Νεο Egreat ΝΜΤ - A1080
nasosmp
20 June 2007
107
Κερατσίνι
Στο site της η Egreat έδωσε στοιχεία για ένα νέο NMT (Α1080) που φαίνεται τουλάχιστον ενδιαφέρον.
EGREAT TECHNOLOGY CO.; LTD
HDMI1.3 network HDD player (A1080)
Features:
Ø Solid Aluminum alloy slim case, good heat sink; at same time, mobile rack design give user
easily/friendly/quickly installation.
Ø Besides of internal 2.5 mobile rack for 2.5 SATA HDD, there is another external SATA
port for external SATA HDD or Blu-ray DVD ROM without extra power.
Ø Support BD disk (need extra SATA BD-ROM which isnt standard accessory)
Ø Special USB3.0 slave port.
Ø Can be refurbish to other FW depend on your choice.
Ø NFS & Samba are supported.
Ø External subtitle can be adjusted size/color/position and so on.
Ø File copy/delete can be supported.
Ø Power on/off by remote control.
Ø Sigmadesign8643 667MHz CPU ,256MB NAND FLASH and 512MB DDR2.
Output connectors:
Video Outputconnectors:
Ø HDMI 1.3
Ø Composite
Audio Outputconnectors:
Ø Stereo
Ø SPDIF Digital audio output
Other interface:
Ø 2 x USB hosts.
Ø 1 x USB3.0 slave
Ø 1 x SATA port which can install DVD ROM or HDD without extra power.
Network
Ø Ethernet 10/100/1000M
Ø
Power on/off control by RC
Ø Add one MCU which can support power on/off by RC.
Spec:
Video format
MPEG1/2/4 Elementary (M1V, M2V, M4V)
MPEG1/2 PS (M2P, MPG)
MPEG2 Transport Stream (TS, TP, TRP, M2T, M2TS, MTS)
VOB
AVI, ASF, WMV
Matroska (MKV)
MOV (H.264), MP4, RMP4
Video codec
XVID SD/HD
MPEG-1
MPEG-2 -MP@HL
MPEG-4.2 - ASP@L5, 720p, 1-point GMC
WMV9 -MP@HL
H.264 -BP@L3 ,[email protected] ,[email protected] ,[email protected]
VC-1 -MP@HL ,AP@L3
Audio format
AAC, M4A
MPEG audio (MP1, MP2, MP3, MPA)
WAV
WMA
FLAC
OGG
Audio codec
WMA, WMA Pro
AAC
MP1, MP2, MP3
LPCM
FLAC
Vorbis
DTS Stereo
Dolby Digital
Picture format
JPEG, BMP, PNG, GIF
Subtitle format
SRT, SMI, SUB, SSA
HDD partition
FAT32, NTFS,EXT3
Unit size
165x165x35mm
Package:
Ø Remote control 1pcs
Ø 7P+15P SATA cable 1pcs
Ø USB 3.0 cable 1pcs
Ø 12V/3A power adapter 1pcs
Ø AC cable 1pcs
Ø CD-R 1pcs
Ø User guide 1pcs
http://www.egreatworld.com/en/ProductShow.asp?ID=183
Tsop
5 November 2007
645
Βριλήσσια
Ενδιαφερον! Ο αντικαταστατης του M34A να υποθεσω. Επισης στο site βλεπω υπαρχει και το R4A και R4B, καινουργια μοντελα λογικα.
vadergr
17 August 2007
27,467
Μεταμορφωση
Δεν αναφερει κατι για hd audio και για full bd menu...
Αν παιζει menu blu ray σιγουρα θα παιξει και hd audio αφου και τα 2 πανε πακετο με το licence...
nigio
22 December 2008
271
και τωρα ενα ερωτημα..xtreamer pro ή αυτο??να ρωτησω.ξερει κανεις αν εχει στανταρ τορρεντ client οπως το M34A?
fits79
Banned
22 January 2008
2,389
To remote control είναι ακριβώς ίδιο με αυτό των popcornhour όπως επίσης φοράει το chipset που έχει και το wd tv live εννοείτε ότι έχει πολύ περισσότερα(Όπως usb3, esata, bluray iso menu κ.τ.λ.) αλλά στάνταρ θα τα πληρώνεις όλα αυτά τα έξτρα καθότι αποκλιεται να κοστίζει μεχρι 100 ευρώ που κοστίζει τώρα το wd tv live έτσι δεν είναι?
Μακάρι να κοστίζει βέβαια τόσο αλλά δεν το κόβω.
Έχει το λογισμικό που έχουν και τα popcornhour αν όχι τότε ποιο έχει?
furious99
20 December 2008
866
Φαινεται οτι η Egreat ξαναγυριζει και σε Sigma γιατι τα realtek μηχανακια της δεν περπατησαν ιδιαιτερα καλα στην αγορα (φυσικο ειναι αφου υπαρχει πληθωρα απο δαυτα και σε τιμες που δεν αφηνουν περιθωρια μεγαλου κερδους).
Απο την αλλη μερια η επιλογη της Popcornhour να βαλει αθλια πλαστικη θηκη στο A-200 (για να γλιτωσει 10 δολλαρια? να πεσει λιγο η τιμη του? να μην υπαρχει εσωτερικος ανταγωνισμος με το C-200? ), αφηνει πολλα περιθωρια σε αλλους, αρκει βεβαια η τιμη να ειναι καλη (οχι σαν του HDX BD-1, C-200, DUNE3) και το firmware αναλογο (dts-hdma audio και bluray menus ειναι απαραιτητα για να πληρωσει καποιος παραπανω απο το WD-Live αυτη τη στιγμη)...
lykman
29 June 2006
5,798
Aθήνα
δεν φοράει το chipset του WDTVL (865X/500MHz) αλλά το ισχυρότερο της σειράς... το 864X/667ΜΗz.
Θα στοιχημάτιζα ότι η τιμή του θα είναι 200ε+ όταν ξεκινήσει η διαθεσιμότητα...
fits79
Banned
22 January 2008
2,389
Ναι έχεις δίκιο το egreat a1010 θα φοράει το sigma tech 8643 ενώ το wd tv live φοράει το sigma tech 8655 που είναι υποδιερεστερο σε δυνατότητες αυτού που έχει το wd tv live με βάση αυτό.
Πάντως ένα καλό για το 8655 είναι ότι είναι το τελευταίο και δυνατότερο sigma tech chipset της σειράς 865x
Και συμφωνώ απόλυτα με αυτό που εχω τονίσει.
furious99
20 December 2008
866
To εχουμε πει, η διαφορα μεταξυ sigma 8655 και 8642/3 ειναι μονο στη δυνατοτητα αναπαραγωγης πολλαπλου HD σηματος π.χ. σε 2 οθονες ταυτοχρονα, κατι που καμια συσκευη της αγορας δεν εκμεταλλευεται, αφου προκειται για ειδικη περιπτωση που δεν ενδιαφερει τον απλο χρηστη.
Ουτε τις HD ταινιες θα παιξει καλυτερα το 8642/3...
Ουτε ειναι πιο γρηγορο στην αναγνωση δισκων, μεταφορα αρχειων, torrents κλπ. αφου οι λειτουργιες αυτες ελεγχονται απο το δευτερο επεξεργαστη 333Mhz που ειναι κοινος σε 8655 και 8642/3...
furious99
20 December 2008
866
Ναι και τα DSP's.
To 8642/3 ειναι απαραιτητο μονο για οσες συσκευες θα παρουν bluray drive πανω τους για να διαβασουν γνησια bluray π.χ. το C-200 και το BD1 (εχουν βαλει καποιες εντολες μεσα για να διαβαζει τα κλειδια του bluray).
Η PCH βαζει μονο 8643 για να εχει κοινο firmware σε ολα τα players και να διευκολυνεται το bugfixing. Το A-200 και το popbox θα μπορουσαν ανετα να εχουν το 8655, και ισως να ηταν και πιο καλο για το θεμα θερμοτητας...
furious99
20 December 2008
866
Τελικα με την ενδεικτικη τιμη στο link που δινεις, και το Α1080 δεν το γλυτωνει το 200ευρω. Δε μας βοηθαει και η ισοτιμια με το μαμημενο το δολλαριο πλεον... Το S2 που παιρνει εσωτερικο δισκο γιατι ειναι πιο φτηνο? αυτη η egreat ειναι να μη βγαλει, αμα βγαλει τα πεταει 10-10 τα μοντελα...
lykman
29 June 2006
5,798
Aθήνα
Αρα ξαναγυρίζουμε στο ότι τελικά έχουν (σημαντικές) διαφορές, γιατί τα μεν με τα 865Χ είναι media players, ενώ τα δε με το 864Χ υπό προϋποθέσεις εκτός από media players μπορούν να αποτελέσουν και BR players αν καταλαβαίνω καλά...
onlineN
12 April 2009
5,316
ΑΘΗΝΑ
Εμένα το S2 μ'αρέσει πάντως!
