Elite Dream BH OE1.6 DM800 Multiboot USB 1.3 Tuner
Eki_13
2,208
Dream Elite BH 1.3 OE1.6 DM800 Multiboot Usb Tuner
WHAT IS NEW ?
Updated: Dreambox Dvb drivers: 20100414
Updated: Enigma2 CVS: Experimental 15 april 20010
New Skin: Army Class Plus HD
Fixed: Device Panel minor bugs
Included: networkbrowser, mytube, videoenhancement, autoresolution and DVDPlayer
http://www.dream-elite.net/forum/sh...-Elite-BH-1-3-OE1-6-DM800-Multiboot-Usb-Tuner
NEW NEW NEW NEW NEW NEW NEW NEW NEW NEW
Usb tuner Dvb-T native support and dedicated panel in Extra-settings.
TO BE SURE THAT YOUR USB TUNER IS SUPPRTED USE:
Hauppauge WinTV-Nova-T (HD)
Instructions to use Usb Dtt Tuner:
1) Insert your usb tuner stick
2) Goto blue -> blue -> Usb-Dvb-T Tuner Panel
3) Activate
The Usb Drivers will be Extended and Updated via Addons Manager.
Currently included Anglofsky1980 Driver Module DIB0700:
AVerMedia AVerTV DVB-T Volar
Compro Videomate U500
Uniwill STK7700P based (Hama and others)
Leadtek Winfast DTV Dongle (STK7700P based)
AVerMedia AVerTV DVB-T Express
Gigabyte U7000
Hauppauge Nova-T 500 Dual DVB-T
Pinnacle PCTV 2000e
Terratec Cinergy DT XS Diversity (Test OK)
Hauppauge Nova-TD Stick/Elgato Eye-TV Diversity (Test NOK )
ASUS My Cinema U3000 Mini DVBT Tuner
Pinnacle PCTV DVB-T Flash Stick
Artec T14BR DVB-T
ASUS My Cinema U3100 Mini DVBT Tuner (Test NOK)
Hauppauge Nova-T Stick (70019) (test OK)
Hauppauge Nova-T MyTV.t
Pinnacle PCTV Dual DVB-T Diversity Stick
Warning: DON'T INSTALL EXTERNAL DRIVERS IN THIS IMAGE OR THE USB TUNER PANEL WILL STOP TO WORK. YOU CAN INSTALL IN THIS IMAGE ONLY DEDICATED DREAM ELITE DRIVERS PACKAGES
Warning: Old plugins for OE 1.5 cannot work in OE 1.6, you have to ask to plugin authors to update. This is not an image problem. DON'T REPORT HERE FOR PLUGINS. WE ARE NOT PLUGINS AUTHORS
Warning2: THIS IMAGE HAVE THE NEW DRIVERS AND CANNOT BE INSTALLED IN MULTIBOOT USING PREVIUS IMAGES. THIS IMAGE HAVE TO BE INSTALLED IN FLASH
Warning3: AFTER IMAGE INSTALLATION GOTO DEVICES PANEL AND MAP YOUR DEVICES. REMEMBER TO INSTALL MEOBOOT ONLY AFTER YOU HAVE MAPPED YOUR DEVICES.
Warning4: ONCE YOU HAVE INSTALLED MEOBOOT DON'T MOVE DEVICE IN WICH MEOBOOT IS INSTALLED. (AS FOR EXAMPLE IF MEOBOOT IS INSTALLED ON USB DON'T REMAP THE DEVICE OF MEOBOOT ON USB2)
Warning5: YOU CAN INSTALL IN MULTIBOOT WITH THIS IMAGE ONLY IMAGES OE 1.6 WITH THE NEW KERNEL.
This image is a final Black Hole serie, to have maximum stability and performance.
We remember that black hole serie images have the best epg system available:
- Integrated Openepg for Sky-it Sky-uk Sky-Au
- Latest CVS enigma2 Epg features
- New external epg.dat system.
Therefore, each board or community can create its favourite EPG data files, and upload it to a web space. Community members can then download it from that server.
This feature offers additional benefits, such as:
EPG download increased speed
EPG download from any channel
EPG scheduled download also during standby
User set EPG Providers Add/Remove
WARNING: THIS IMAGE INCLUDE THE NEW KERNEL 2.6.18-7.3. FOR THIS REASON YOU HAVE TO INSTALL IN MULTIBOOT ONLY LATEST IMAGES BASED ON OE 1.6 WITH NEW KERNEL.
Main Function Keys
Button 1xOK = Light Info Skin
Button 2xOK = Extra Info Skin
Button Blue = Dream ELite Blue Panel
Button 1x Blue + 1x Red = Dream Elite Epg Panel
Button 1x Blue + 1x Yellow = New System Monitor Panel
Button Blue-Long-Push = Extensions
Button Green = Dream Elite Green Panel
Button Green-Long-Push = Subservices
Button 1x Green + 1x Red = CCcam Info
Button Yellow = Time Shift​
Addons
Dedicated Addons Server
Download and install additional packages from Dream Elite server​
Infobar/OSD
Enigma2 Analogic Clock
Channel Orbital Position
Advanced Tuner Info: Sr Freq Pol Fec
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
Advanced EMU information​
Dream Elite Panels features
Blue Panel
Extra Setting
Black Hole Cron Manager
OSD Settings
Devices Manager
Kernel Modules Manager
Fast Plugin Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Black Hola Mount Wizard
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel
Info
CCcam Info
Service Info
Enigma2 Settings
About
Memory
Space
CPU
Process
AutoCam
Select EMU by Channel
EPG Panel
Global setting
Provider Setting
Green Panel
CCcam info
Fast Plugin
Addons
Addons Download Manager
Manual Install Del packages
Manual Install IPK packages
Addons Uninstall Panel
Dream Elite Statistics
Scripts
Many thanks to the Beta Testers Team.
Many thanks to Rytec for all the epg servers providing precompiled Epg.dat for Dream Elite Image (add skyIta and SkyDe).
Credits
Many Thanks to Rytec for external epg
E2 Sky Epg loader integration by MaxZ4.
Many Thanks to lukkino (VDR-Italia) for opentv source code.
Many thanks to Reinh@rd for the satellites.xml file.
MANY THANKS TO ANGELOFSKY1980 FOR USB DVB-T DRIVERS
ATTENTION!
THIS IMAGE HAVE TO BE INSTALLED IN FLASH.
THIS IMAGE CANNOT WORK IN MULTIBOOT WITH DIFFERENT IMAGES IN FLASH. DREAM ELITE TEAM WILL NOT SUPPORT IMAGES NOT INSTALLED IN FLASH.
Known bugs:
Hdd temperature is not working in OE 1.6 and the result is unpredictable
Backups or other modified Images are not supported!
This Images doesn't contain any keys nor softcams.
notist
12 August 2009
593
Eki13 καλημέρα.Ξέρεις αν ο 800HD με bootloader 72 παίρνει αυτό το image,για να βάλω και το usb Terratec Cinergy DT XS Diversity,που λένε ότι παίζει οκ?Έχω μπερδευτεί με τις εκδόσεις 72 76 ΟΕ 1.6 κτλ.Ευχαριστώ πολύ.
notist
12 August 2009
593
Χαχαχα..όχι σκέφτομαι να αγοράσω.Αλλά έμαθα ότι τελικά δεν παίρνει αυτό το image με bootloader 72.Από 75 και πάνω.Ευχαριστώ πολύ.
notist
12 August 2009
593
Καλησπέρα.Τελικά αύριο παραλαμβάνω γνήσιο να έχω ήσυχο το κεφάλι μου,να περάσω αυτό το image,αλλά και όποιο βγει στην συνέχεια,και να μην έχω κανένα πρόβλημα,αν είναι από τα βάθη της Κίνας με bootloader 75 76 77 και πάει λέγοντας.
chris4
15 November 2009
110
καλημερα σε ολους ξερει κανεις αν αρχισε να λειτουργει ξανα κανονικα ο server του dream elite?(για addon,cam,settings,picons etc)
Jorgito
17 August 2006
174
Καλησπέρα σε όλους ! Ο σέρβερ τους δουλεύει κανονικά και μπορείτε να κατεβάσετε τα πάντα όχι μόνο cams...
Επίσης σας έχω ένα ευχάριστο νέο :
" Dream Elite e glieta di annunciare a breve la riapertura della Board. Con tantissime grandi novitá, a partire da nuovi Admin e moderatori. "
Σε ελεύθερη μετάφραση :
" Dream Elite announce soon the reopening of the Board. With so many great innovations, from new Admin and moderators. " :afro:
malakudi
Banned
24 April 2008
7,927
Όπως έγραψα και στο θέμα των VU+, φαίνεται πως η Dream Elite όπως την ξέραμε δεν υφίσταται πια. Έχει διασπαστεί, με κάποια γνωστά μέλη (Matrix10, AngelOfSky) να πηγαίνουν σε αποκλειστική υποστήριξη του VU+ και κάποια άλλα σε αποκλειστική συνεργασία με την Dream Multimedia (εξ' ου και το μανιφέστο κατά των κλώνων).
notist
12 August 2009
593
Μια χαρά.Ας συνεχίσουν την υποστήριξη και για τους 2,μιας και είναι από τα καλύτερα image.Ξέρουμε αν είναι και σε ποιό φόρουμ?
notist
12 August 2009
593
Καλημέρα.Θέλω να περάσω ξανά το image αυτό,γιατί δεν ξέρω τι έγινε.Πήγα να δοκιμάσω αν κατεβάζει από τον online server τους,κατέβασα lcd picon τα ενεργ/σα,και από τότε,κλασσικά πράσινη οθόνη και restart.
Επανεκ/ση δεν κάνει-----πράσινη οθόνη
Στον σκληρό δεν γράφει πράσινη οθόνη
και tuner failed από δορυφόρο σε δορυφόρο.Μόνο τα επίγεια ψηφιακά παίζει
Ξέρει κανείς αν περάσω το image αυτό ξανά,drivers από τον σέρβερ τους για το στικάκι θα έχει άραγε? Ευχαριστώ.
Υ.Γ.Ξέχασα να πω.Μπήκα μέσω του dcc έσβησα τα picon,και έστρωσε ως προς την επανεκ/ση,κάνει κανονικά,και γράφει οκ στον σκληρό.Το πρόβλημα παραμένει στο tuner failed.
NICKMAN9271
22 August 2008
358
Ηρακλειο κρητης
Re: Απάντηση: Elite Dream BH OE1.6 DM800 Multiboot USB 1.3 Tuner
γιατι δεν δοκιμαζεις το de phoenix edition , τα προβληματα που αντιμετώπιζα πχ στο diseqc , στην αναγνωριση του hdd και αρκετα random crashes λύθηκαν στον μαϊμού 800 . . . επισης τη κατασταση βελτιωσε αρκετα ειδικα στο θεμα diseqc , η αντικατασταση του τροφοδοτικου με ενα σταθεροποιημενο 12v 3Α απο το εμποριο .
notist
12 August 2009
593
Ευχαριστώ για την απάντηση σου φίλε μου.Που το βρίσκω αυτό?έχεις καμία διεύθυνση?Να σε ρωτήσω υποστηρίζει στικάκι για τα επίγεια?Ξέχασα να πω ότι έχω το crypto redi pc 50 με drivers όταν δούλευε ο σέρβερ τους,του hd volar.
Δεν μπορώ να καταλάβω τι έπαθε και τα κάνει αυτά.Στην αρχή δούλευε κανονικά και σχετικά γρήγορα,σε σχέση με τον 8000 που έχω στο σαλόνι.Επίσης να πω ότι είναι ο γνήσιος 800.Ευχαριστώ.
aggelostrom
21 October 2008
4
Προβλημα με εγκατασταση σε DM800
Προσπαθώ να βάλω το dream elite και κάθε φορά που το φλασάρω μου βγάζει ενα μήνυμα κάπως έτσι "invalid file or old version" και μετά δεν κάνει τίποτα (το ίδιο κάνει και για το newnigma) ενώ άμα βάλω gemini όλα οκ!!!
Μήπως μπορείται να με βοηθήσεται κάπως;
