Popcorn Hour A-300 !!!
vadergr
17 August 2007
27,463
Μεταμορφωση
Βγηκαν στην φορα τα χαρακτηριστικα του νεου mp της γνωστης εταιρειας ...
Βασιζεται στο νεο sigma 8647@800mhz.Διαθεσιμο στην Αμερικη τελη του μηνα.
Sigma Designs 8647 CPU with L2 Cache
High Speed USB 3.0 connection to PC
10/100/1000mbps Gigabit Ethernet
Fully automated Media Jukebox
Full Flash Interface
3D MKV Support
Media jukebox for all your digital needs
Apps Market for your TV
HDMI 1080/24P
Supports Internal SATA HDD
NAS Server
BT/ Usenet Client
Aluminum chassis
Fanless
xrthammp
6 June 2008
495
Popcorn A300
Νέο Popcorn Α300 ανακοινώθηκε σήμερα. Επεξεργαστής Sigma 8647, 800Mhz, HDMI 1.3, gigabit lan. Το κουτί ίδιο με αυτό του Α210.
Αναλυτικές προδιαγραφές σύντομα.
xrthammp
6 June 2008
495
Re: Popcorn A300
Hardware Specification
CPU Sigma Designs SMP8647, 800MHz CPU with 256KB L2 Cache
Memory 512MB DDR2 DRAM, 256MB NAND Flash
AV Outputs HDMI v1.3a, Component Video, Composite Video, Stereo Analog Audio, S/PDIF Optical, Digital Optical
Interface 2 x Host USB 2.0 (Front and Back), 1 x Slave USB 3.0
Network 10/100/1000 Mbps Gigabit Ethernet, Wireless N USB dongle (optional)
Vented Aluminum Body, Fanless, Quiet Operation
265mm (L) x 135mm (W) x 45mm (H)
Weight: 1kg
Power 12V DC, 3A Max
Gigabit Ethernet 10/100/1000mbps
3.5” SATA HDD Up to 3TB Fanless
Format Specification
Video MPEG1/2/4 Elementary (M1V, M2V, M4V), MPEG1/2 PS (M2P, MPG, DAT, VOB), MPEG2 Transport Stream (TS, TTRP, M2T, M2TS, MTS), AVI, ASF, WMV, Matroska (MKVMOV (H.264), MP4, RMP4, Real Video (RM) XVID SD/HD, MPEG-1, MPEG-2 MP@HL, MPEG-4.2 ASP@L5, 720p, 1-point GMC, MPEG-4.10 (H.264) : BP@L3, [email protected], [email protected], [email protected], WMV9 : MP@HSMPTE 421M (VC-1) : MP@HL, AP@L3,
Audio AAC, M4A, MPEG audio (MP1, MP2, MP3, MPA), WAV, WMA, FLAC, OGG, APE, TTA
Photo JPEG, BMP, PNG, GIF, TIFF
Decoder Dolby Digital, DTS, WMA, WMA Pro, MPEG-1(Layer 1,2,MPEG-4 AAC-LC, MPEG-4 HE-AAC, MPEG-4 BSAC, LPCM, FLAC, Vorbis Pass-through DTS, DTS-HD HR, DTS-HD MA, Dolby Digital, Dolby DigiPlus, Dolby True HD
Other Formats ISO, AVCHD and IFO navigation, Simple BD navigation Subtitle SRT, MicroDVD SUB, SSA, SUB/IDX, Opensubtitle
NiKa
11 June 2008
2,487
Διάβασα ότι το Sigma 8647 είναι πιο γρήγορο από εκείνο της προηγούμενης γενιάς.... θα υποστηρίζει 1000ρι....
τίποτε άλλο?? σε σχέση με ποιότητα εικόνας .. ήχου... (αλλιώς δε βλέπω λόγο για αναβάθμιση για όσους έχουν Α200/Α210)
lykman
29 June 2006
5,798
Aθήνα
Απάντηση: Re: Popcorn Hour A-300 !!!
αν έχεις και καμιά ενδεικτική τιμή... έστω και χοντρικά.
Μέσα στο μήνα λογικά θα έχουμε και από τα δύο (V8 και Α300).
τώρα να πω κάτι που με τρώει η γλώσσα μου, ή να κρατηθώ? Απλά θυμήθηκα κάποιες άλλες εταιρίες... :damnyou: -bye-
NiKa
11 June 2008
2,487
Xtr...............Xtr....... Xtr.....
Ειλικρινά δεν σε καταλαβαίνω.... :drummer:
vadergr
17 August 2007
27,463
Μεταμορφωση
Re: Απάντηση: Popcorn Hour A-300 !!!
Iδια εικονα, ιδιος ηχος.Θα ειναι λιγο πιο γρηγορο στην αποκριση (667mhz vs 800mhz).Το gigabit ευπροσδεκτο αλλα ψιλο αχρηστο απο την στιγμη που και με το 100αρι των popcorn a200/210 εκανες την ιδια δουλεια.
Και σιγα μην λειτουργησει κανεις τον εσωτερικο δισκο σαν nas με εγγραφες.Η ανωμαλια η ιδια.
Αν σκεφτειτε, και το μικρο v8 τον ιδιο επεξεργαστη εχει χωρις nmj και full blu ray.
Επειδη ξερουν οι της sigma οτι η πραγματικη νεα φουρνια ειναι η επομενη (8910 στα μεσα του 2012) ,δεν εβγαλαν φετος μια αργη και μια γρηγορη εκδοση (οι διαφορες 8646 με 8647 ειναι το macrovision) οπως με 8642/43 και πχ 8655.
Αν εχει καποιος ηδη 8642/3 media player δεν υπαρχει λογος να αναβαθμισει ...
NiKa
11 June 2008
2,487
Απάντηση: Re: Απάντηση: Popcorn Hour A-300 !!!
Άρα
α) δεν υπάρχει λόγος αναβάθμισης..
β) Παίρνει κάποιος το πιο φθηνό v8 και βάζει firmware Α300... :)
(καθόσον έχουν ίδιο chip... και τα έχει όλα... όπως γίνεται τώρα με Α200/Α210 που παίρνουν fw c200...)
-bye-
vadergr
17 August 2007
27,463
Μεταμορφωση
Re: Απάντηση: Re: Απάντηση: Popcorn Hour A-300 !!!
Άρα
-bye-
α)ουσιαστικος λογος οχι , κανενας
β)αν κανει καποιος το σπασιμο και μεταφερει το fw σαφως.Να μπορεις να βαλεις ομως το μαμα a300 στο v8 δεν θα μπορεις.
