Borrego™ HD Video and Digital and Analog Audio matrix switch/router
Browser
10,573
Borrego™
The Borrego matrix switch is an 8 input matrix with optionally 2, 4 or 8 outputs, designed for switching and distributing high definition video and digital and analog audio throughout the home. This allows the centralization of all video source equipment, and allows those sources to be shared throughout the home.
Features
* Component video (YPbPr)
* Left and Right analog audio
* Digital audio (SPDIF coax), doubles as composite video matrix
* Full non-blocking matrix - All outputs can display the same signal, or different signals.
* Independent audio and video switching. Digital and analog audio can be switched independently
* NeoTouch™ front panel - no moving parts to jam.
* Mutliple control options such as RS-232, USB, IR detector (front) and wired IR (rear)
* Full discrete power control functions
* Front panel lockout, Front panel blackout
* Rack mountable with optional black or silver
rack kit. (2U chassis)
* Silver chassis with choice of black or white front panel
* IR remote control included
Specifications
Power Inlet: IEC 320-C14
Input Voltage: 90-240VAC 50-60Hz, 8W typical
Dimensions: Width: 17” Height: 3.45” Depth 10.5”
(not including removable feet)
Weight: 12 lbs
Video Bandwidth: 140MHz+ (up to 1080p)
Analog Audio Bandwidth: 0 Hz to 200KHz
Digital Audio Modes: PCM, LPCM, Dolby, DTS
Digital Audio/C-Video Bandwidth: 20MHz
RS-232 (option): 9600 baud, full two way protocol
USB (option): Slave device, Windows driver included, MAC and Linux drivers available, Installs as virtual COM port at 9600 baud
Rear IR (option): 3.5mm jack for 5V or 12V blaster input, polarity insensitive
Borrego 8x2 MSRP $749
Borrego 8x4 MSRP $1299
Borrego 8x8 MSRP $2499
Optional Rack Ear Kit MSRP $25 (black or silver)
Optional Serial Comm Package (RS232+USB+Rear IR) $99
http://www.neothings.com/consumer.html
takisot
Μέλος Δ.Σ.
24,272
Παλλήνη
Ωραιο μου φαινεται για καποιον που επιθυμει HD σε ολο το σπιτι!
Και δεν ειναι και απαγορευτικη η τιμη του..
ilise
3 August 2006
3,266
Παιδια αυτο μας ερχεται απο την αλλη μερια του Ατλαντικου.
Μην ξεχνατε οτι εκει σαμποταρουν το δικο μας scart και αντ αυτου εχουν γεμισει τον τοπο με component.
vipcinemas
29 June 2006
321
Liverpool
http://www.ramelectronics.net/html/EXT-HDMI-444.htm
Matrix με HDMI.
Εγω παντως στο σπιτι εχω ενα Server με μερικα Terratecακια, ενα NAS στο δικτυο, και στις δυο κρεβατοκαμαρες εχω απο ενα HD Mediabox. Το αλλο δωματιο εχει ενα Transgear 700, και το Home Cinema ενα Crystalio II Pro (που ως γνωστον, εχει Mediabox ενσωματομενο).
HD παντου !
Προχτες το ολοκληρωσα,( δεν ειμαι και ειδικος στα δικτυα), αλλα δουλευει υπεροχα. Οσοι το ειδανε μεινανε με ανοιχτο το στομα, κυριως οταν επιλεγαμε ειδος ταινιας, και εμφανιζοτανε μια τεραστια λιστα. Ουτε να αλλαζουμε DVD...
Χαζεψανε !!
Οσον αφορα το audio, εχω κανει κατι αλλο, ωστε να μην χρειαζεται να ανοιγω την τηλεοραση, προκειμενου να επιλεξω τραγουδι ( θα ητανε ηλιθιο αλλωστε, πιστευω).
Δημητρης
