Τεχνολογιες panel TFT-LCD.
Yperion
21 June 2006
43,516
BVR (Beyond Visual Range)
Τεχνολογιες panel LCD-TFT:
TN film (Twisted Nematic)
- low manufacturing/retail costs
- restrictive viewing angles
- fast pixel response times
- dead pixels display white. Stuck pixels display RGB colors
- lower contrast levels means blacks are not as dark as VA based panels
- lower color reproduction
IPS (In Plane Switching)
- improved viewing angles over TN
- very good color reproduction
- slower pixel response times than TN
- dead pixels display black
Super-IPS (S-IPS)
- same as IPS except ...
- likely best color reproduction of all TFT
- less expensive to produce than IPS
- improved pixel response
ASV (Advanced Super View)
VA (Vertical Alignment) Technologies
MVA (Multidomain Vertical Alignment)
- compromise between TN and IPS technologies
- superior color reproduction over TN but not as good as IPS
- very good viewing angles but less than IPS
- higher contrast than TN or S-IPS means very good blacks
- dead pixels are black
- slower pixel response than TN or IPS
- details can be lost when directly viewing dark areas
Premium-MVA (P-MVA)
- same as MVA except ...
- "overdrive" technology increases pixel response but still slower than TN
- may have slightly degraded color reproduction due to "overdrive" process
PVA (Patterned VA)
- larger viewing angles
- higher contrast levels means darkest blacks
Super-PVA (S-PVA)
- same as PVA except ...
- “Magic Speed” (the Samsung equivalent to Overdrive) improves pixel response
- slightly improved color reproduction
- slightly improved viewing angles
TN - Gamers
Considered a "gamers" panel due to it's fast pixel response times which reduces trailing images know as "ghosting". However, this advantage has been reduced by new technologies to accelerate pixel response times in other panel types. Colors and contrast tend to be weak and blacks are not truly dark. Viewing angles are significantly limited. However, monitors based on this technology tend to be inexpensive.
IPS / S-IPS - Graphics Work or Web Browsing
Considered to have the best color reproduction of all panel types, these panels are well suited for graphics work or web browsing. Pixel response time is also good but slower than the TN "gamers" panel. Contast and blacks are also less dark than VA panels but viewing angles are excellent.
MVA / P-MVA / PVA / S-PVA - Compromise/combination for All-Around Use
These panels are a compromise between the fast pixel response times of the TN panel and the excellent color reproduction of the IPS panels. Contrast and blacks are best of all the panel types. Viewing angles are almost similar but slightly inferior to IPS. These details will only matter if you look for them, for average users like myself these are the best IMO.
Συνοπτικα κατα εταιρεια (με αποκλισεις αναλογα με το μοντελο):
S-IPS -> LG , Philips , Hitachi , JVC, Panasonic
S-PVA -> Samsung , Sony
ASV -> Sharp
P-MVA -> Acer , Toshiba
Links:
http://www.hardforum.com/showthread.php?t=1039222
http://www.techenclave.com/forums/tft-technology-breakdown-and-model-panel-73792.html
http://en.wikipedia.org/wiki/TFT_LCD
http://en.wikipedia.org/wiki/Liquid_crystal_display_television
http://electronics.howstuffworks.com/lcd.htm
http://www.tftcentral.co.uk/
Yperion
21 June 2006
43,516
Οπως λεει ο τιτλος ειναι διαφορες τεχνολογιες κατασκευης πανελ LCD.
Πως φαινονται τα πανελ σε μεγεθυνση:
IPS
ASV
S-PVA
PVA
Προσεξτε το κενο που αφηνουν τα pixel στο IPS πραγμα που σημαινει οχι καλο μαυρο και οτι οσο αυξανει η γωνια θεασης το μαυρο γινεται ευκολα γκρι (οποιοι εχουν Philips η LG θα εχουν παρατηρησει τα παραπανω φαινομενα).
Simos.I
22,052
Southern Coast of Tavros beach
Πολύ καλή ενημέρωση, το επόμενο που ίσως θα ρώταγα είναι σε πάνελ παίζουν π.χ
Sony, Phillips, Sharp, LG, Samsung, Toshiba, JVC, HITACHI, το ξέρω ότι θέλει ψάξιμο, ευχαριστώ.
Yperion
21 June 2006
43,516
ASV -> Sharp
P-MVA -> Acer , BenQ
Αλλοι κατασκευαστες οπως Toshiba , JVC, Panasonic , Hitachi εχουν φτιαξει την δικη τους κοινοπραξια που λεγεται IPS Alpha Technology:
http://www.hitachi-displays.com/en/news/2042325_18571.html
Ομως μερικα μοντελα οπως η Toshiba WL66 βρηκα οτι εχουν πανελ απο Ταιβαν (AU Optronics).
ΥΓ. Κυριοι διαχειριστες μηπως αυτο το thread ειναι χρησιμο να γινει sticky?-bye-
Yperion
21 June 2006
43,516
Re: Απάντηση: Re: Τεχνολογιες panel TFT-LCD.
Η παραπανω εικονα δειχνει ενα panel S-IPS. Φαινεται καθαρα πως τα χρωματα "ξεβαφουν" υπο γωνια κατι το οποιο δεν συμβαινει με αλλες τεχνολογιες (πχ. S-PVA).
Δειτε εδω για περισσοτερες πληροφοριες:
http://www.avforums.com/forums/showthread.php?t=408033
Yperion
21 June 2006
43,516
Ξαναβαζω τις φωτογραφιες γιατι φαινεται να μην λειτουργουν:
Απο αριστερα προς τα δεξια ειναι P-MVA , ΤΝ , ΙPS , PVA.
Διονύσης1
5 January 2007
1,568
Κέρκυρα
Τα ASV που φοράει η SHARP θεωρούνται καλά πάνελ ???
Και τι μειονεκτήματα έχουν σε σχέση με τα άλλα panel ??? :confused:
Για παραάδειγμα, θεωρείται καλύτερο το πάνελ μιας SHARP AQUOS από μία SONY BRAVIA ??? (Και ποιες είναι οι πρακτικές διαφορές τους ??? )
Μια ερώτηση ΠΟΛΥ χρήσιμη πιστεύω, για όσους αμφιταλαντευόμαστε ανάμεσα στις δύο αυτές μάρκες ... :grandpa:
Yperion
21 June 2006
43,516
Tα ASV ειναι πολυ καλα πανελ σε ταχυτητα (ισως τα πιο γρηγορα που υπαρχουν αυτη τη στιγμη) αλλα υστερουν σε γωνια θεασης ως προς τα S-PVA που χρησιμοποιουν οι Sony-Samsung οποτε δεν μπορουμε να τα εχουμε ολα.
Σε μια τηλεοραση παιζει μεγαλο ρολο το πανελ αλλα ακομη πιο σημαντικο ρολο παιζει ο επεξεργαστης εικονας που εχει συνηθως "πιασιαρικα" ονοματα οπως "Bravia Engine" , "Perfect Pixel" , "Active Vision" κτλ.
Για παραδειγμα η Sony (και αλλες εταιρειες) χρησιμοποιει chip της Τrident Μicro:
http://www.tridentmicro.com/Product.asp
H Sharp χρησιμοποιει chip της Micronas , oι Philips τα Nexperia που κατασκευαζει η ιδια κτλ.
Τωρα μην με ρωτησεις ποιος ειναι ο καλυτερος επεξεργαστης εικονας γιατι απαντηση δεν υπαρχει. Οι φθηνες LCD οπως ειναι λογικο εχουν μετριους ενω οι ακριβες εχουν τους πιο καλους.-bye-
Διονύσης1
5 January 2007
1,568
Κέρκυρα
Θέλει πολύ ψάξιμο το πράγμα...
Μου κάνατε την καρδιά περιβόλι τώρα! :grinning-smiley-043
Ήθελα να αγοράσω μια FULL HD στις 42'', και έλεγα για SHARP AQUOS που μεταξύ των άλλων,έχουν γωνία θέασης 178 μοίρες !!! :antlers:
Για Sony Bravia σε αυτές τις ίντζες, πάει πολύ ψηλά η καμπάνα ... :slapface:
Τι να κάνω ??? Να περιμενω να πέσουν οι τιμές, ή να προχωρήσω στην αγορά Sharp Aquos ???? :confused:
