Opticum 9500 HD PVR 2CI2CXE Plus
john 78
Banned
29 December 2008
1,684
Επειδη ειχε υπαρξει μια συζητηση προ ημερων με τον φιλο Σουζακια περι ομοιοτητας Yumatu HD kαι Opticum 9500 HD πληροφορω απλως οτι ο Opticum 9500 HD εχει κυκλοφορησει εδω και λιγες μερες και κοστιζει περιπου 270Ε.Εδω τα τεχνικα χαρακτηριστικα του.
Main Features:
2x Card Reader slot with Con@x embedded
2x Common Interface slot for CAM modules
Ethernet supported
USB 2.0 Host support
HDMI supported
Video resolution 1080i, 720p, 576p, 576i
Software & Channel Database Transfer via USB
Blind scan
Multi-LNB Controlled by DiSEqC control Version 1.0, 1.1, 1.2 and USALS
Teletext support
Multi picture display
Powerful channel control by favorites, lock, skip, move and delete
Multi-language supported (OSD & Menu)
Optical Output for Digital Audio
General Data
System Resources
Main Processor: 400 MIPPS based CPU
Flash Memory: 8Mbytes [Optional Expand]
DDR SDRAM: 1024+512Mbits [Optional Expand]
Tuner/Channel
1tuner: Decoding
Input Connector: F-Type, Connector, Female
Loop Through: F-Type, Connector, Female
Signal Level: -65 to -25 dBm
LNB Power & Polarization:
-Vertical: +13V/+14V
- Horizontal: +18V/+19V
- Current: Max 500mA
- Overload Protection
22KHz Tone: Frequency: 22�1KHz
DiSEqC Control: Amplitude: 0,6�0,2V, Version 1.0, 1.1, 1.2, USALS Available
Demodulation: 8PSK/QPSK
Input Symbol Rate: 2-45 Mbps, Convolution Code rate 1/2, 2/3, 3/4, 5/6, 7/8 and Auto MPEG TS A/V Decoding
Transport Stream: MPEG-2/H.264
Input Data Rate: 120Mbit/s max
Aspect Ratio: 4:3, 16:9, Letter Box
Video Decoding: 1920x1080i
Video Resolution: 720x576 (PAL), 720x480 (NTSC)
Audio Decoding: MPEG-1 Layers 1/2, Dolby AC-3
Audio Mode: Left / Right / Stereo
Sampling Rate: 33KHz, 44,1KHz, 48KHz
A/V & Data Input/Output
TV-SCART: Video CVBS/RGB output, Audio L/R output
VCR SCART: Video CVBS output, Audio L/R output, Video CVBS, RGB input, Audio L/R input
RCA A/V: 1x YPbPr output, Video CVBS output, Audio 2x L/R output
S/PDIF: Optical, Coaxial Digital Audio or Dolby AC-3 Bit Stream Output
RS-232C: Transfer rate 115,2Kbps, 9 pin D-sub type
USB: USB 2.0, Compatible w/independent power supply output
HDMI: VER1.2 Type A
RF-Modulator (Optional)
PLL type: CH21~69 for the Demodulation
TV Standard: PAL BG/I/DK selectable
RF Connector: 75 Ohms, Male/Female
Frequency Range: UHF : 470~860MHz
Power Supply
Input Voltage: 100-250 VAC, 50/60Hz
Type: SMPS
Power Consumption: 30W Max.
Protection: Separate Internal Fuse and Chassis Grounding. The input shall have lighting or electric shock protection
Physical Specification
Size[W*H*D]: 360mm x 266mm x 65mm
Net Weight: 2,49 kg
Environment:
Operation Temperature: 0�C~+45C
Storage Temperature: -10�C~+70C
Storage Humidity: 5~95�RH (Non Condensing)
john 78
Banned
29 December 2008
1,684
Re: Opticum 9500 HD PVR 2CI2CXE Plus.
φωτο.....
spirosr
7 October 2008
63
ΒΥΡΩΝΑ
Στην Ελλάδα εχει κυκλοφορησει ;
john 78
Banned
29 December 2008
1,684
Nαι,βεβαια, γι αυτο ανοιξα και αυτο το καινουριο θεμα, απλως δεν συνηθιζω ποτε να δινω λινκ που οδηγουν σε σιτε καταστηματων.Να μην θεωρειται διαφημιση γιατι αλλωστε δεν κανω.....
john 78
Banned
29 December 2008
1,684
φωτο....
john 78
Banned
29 December 2008
1,684
φωτο + .....
john 78
Banned
29 December 2008
1,684
φωτο ++
john 78
Banned
29 December 2008
1,684
Απάντηση: Opticum 9500 HD PVR 2CI2CXE Plus.
Σου στελνω, αλλα προσοχη το ποστ δεν εχει καμμια σχεση με διαφημιση.Ειναι προς ενημερωση και αυξηση των επιλογων για αγορα δεκτη.
geosoho
23 March 2007
51
μπορω φιλε μου gianniko να εχω και εγω pm για το μαγαζι που πουλαει τον δεκτη? σ'ευχαριστω!
gianpanatha
16 July 2006
90
καλα ρε παιδια τοσο μυστικο ειναι, πεστε το καθαρα ποιος πουλαει το δεκτη ελεος.
john 78
Banned
29 December 2008
1,684
Λοιπον φιλε δεν περιμενα να παρει τετοια τροπη το θεμα γιατι δεν προκειται περι διαφημισης.Εχω στειλει ενα μηνυμα στον AlexT και αν αποφασισει θα γραψει κατι αυτος ως συντονιστης.
teomad
Banned
5 July 2008
1,980
λοιπον εγω λεω να παμε να κοιμηθουμε τωρα και θα συνεχισουμε αυριο
παντος αυτο το παιδι δεν νομιζω να κανει διαφιμιση γιατι
να σας τα πω και κατι καπως αλιος μακαρι να βλεπαμε και αλλες φωτογραφιες
απο αλους δεκτες αλλα Menu και να διαλεγaμε
δεν ειναι ανγκη να τσακονομαστε
τοτε κανενας απο εμας δεν θα ανεβασε φωτο με δεκτες εικονες και τετοια
θελετε να γινει αυτο το πραμα και να μιλαμε με κωδικους?
κριμα δεν ειναι
μεθαυριο που θα αγορασω ενα δεκτη και ανεβασω καμια φωτο θα με πειτε εμπορο:flipout:
ανεβαστε και εσεις τιποτα να δουμε
το ποστ δεν ειναι παραθεση σε κανεναν
καλο βραδυ
AlexT_
10,452
Για να μην υπάρχουν παρεξηγήσεις και υπόνοιες, δεδομένου ότι ο δέκτης δεν βρίσκεται εύκολα, ας γίνει η ενημέρωση με πμ.
AlexT_
10,452
gianniko, δώσε δημόσια πληροφορίες και όποιος ενδιαφέρεται ας ερευνήσει περαιτέρω..
