Blackmagic Design Pocket Cinema Camera 4K
What's new in Blackmagic Camera Setup 7.3​
The following models have new features.
Pocket Cinema Camera 4K, 6K and 6K Pro
Upgrades the luminance histogram to RGB histogram.
  • Adds color channel clipping indicators.
  • Adds false color guide display.
  • Adds LCD screen calibration settings.
  • Improves auto focus and active lens control.
  • Improves focus peaking visibility.
  • Fixes an issue with importing LUT’s and Presets.
Pocket Cinema Camera 4K and 6K
  • Adds support for Generation 5 color science.
  • Adds support for LCD screen dimming for power conservation.
  • Adds Q1 and Q3 Blackmagic RAW recording options.
Πολύ καλή αναβάθμιση!
Today we released Blackmagic Camera 7.3 update, which adds built in LCD calibration, giving you the ability to adjust the color temperature of your screen in the setup menu for greater confidence when monitoring on set with the Blackmagic Pocket Cinema Camera 4K, 6K and 6K Pro models. This update also adds support for an upgraded RGB histogram and color channel clipping indicators to these models, giving you even greater accuracy in reading color channels so adjustments and corrections can be made while shooting. A false color guide display is now also available, enabling monitoring of consistent exposure and brightness throughout scenes on set for faster and easier color correction in post production. Plus, there’s improved auto focus, active lens control and added support for timecode via XLR mic inputs for syncing cameras on multi camera shoots.
The new update also adds support for generation 5 color science to Blackmagic Pocket Cinema Camera 4K and 6K models, giving you the ability to capture more color data in the highlights and shadows for better looking images. LCD screen dimming in these same models has also been added, which preserves the camera’s battery life when the LCD is not in use. Additionally, when you’re working on effects heavy feature film and commercial projects and need the highest quality possible, Blackmagic RAW Q1 and Q3 constant quality recording options are now available.
Blackmagic Camera 7.3 update is available now as a free download from http://bmd.link/dJH7nA
Μολις το εκανα και στην δικια μου 4k.
Ενταξει ολα τα αλλα για εμας δεν ειναι σπουδαια αλλα το rgb luminance οπου σου δειχνει και ποιο χρωμα κλιπαρει ειναι σπουδαια προσθηκη.
Υποψιν υπαρχουν αναφορες για οσους χρησιμοποιουν τον viltrox speedbooster οτι εχασαν εντελως τον ελεγχο του διαφραγματος.....(ενα απο τα πρωτοκολλα που πειραξαν στο update ειναι και το ΑF οπου προσωπικα δεν τσεκαρα καν αν αλλαξε τιποτα καθως δεν θα γινει και Canon)
Oποτε προσεξτε καλα οσοι εχετε viltrox speedbooster ( για κατοχους metabones δεν ακουστηκε τιποτα)
Χθες το έβαλα , ξεχάστηκα κ συνέδεσα σε usb3, και στη μεση κόλλησε....
Αθάνατη bm, χωρις καρδιοχτύπι δε γίνεται..
Απ'το τίποτα καλό το RGB histogram, parade θα προτιμούσα φυσικά..
Το af με έναν ef 70-300 βελτιώθηκε νομίζω. Gen 5 χρησιμότατο. Όπως και Q1, Q3.
Ακόμα τα presets k luts ένα ένα θέλουν Εxport & Ιmport...
βάλτε ένα multiple check box...
Το focus peaking σου λειτουργεί;
Μόνο τα lines βλέπω κάνουν κάτι.
απλα, για να κανεις backup export ή import μονο ενα ενα γινεται, δε μπορεις να επιλεξεις ολα ή μερικα μαζι
Εβγαλε μολις καινουργιο firmware 3.6 για τον EF-m2II το οποιο το λεει "temporary solution" ...Μαλλον θα περιμενω να δω τι θα γραψουν οι αλλοι!!
Από ότι κατάλαβα δίνει και af λειτουργικό.
Όταν επιστρέψω Αθήνα που τον έχω αφήσει θα το δοκιμάσω.
Κλασική bmd.
Έβγαλαν update του update.... 7.3.1
Δεν υπάρχει περίπτωση να το βάλω προς το παρών, μέχρι να τελειώσω όλα τα ανοικτά projects,
το 7.3 μου χάλασε το braw studio plugin στο premiere με timecode shift k τρόμαξα να το επαναφέρω...
Παντως για την 4k που δοκιμασα σημερα το 7.3.1 δεν κανει τιποτα και δεν προχωρα σε update θεωροντας την καμερα up to date.
o γνωστος Vincent Laforet, Canon "evangelist" απο εποχής 5Δmk2, c300 κλπ
Οταν με ρωτουν τι θα κανω την 4k αν παρω την 6k pro (επειδη εχω ηδη φακους για εκεινη δεν θα δωσω ουτε πενταρα παραπανω) τους απαντω οτι δεν την δινω με τιποτα.
Το μεγεθος της σε συνδυασμο με φακους m43 (γιατι αν βαλω πανω τα μπαζουκα που εχει ο Laforet δεν εχει και καμια διαφορα) και το κοστος της ειναι μοναδικο στην αγορα.
δε ξερω αν ειδατε πλάνα απο το νεο fpv drone που σηκώνει pockets και κάνει όσο ενα osmo....
Oχι αλλα η ερωτηση ειναι την βαζεις την καμερα σου πανω σε αυτο το καρυδοτσουφλο ?
Δεν ειμαι αρνητικος αλλα ασε να την βαλει πρωτα κανας αλλος.....και το κυριοτερο ειναι τι δυνατοτητες πτησης εχεις με δαυτο....
Στο μεταξυ η εικονα ειναι $@#(&^(!^@!
Ασε που βλεπω και warp stabilizing στο βιντεο .
Και δεν θελω καν να σκεφτομαι το κοστος σε πιθανη πτωση. Μιλαμε για καμερα 1000€ συν ενας φακος πες 500€ δηλαδη πτωση και εναμιση χιλιαρικο για πεταμα ?
