ειδικα 1η γενεας) θα επρεπε να εχεi λιθοβολιστει!!!!!!
apple fan boy reviewing an htc?? sure thing boss...
Και περα απο οτι τον κραζουν και τον ιδιο οι υπολοιποι κατοχοι ειναι ευχαριστημένοι.
Προσωπικη άποψη -ακομα- δεν εχω. Σύντομα ομως...
Che
1 September 2008
1,774
ΓΛΥΚΑ ΝΕΡΑ
Θελω να γινω χαλιφης στη θεση του χαλιφη .Αμ δε , εχουν να φανε πολλα ψωμακια ακομα για να φτασουν το iphone.Kι αφου σας λεει ρε παιδια ο χριστιανος οτι εχει κανει αμεση αντιπαραθεση τα 2 τηλεφωνα γιατι τον κραζετε?Και εγω το diamont ειχα και το τρωει το συρταρι.Αν πιασεται ποτε στα χερια σας το μηλαρακι ΚΟΛΛΗΣΑΤΕ ΤΕΛΟΣ.
