Dark side of the moon - DVD AUDIO
[email protected]
14 July 2006
24
Δεν ξέρω αν έχει ξαναγίνει αναφορά και είναι πιστεύω σημαντικό:
Α genuine transfer from the original master tapes.
Audio_TS
MLP Lossless at 24/96 Resolution in 4.1
Video_TS
DTS from 24/48 Source files
Dolby Digital from 24/48 Source files
Finally you can hear Alan Parsons mix as it was always intended to be heard in studio quality audio....
Αφιερωμένο στους θιασώτες του HTPC που δεν έχουν δυνατότητα SACD
και μια και είπα SACD, δείτε και την παρακάτω κριτική σχετικά με τη σύγκριση των δυο μίξεων:
I've compared this with the 1975 Alan Parsons quad mix, and the old quad mix simply blows aways this bastardized new age version. It suffers the same problems of most modern surroung recordings... for some reason the trend is to put the band up front, and ambience in the rear. Just a slightly expanded version of stereo, with this weird reverb-y halo around everything. I don't want to sound like a nostalgiac luddite with an "everything was better in the 70's" rap, but Parsons' 75 quad mix seriously blows this SACD away. Maybe not in terms of sparkling clarity and gloss, but in terms of active surround use in a MUSICAL way. It's truly a 3 dimensional sound experience, using the quad format to its fullest potential, and in keeping with the albums' artistic intentions. I've got a fan-made DTS disc of the quad vinyl, and urge other fans of this album to seek that out first. The mix itself becomes part of the composition, whereas this Sony SACD is just a sparkling recreation that leaves a sour taste in one's ears, especially considering Parsons' should have had the job to begin with.
Είχα αναφερθεί παλαιώτερα στο Forum για την είδηση κυκλοφορίας του σε sacd και dvd audio.
Η συγκεκριμένη δουλειά είναι και μία απο τις πιό αγαπημένες μου μουσικές επιλογές.
Το μόνο που μου μένει είναι πλέον η αγορά του.
To link που αναφέρεται πιό πάνω καλό θα ήταν να μην υπάρχει σαν παραπομπή, για ευνόητους λόγους.
Re: Απάντηση: Dark side of the moon - DVD AUDIO
Θα συμφωνισω αν και θα ηθελα να απαντησετε σε μια ερωτηση Αν καποιος εχει το
συγκεκριμενο εργο (χαζομαρα βεβαια, αλλα δεν ειναι εκει το θεμα) αγορασμενο σε CD, SACD και τουλαχιστον δις σε LP
δεν δικαιουτΑΙ και μια κοπια εστω "πειρατικη"?
ΥΓ. Το τορρεντ τι ειναι?
Φτου ρε γκίνια!!! Ολη μερα στο φορουμ, πάς σε μια συνάντηση και...:violent-smiley-030:
Βρε παιδιά μη μου λέτε τέτοια, το έχω ήδη 3 φορές (κι άλλη μία που θα το πάρω μέσα στο Pulse DVD), τώρα πρέπει να πάω και για 5η?
ΔΕΝ ΝΟΜΙΖΩ ΟΤΙ ΕΙΝΑΙ illegal ΤΟ link μιας και ΔΕΝ ΥΠΑΡΧΕΙ ΔΙΑΘΕΣΙΜΟ ΣΤΗΝ ΑΓΟΡΑ. ΑΛΛΩΣΤΕ ΣΤΑ ΠΕΡΙΕΧΟΜΕΝΑ ΤΟΥ ΔΙΣΚΟΥ ΑΝΑΦΕΡΟΝΤΑΙ ΤΑ ΕΞΗΣ:
FEEL FREE TO DISTRIBUTE THIS DISC TO OTHERS, BUT ALWAYS "AS IS" AND IN FULL.
PLEASE DO NOT RIP AND REPOST IN ANY OTHER FORMAT. THERE IS NO NEED AS ALL DVD PLAYERS CAN READ THIS DISC,
AND DOING SO WILL DEPRIVE OTHERS OF THE FULL HIGH RESOLUTION FORMATS USED.
ADDITIONALLY, RIPPING TO DTS-CD WILL INVOLVE QUALITY LOSS DUE TO DOWNSAMPLING, AND WILL
REDUCE THE LISTENING PLEASURE FOR OTHERS.
...στο avsite δε μου το έχουν σβήσει :music-smiley-005:
Οχι μωρε. Άσε να τα πάρει ο Waters 15 φορές από τον καθένα μας.
For want of the price of tea and a slice, the old man died.
dts version from different source material (they say the old SQ Quad LP's, but who knows for sure) can be found on many torrents or eBay (search dts Pink Floyd). This dts version is from the SQ LP and it has been ripped from a commercial version but is still not a legal 'commercial' release if you know what I mean.
Eιναι κοινως ενα remaster απο καποιους το οποιο δεν ειναι νομιμο μιας και δεν εχουν παρει καποια δικαιωματα.
This is NOT the usual Q8 or SQ versions with all their limitations
(limited bandwidth on the Q8, Matrixed surround on the SQ etc)
κι επαναλαμβάνω:
κι επειδή το έχω και το ακούω.....ΚΑΜΙΑ ΣΧΕΣΗ!
Απάντηση: Re: Απάντηση: Dark side of the moon - DVD AUDIO
Ελήφθη, κατανοήθη.... OVER-bye-
Ενας βασικος λογος που δεν επιτρεπεται να ποσταρετε τετοιου ειδους sources ειναι οτι το 99.9% των αρχειων που περιεχονται μεσα σε αυτα τα site ειναι παρανομα και δεν θα θελαμε να εχουμε links που να παραπεμπουν σε αυτα. Οι λογοι πιστευω ειναι κατανοητοι.
Ευχαριστω.
Απάντηση: Re: Dark side of the moon - DVD AUDIO
Προσπαθω να δημοσιεύσω το .jpg με το εξώφυλλο, αλλά δεν τα καταφέρνω.
Μηπως το μεγεθος ξεπερνα τις επιτρεπομενες διαστασεις ? Τι μεγεθος εχει το αρχειο που προσπαθεις να ανεβασεις και τι διαστασεις ?
901 kb.
Αλλά το "insert image" μου ζητά http link.
Πως το κάνω?
__Δηλαδή, μετά το καις σε dvd όπως είναι το αρχείο (όπως το κατεβάζεις) και παίζει σε DVD-A..; Χμμμ, θα μου πεις, ναι, γιατί όχι (οποιοδήποτε DVD-player κάνει)...
__Ωραία, θα ήθελα να κάνω μία μίνι κοντρίτσα με το SACD μου... ΤΗΑΝΧ gDon't ! !
EDIT:
__Επειδή η ποιότητα του εξωφύλλου δεν είναι καλή (χίλια συγνώμη), θα ήταν μια καλή ιδέα να το ανεβάσεις (στο full μεγεθός του, χωρίς resize), στο www.imageshack.us και εδώ να κάνεις post το link ή το thumbnail του (δίνει αυτή τη δυνατότητα το site που σου προτείνω). ΑΝ θέλεις και μπορείς φυσικά! Ευχαριστούμε και πάλι.
