Νέες τηλεοράσεις με ενσωματωμένο δορυφορικό δέκτη!!!
panosxgr
24 June 2006
8,604
Φαίνεται ότι είμαστε ακόμα στην αρχή των νέων τηλεοράσεων που πρόκειται να δούμε στο άμεσο μέλλον. Ηδη στη Μεγάλη Βρετανία κυκλοφορούν οι πρώτες LCD τηλεοράσεις, οι οποίες έχουν εκτός από αναλογικό και ψηφιακό δέκτη, δορυφορικό δέκτη καθώς και ραδιόφωνο! Τιμή: 1885 (32in)
Technisat HD-Vision 32: The multi-talented new digital high-quality television set.
32" HD-ready LCD display with multi-function tuner for all distribution paths, ready for Pay TV with CI interface.
The highlight of the HD-Vision 32 is the integrated multi-tuner for DVB-S (digital satellite reception), DVB-T (digital terrestrial television), DVB-C (digital cable television), analogue cable television, analogue terrestrial television and FM radio reception. In addition, the HD-Vision 32 features two HDMI connections (incl. HDCP), a USB 2.0 interface, a CI slot and a card reader. Also, the HD-Vision 32 complies with all technical and licensing conditions and is able to receive television programmes broadcast in accordance with the HDTV standard (HD-ready).
The HD-Vision 32 also provides a wide range of added-value services. It comes equipped with TechniSat's own, free, user-friendly electronic programme guide (EPG) "SiehFern INFO", the programme list manager ISIPRO, an automatic software update facility as well as the TechniSat installation assistant "Autoinstall", which ensures initial installation of the receiver is child's play.
Specifications
- 32" high-resolution multi-media LCD television set
- 81cm visible image
- Format: 16:9
- Resolution: 1366 x 768 (lines x rows)
- 16.7 million colours
- HD-ready
- Contrast: 1000:1
- Brightness: 500 cd/m²
- Multi-function tuner (for DVB-S, DVB-T, DVB-C, analogue cable, analogue terrestrial, FM)
- AC 3 Dolby Digital bit-stream out
- 2-way loudspeaker system with bass reflex (loudspeakers detachable)
- Free, user-friendly EPG "SiehFern INFO"
- aTHP (= advanced TechniSat Home Platform)
- Autoinstall (installation assistant)
- Automatic software update
- 2 SCART connections
- YUV connection
- S-Video connection
- 2 HDMI connections (HDCP implemented)
- USB 2.0 connection
- Common Interface (CI)
ΠΗΓΗ: http://www.sateuropa.co.uk/product_overview.asp?id=1310&catid=2&subcat=4
Λύσεις τύπου combo είναι entry level ... Αποδεδειγμένο σε πολλά άλλα πράγματα ... εχει και άλλα μεινεκτήματα , όπως εαν χαλάσει το radio tuner χάνεις ολοκληρη τηλεόραση...
Το Πλαίσιο την έχει 1549 Euro.
εδώ
στην φώτο την έχει μέ τα ηχεία τοποθετημένα κάτω, προ ημερών είχε άλλη φώτο....
ΥΓ Αν χαλάσουν ΟΛΑ τα tuner θα σου μείνει ένα μόνιτορ με δύο YUV connection και άλλα δύο 2 HDMI connections (HDCP implemented)...
...entry level είπατε;;;
