OCTAGON SF-918 © model 2008
george664
11 May 2007
1,449
ΡΕΘΥΜΝΟ
HDTV High Definition reception receiver , Linux Receiver , Ethernet USB series 000 MHz - 32-bit processor ,400 MB RAM ,10 000 places (TV & Radio) ,Ethernet LAN - 10/100 Mbps ,E-SATA port ,USB 2.0 ,HDMI connector ,VFD display (Dot Matrix Vacuum Fluorescent Display) ,2 x CI slots for modules
Smart Card reader for encryption CONAX
Πολυ καλα χαρακτηριστικα και πολυ καλη τιμη 320 ευρω
george664
11 May 2007
1,449
ΡΕΘΥΜΝΟ
Octagon SF918 HDTV - Linux Kernel - LAN
Feature:
Linux Kernel
-- Image soon with all known EMUs g incl ** x, newcamd
An elegant HDTV digital satellite receiver
With LG tuner, 32-bit 1000 MHz processor and 400 MB of memory provides
OCTAGON the HD SF 918 for a strong and first-class reception.
Enjoy the HD quality with less than 1 sec switching time of the programmes.
With the Ethernet LAN connectivity, USB, eSATA and HDMI, they have the choice of agony
Over the remote controlled tuner gain (AGC value) also enables the weak channels without interference to receive this receiver was unique.
Individual color settings (brightness, contrast, color saturation) to its Sendungsart (film, news, sports, users) allow them the best image quality.
Only Arte features:
1000 MHz - 32-bit processor
400 MB RAM
E-SATA port
USB 2.0
HDMI connector
Features:
Digital Satellite Receivers MPEG 4/H.264 & DVB-S2 (DVB) compatible
Format Resolution: 576p/720p/1080i
3D user-friendly OSD menu
Clear and simple on-screen interface
Color Adjustment: color, brightness, contrast and color saturation
Bedienfreundlicher EPG (electronic program guide) for the display of program information and program preview
254 satellite programmable
Level control DiSEqC 1.0, 1.1, 1.2 and 1.3 (USALS)
LNB voltage 13/18V & 14/19V adjustable in long lines
Video format in 4:3, 16:9 and letterbox
Zoom & pause function
Recall function: storing the last 20 selected stations
Find function: stations can be found alphabetically
Program timer function
Sleep timer function
8 favourite lists for the organization of TV programmes (film, news, sports, music, children, drama, family, Misc.)
8 favourite lists for the organization of radio stations (film, news, sports, music, children, drama, family, Misc.)
Parental Controls for menu and programs
Several clear channel sorting functions such as delete, rename, move and block
Backup & restore the setting (Backup / Restore)
8 buttons on the front panel
Front buttons on / off switch
Support for Teletext and subtitle
Software - Updates on USB/RS-232 (PC-STB / STB STB)
Data transfer: receiver to receiver
Menu in 24 languages
Games menu: Sokoban, Snake, Tetris, Mines, Slot Machine, Othello
Calendar and calculator function
Automatic NTSC / PAL detection
Very fast channel search
Multi-Search: several satellites can be marked and searched
Manual input PID (audio, video and PCR)
Volume difference for each channel individually adjustable
Main background and radio background image changed
Boat image on / off
Div. Selectable menu animations: Stripe, spray, Slide, Fade
Power switch on / off
HF Modualtor
Dolby Digital 5.1 SPDIF output (optical)
2 x Scart (TV / CVR)
2 x RCA audio output (R / L)
1 x RCA video output
Following component (YUV - YPbPr)
Dimensions: 340 x 60 x 268 mm
Weight: about 2.5 kg
The remote control there in black and silver!
OCTAGON HD SF 918 HDTV bedienungsanleitung in deutsch und english
AlexT_
10,452
Επειδή είμαι της λεπτομέρειας θα πω ότι μόνο το κινέζικο τηλεκοντρολ δεν μου άρεσε.
Ολα τ' άλλα καθώς και η τιμή είναι σούπερ. Αν αποδειχτεί ότι δεν έχει τα γνωστά προβλήματα με το tuner στα DVB-S2 κανάλια τότε είναι κελεπούρι.
astanapane
21 September 2007
794
Χολαργός
Re: Απάντηση: OCTAGON SF-918 © model 2008
Έχεις απόλυτο δίκιο. Το R/C είναι απαράδεκτο.
asikamin
31 July 2006
84
γιατί πάντα οι δέκτες να είναι τόσο κιτs?
που να το βάλεις αυτό το πράμα στο ρακ!
AlexT_
10,452
Αν εννοείς το μέγεθος δεν είναι τόσο τεράστιος στην πραγματικότητα.
Αν εννοείς τον σχεδιασμό δεν σε κατάλαβα. Πως πρέπει να είναι ο δέκτης που θα μπει στο ρακ?
astanapane
21 September 2007
794
Χολαργός
Για το link πρέπει να είσαι γραμμένος στο forum :hmmmm2:
Επίσης όλο το "κόλπο" σε ένα linux δέκτη είναι τα images. Για αυτό και μέτρια "μηχανάκια" λόγω υποστήριξης βρίσκονται στην κορυφή, ενώ τα κορυφαία σε hardware πολλές φορές πατώνουν. Ο νοών νοήτω. :angry:
dingo
12 September 2007
244
Το μηχάνημα υποστηρίζει linux
αλλά δέν είναι στις άμεσες προτεραιότητες να το κάνουν
Ίσως στο μέλλον κάτι γίνει, όχι τόσο σύντομα όμως
