How to configure EAC for a perfect (100%) rip
Tasos_Th
5 September 2006
3,060
Goteborg, Vastra Gotaland, SVERIGE
Το παραθέτω όπως το βρήκα παιδιά.
Dear music-lover,
Exact Audio Copy is a widely known, so called audio grabber for audio CDs using standard CD and DVD-ROM drives.
I don't take myself for an EAC expert, far from it, but there's one thing I know, what a terrible shame it is to rip a CD in "burst" instead of "secure" mode, which happens all too often nevertheless. That's why I included the subjoined article. Consider it a helping hand for those who may need it.
Amani
http://www.exactaudiocopy.de/
How to configure EAC for a perfect (100%) rip.
(written by ?topbudget? - www.hq.net)
Since we all prefer lossless formats here, rips from CD should be not just without audible artifacts but 100% identical to the original. Otherwise, there's
no sense in lossless at all. That's why I've decided to write a short 'How-To' on proper configuring of
Exact Audio Copy (EAC).
Here are settings that need to be properly configured:
EAC-> EAC options-> Extraction
[v] Fill up missing offset samples with silence
[ ] No use of null samples for CRC calculations
[v] Synchronize between tracks
[ ] Delete leading and trailing silent blocks
[v] Lock drive tray during extraction
Extraction and compression priority: [High]
Error recovery quality: [High]
EAC-> EAC Options-> Tools
[v] Retrieve UPC/ISRC codes in CUE sheet generation (only if CD-drive supports
gap Detection method A.
Enabling this option is the only way to make an exact copy.)
[v] Use CD-Text information in CUE sheet generation
[v] Automatically write status report after extraction
[ ] Activate beginner mode, disable all advanced features
EAC-> EAC Options-> Normalize
[ ] Normalize
Never ever use this option. Keep it disabled by all means!
EAC-> EAC Options-> Interface
[*] Installed external ASPI interface
- before setting up this option you should download
Nero ASPI Driver
and put it in EAC's folder
EAC-> Drive Options-> Extraction Method (!!!)
- insert in your CD drive any (unscratched) audio disc and press Detect Read Features button. If Accurate Stream was NO, then do not use this drive for audio extraction!
If Accurate Stream was detected (Yes), then set the following options this way (no matter what results were shown in Analyzing window):
[*] Secure mode with following drive features:
[v] Drive has 'Accurate Stream' feature
[v] Drive caches audio data
[ ] Drive is capable of Retrieving C2 error information
Attention: due to many confusions make sure you've adjusted your settings as it shown on the picture:
EAC-> Drive Options-> Drive
Drive read command - insert any audio CD in your drive and press Autodetect read command now button
EAC-> Drive Options-> Offset / Speed
For most exact copy of audio CD it's recommended to use read sample offset correction. To understand the importance of offset correction please read
"The Truth About Offsets" article. Proper offset correction for majority of modern drives could be found
here: http://www.accuraterip.com/driveoffsets.htm
If your drive is not in the list, you may try to determine proper offset correction yourself. Read SatCP's comprehensive gude on how to determine offsets.
(note: for most common drives EAC itself can detect offset corrections.)
[*] Use read sample offset correction
Enter determined value, otherwise leave default settings (zero).
[v] Overread into Lead-In and Lead-Out [Optional]
Use this only if your drive support this feature and if you've set custom (not default) value for read sample offset correction
[v] Allow speed reduction during extraction
EAC-> Drive Options-> Gap Detection
Gap/Index retrival method: [Detection method A]
Detection accuracy: [Secure]
- press OK to save settings and try to detect gaps of inserted audio CD: Action-> Detect Gaps (F4). If EAC seems to take forever to detect the gaps or the
detection process locks up after a few tracks, the detection method you've choosen is not optimal for your drive. Try choosing Detection method B or C.
Note that 'Detection method A' will result in most accurate rip
That's it, all set up and ready to go.
Big Grin
Based on Sergey Overkill's article.
This is a very brief How-To. For more comprehensive info please reter to
The Coaster Factory's EAC tutorial:
http://users.pandora.be/satcp/eac-qs-en.htm
Exact Audio Copy:
Trader's Little Helper:
http://thor.prohosting.com/roh0205/
supersonic
49,365
καλό αλλά θέλει πολύ διάβασμα....
θα ήθελα όμως και ένα τυφλο τεστ με 100% κοπιαρισμένα και με συμβατικά με nero ή με audio dvd-r....
10 July 2006
5,257
Απάντηση: Re: How to configure EAC for a perfect (100%) rip
Βρέξε κ@λο, φάε ψάρι! :grinning-smiley-043
Manos S.
5 September 2006
572
Χμμ.. στο καινουριο eac τα options δεν είναι έτσι ακριβώς και μου είναι δύσκολο να το ρυθμίσω,
Τάσο μήπως υπάρχουν ρυθμίσεις και για το πιο καινούριο μοντέλο ?
Τα αποτελέσματα θα ποικίλλουν, ανάλογα την κατάσταση του πρωτότυπου CD. Αν είναι σε άψογη κατάσταση, είναι πολύ πιθανό να μην ακουστούν διαφορές. Αν είναι ταλαιπωρημένο, θα ακουστούν. Έχω "σώσει" στο παρελθόν πολλά δισκάκια που δεν διαβαζόντουσαν καλά-καλά με το EAC, κάνοντας μια σωστή κόπια (αργά και βασανιστικά...).
Manos S.
5 September 2006
572
Εμένα πάλι τα πρωτότυπα cds ειναι μια χαρά, δεν μπορώ να βρω όμως πως ενεργοποιήται το freedb και επίσης πως θα γίνονται τα mp3 CBR και oxi VBR :confused:
sotos65
25 August 2007
10,620
Χανιά
EAC>freedb/Database options > freedb -> βάζεις απλά ένα email (δεν είμαι σίγουρος αν θέλει κανονικό ή μπορείς και με ψεύτικο) στο προκαθορισμένο πεδίο,
...και επίσης πως θα γίνονται τα mp3 CBR και oxi VBR :confused:
EAC>Compression options>External compression -> επιλέγεις τον επιθυμητό encoder, πχ ο LAME για τα mp3 και στο bit rate επιλέγεις κάποιο από τα προκαθορισμένα bitrate, κι όχι τα variable.
Manos S.
5 September 2006
572
Ευχαριστώ Σώτο! , αυτά τα δύο τα ρύθμισα αλλά τώρα πατάω το δεύτερο εικονίδιο στη στήλη αριστερά που λέει MP3 και αντί mp3 μου τα μετατρέπει σε wave sound format, τι να κάνω πάλι λάθος?
YannisA
22 January 2008
3,151
ΑΘΗΝΑ
απ' ότι βλέπω στη δεύτερη φωτό, είναι επιλεγμένο το LAME MP3 Encoder, αλλά από κάτω, στο "Program Including path...κλπ", δίνεται η διαδρομή προς τον FLAC encoder.
Βρές το LAME.exe, βάλτο στο ίδιο folder με το EAC και άλλαξε αυτή τη γραμμή ως εξής
C:\Program Files\Exact Audio Copy\Lame.exe
Manos S.
5 September 2006
572
Ναι στην δεύτερη φώτο του soto είναι επιλεγμένο το Flac Encoder, εμένα είναι επιλεγμένο ήδη το lame 3.98 ,
κάτι πιο απλό θα κάνω λάθος.
YannisA
22 January 2008
3,151
ΑΘΗΝΑ
στη δεύτερη φωτο, είναι επιλεγμένο το "Delete WAV after compression" ?
Αν ναί και εσύ βρίσκεις WAV αρχεία, τότε δεν φτάνει στο compression. Μήπως δεν βρίσκει το Lame ? Είναι σωστό το path που έχεις βάλει?
Επίσης τα WAV που σου βγάζει, τί ονόματα έχουν? (Κάτι τέτοιο? 0d8~34zy.wav)
Manos S.
5 September 2006
572
- Ναι είναι επιλεγμένο το "Delete WAV after compression"
- To path για το Lame είναι σωστό - το τσέκαρα,
- Τα αρχεία που βγάζει είναι ' Microsoft Wave Sound Format '
κάποια μικρολεπτομέρεια θα ξεχνάω thanks πάντως
sotos65
25 August 2007
10,620
Χανιά
Αν θέλεις μπορείς να δοκιμάσεις και την έκδοση .dll του lame αντί του εξωτερικού encoder (αν και δεν βλέπω τον λόγο που δεν σου δίνει τα mp3 αν έχεις βάλει τις ρυθμίσεις όπως λες). Βάζεις το lame_enc.dll (το βρίσκεις στο ίδιο πακέτο με το .exe εδώ) στον φάκελο root του EAC, πηγαίνεις EAC > Compression options > external compression και ξετικάρεις το "use external program for compression". Πηγαίνεις στο διπλανό tab "Waveformat" και επιλέγεις τον Lame από το "wave format", και την συμπίεση που θέλεις από το "sample format", τσεκάρεις και το "add id3 tag" (παρεμπιπτόντως και στον εξωτερικό encoder να το τσεκάρεις, διαφορετικά δεν θα γράψει id3 tags στα mp3, στη φωτό που είχα βάλει ήταν οι ρυθμίσεις για flac, και απλά είχα αλλάξει την επιλογή του encoder, sorry για το τυχόν μπέρδεμα), τσέκαρε επίσης το "Do not write wav header to file", δώσε και την επέκταση .mp3 ακριβώς από κάτω και είσαι έτοιμος (δες φωτό).
Manos S.
5 September 2006
572
Όταν χρησιμοποιώ τις αρχικές ρυθμίσεις στο compression options όπως είναι στη πρώτη φώτο φτιάχνει mp3 σε VBR
όταν πάλι χρησιμοποιώ compression options οπως μου είπες πριν (δεύτερη φώτο)
το μετατρεπει σε wave sound format
edit: αν περνούσανε και τα attachments καλά θα ήτανε
Manos S.
5 September 2006
572
To πρόβλημα είναι στο EAC->compression options-> external compression ->Additional command-line option . Αν αφήσω το παράθυράκι κενό, αντί mp3 γίνονται wav,
αν πάλι το αφήσω όπως έχει δηλ :%l-V 5%l%h-V 2%h --vbr-new %s %d
τότε γίνονται vbr... δοκίμασα να αλλάξω το vbr με cbr αλλά πάλι wav μετατρέπονται,
σκέτο μπέρδεμα είναι.
Μου φαίνεται θα αρχίσω να ριπάρω με το audiograbber γιατί με το eac δεν βγάζω άκρη
sotos65
25 August 2007
10,620
Χανιά
Μα δεν χρειάζονται πρόσθετες επιλογές στο συγκεκριμένο πεδίο, αρκεί η βασική επιλογή του bitrate, όπως επίσης να έχεις τικάρει το id3 tag ώστε να καταγραφούν κανονικά τα id3 tags στα mp3. Από τη στιγμή που βάζεις όμως στο συγκεκριμένο κάποια πρόσθετη επιλογή στην command line όπως η --vbr-new αυτομάτως του λες να κάνει τα mp3 με μεταβλητή συμπίεση vbr. Δηλαδή αν τα έχεις όπως στη φωτό σου τα κάνει wav; Το παράθυρο του lame όπως στη δεύτερη φωτό δεν εμφανίζεται σ' αυτή την περίπτωση;
ΥΓ. Το Audiograbber είναι από τα αγαπημένα μου προγράμματα ripping, το μόνο κακό ότι έχει να ανανεωθεί πάνω από 4 χρόνια...
ΥΓ2. Παρεμπιπτόντως έχεις συγκεκριμένο λόγο που τα θέλεις cbr; Νομίζω μόνο αν επιλέγεις cbr στα 320kbps έχει νόημα αυτή η επιλογή, διαφορετικά είναι καλύτερες οι επιλογές σε vbr.
Manos S.
5 September 2006
572
Ουφ επιτέλους το κατάργησα , το ξανακατέβασα και τα κανα όλα απ´την αρχή, και ναι τώρα έχω 320kbps cbr :smile: :smile:
thanks soto!
ΚΩΣΤΑΣ ΖΑΓΓΟΓΙΑΝΝΗΣ
20 October 2007
17,886
Μεσευρώπη
Eίπα να αναστήσω αυτό το νήμα για να ρωτήσω τους γνωρίζοντες. Τι καταλαβαίνετε από το ακόλουθο log ;
EAC extraction logfile from 15. February 2007, 15:22 for CD
John O'Conor / Complete Beethoven Piano Sonatas, Vol. III
Used drive : SONY CD-RW CRX216E Adapter: 1 ID: 0
Read mode : Secure with NO C2, accurate stream, disable cache
Read offset correction : 6
Overread into Lead-In and Lead-Out : No
Used output format : C:\EAC\flac.exe (User Defined Encoder)
320 kBit/s
Additional command line options : -8 -V -T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" -T "comment=EAC Secure, Lossless FLAC "
Other options :
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks : No
Native Win32 interface for Win NT & 2000
Το αρχείο είναι flac ή δεν είναι;
