Audiotrak Prodigy 7.1 HiFi
takisot
Μέλος Δ.Σ.
29,309
Παλλήνη
Για δειτε μια καρτουλα ηχου που παραγγειλα απο Γερμανια προκειμενου να απολαμβανω τα νεα HD φορμα ηχου:
The Prodigy 7.1 HiFi from AUDIOTRAK is based on the powerful VIA Envy24HT (ICE 1724) audio controller and the Wolfson WM8776 / 8766 audio codecs, providing 2, 4, 6 (5.1) and 8 (7.1) channel support as well as optical digital I/O with 24-bit/196kHz support.
To provide stable high level output signals, Prodigy 7.1 HiFi uses a fine selection of high quality capacitors from Sanyo (SP series) and from Nichicon (up to 2200uF RU series / Nichicon ES series) to optimise the power supply of the analog and digital components on the card and to optimise the audio output quality. The special design of Prodigy 7.1 HiFi with its 4 layer PCB cuts off electromagnetic waves from the internals of the PC – there won’t be problems with an unstable power supply caused by the systems CPU or the HDD.
A separation between the analog and the digital part using an aluminium cover that shields the sound against electromagnetic waves is a major part of the Prodigy 7.1 HiFi design. Even better, the OpAmps on the card are installed on sockets, providing the possibility to change them to the users preference.
The Prodigy 7.1 HiFi driver software is based on the EWDM standard from pro audio manufacturer ESI providing perfect compatibility with Windows 2000 / XP / 2003 and even Windows XP x64, offering high performance and low latency operation with all important famous audio applications. The DirectWIRE 3.0 and Advanced NSP (Native Sound Processing) support in the driver allows you to virtually patch all your digital audio sources internally between various different software applications running at the same time and use effect plugins simultaneously. Audio streams can be transferred between different audio applications, which is especially great when using software effects, synthesizers or virtual instruments. The driver also includes support for the 3D technologies from QSound Labs in Canada: Q3D/QEM, QMSS, QRumble, QSizzle, QExpaner, QEQ and QNormalize.
Key Features
  • 192 kHz 7.1 HiFi surround audio interface
  • 24-bit / 96 kHz ADC with 102dB(a) dynamic range
  • 24-bit / 192 kHz DAC with 108dB(a) dynamic range
  • S/PDIF digital I/O with optical connectors
  • High quality RCA connectors for the main analog output signal
  • Up to 4 simultaneous inputs and 10 simultaneous outputs
  • Special design to eliminate CPU and HDD noise
  • Supports 5.1, 7.1 and other surround formats
  • Professional EWDM driver based on ESI technology
  • DirectWIRE support to record any signal from any source internally
  • Advanced NSP support, use effect plugins to expand your sound
  • Integrated headphone and microphone amplifiers
  • ASIO 2.0 support for professional multichannel applications
  • QSound support under Windows X
  • Works under Windows 2000, XP, 2003 and XP x64
  • Compatible with all major game and surround standards
  • Compatible with all major professional audio applications
Περισσοτερα μολις την εχω στα χερια μου..
Εξαιρετική ποιότητα κατασκευής και ποιότητας ήχου, τη ζαχάρωνα αρκετό καιρό αλλα τελικά κατέληξα σε αυτή
se200pci.jpg ΟΝΚΥΟ SE-SE200PCI
υπαρχει καποιο link για να διαβασουμε για την ONKYO, γιατι μπηκα στην σελιδα της και δεν την βρηκα την καρτα
H καρτουλα εφτασε σημερα με απλο ταχυδρομειο απο Γερμανια!
Η συσκευασια πολυ προσεγμενη για αποφυγη χτυπηματων. Μεσα υπηρχε απλως η καρτα, το καλωδιο, οδηγιες και cd/drivers/programs.
H κατασκευη φαινεται ποιοτικη:
Περισσοτερα μολις την "κοτσαρω"!
Μισό να βγάλω μία ανακοίνωση για πάρτυ το βράδυ (μπας και γλυτώσουμε τις αστυνομίες) :p
Λοιπον μαζευτηκαμε χθες στου Συριου, να βαλουμε την καρτα ΜΟΥ στο HTPC TOY! :D
Η καρτουλα δουλεψε απροβληματιστα με τους μαμισιους drivers και την τεσταραμε στο 7.1 συστημα του Συριου.
Πρωτες εντυπωσεις ιδιαιτερα ενθαρυντικες!
Οταν βαλαμε το Ice Age 2 το οποιο εχει Master DTS HD, το Bitrate meter του Powedvd τρελαθηκε! Χτυπησε κατι νουμερα 20.000 με 25.000!! Επισης δεν ηταν σταθερο, οταν ειχε λιγη πληροφορια επεφτε χαμηλα και οταν ειχε πολυ χτυπουσε τα παραπανω νουμερα!
Περισσοτερα μολις το δω αποψε στο συστημα μου.
Καλησπέρα !
Αποφάσισα και εγώ να φτιάξω επιτέλους, ένα HTPC της προκοπής, και συγκεκριμένα να βάλω μέσα ό,τι ακριβώς περιέχει και το HTPC που έφτιαξαν στο τελευταίο τεύχος του περιοδικού ''Ήχος και εικόνα" (τεύχος #409 , Απρίλιος 2007, σελίδες 38-41) ! :antlers:
Σαν κάρτα ήχου λοιπόν προτείνουν την Audiotrak Prodigy 7.1, στην οποία αναφέρεται και το παρόν thread ...
Να σημειώσω ότι εκτός από τα καλά λόγια που λέτε εδώ, και το περιοδικό λέει ότι είναι πολύ καλή επίσης!
Ψάχνοντας στο review του Τάκη παραπάνω, βρήκα στα μειονεκτήματα της κάρτας τα εξής και τα αντιπαραθέτω εδώ !
Output voltage is extremely low. 0.6Vp-p or 0.3Vp. If using this card be sure to watch your wiring, it will be very easy to pick up noise at this level.
Availbility seems to be low. I think EGO ssytsm/ESI-PRO is phasing out Audiotrak but I can't confirm it. There does not seem to be any updates on drivers so don't lose your driver CD, and most of their products listed on their websites are "not available" but information is left for reference (or soemthing like the that).
Ήθελα να ρωτήσω τον Τάκη και όσους άλλους την έχουν τεστάρει από κοντά, αν όντως οι χαμηλές τάσεις από τις αναλογικές εξόδους εγκυμονούν κίνδυνο για Clipping, με αποτέλεσμα ζημιά του ενισχυτή ή των ηχείων ....
Επίσης, αν υπάρχουν drivers γισ VISTA, μιας και θα τα βάλω αν όχι τώρα, σε 2-3 μήνες ΤΟ ΠΟΛΥ στο HTPC ... :operator:
Μήπως εν τω μεταξύ υπάρχει κάποια άλλη κάρτα ήχου αυτή τη στιγμή, στα ίδια περίπου χρήματα και ποιότητα κατασκευής, με αναλογικές εξόδους και υποστήριξη Windows Vista, κατάλληλη για HTPC, ή να πάρω αυτή ??? :grandpa:
Διονυση, δεν εχουν βγει ακομα drivers για vista.
Απο την καρτα ειμαι πολυ ικανοποιημενος so far, αλλα εχει ενα μειονεκτημα: Ο driver δεν επιτρεπει bass & delay management και αναγκαζομαι να ακολουθησω περιπλοκες λυσεις για κατι που θα επρεπε να κανεις με ενα κλικ.
Για το θεμα χαμηλου output voltage κανενα προβλημα.
ΥΓ: Λογικο ειναι να την προτεινουν στον Ηχο αφου το αρθρο το εγραψα εγω παρεα με τον Ηλια τον Λαμπο! :D
