Δέκτες Vu+: Images / Drivers
  • Αγαπητοί φίλοι και φίλες.
    Με ιδιαίτερη χαρά σας προσκαλούμε στην κοπή της πρωτοχρονιάτικης πίτας του AVClub στη Θεσσαλονίκη για το 2023 την Κυριακή 02 Απριλίου και ώρα 14.00
skskre
2 April 2013
83
Openvix 3.0 Build 600 Greek mod backup by kalemis vusolo2
Να ρωτήσω κάτι- ίσως και χαζό αλλα.... Αυτό το image όπως και άλλα "φτιαγμένα" από Greek mods μπαίνουν σε Xtrend ET4000- που δέχεται image OPEN VIX, OPEN AAF κ.τ.λ?
Ευχαριστώ
vaflas
29 April 2008
443
Λάρισα
Black Hole 2.0.3 Hyperspace
More Flash space available
Better performance
Great improvement of image quality in Solo2.
The codename of this image is a tribute to the past history of Black Hole series (one of the fastest ever images for the old dreamboxes).
Basically we have a new concept of image installation.
The Black Hole Speed Up is NOW INTEGRATED into the start wizard on the first configuration of the image after flashing and all applications can be enabled/disabled at the first boot configuration wizard.
You can choose to enable/disable features directly on first installation.
You can always access the Bh Speed Up panel later to enable/disable features.
With the package selection this way we can reduce the flash memory used and increase your box performance.
What is new:
NEW: kernel 3.3.8 (solo2)
NEW: Vuplus drivers:
- Fix deinterlacer problem (solo2, duo2)
- Support dual tuner blindscan (duo2, uno, ultimo)
- Fix SD video output problem when transcoding enabled (solo2)
- Enhance demux filtering (solo2)
- Support DTS-HD
- Add redundant interface to zapping mode
NEW: Greatly reduced image size due to the optimization of the building of larger packages.
NEW: Greatly improved image quality in Solo2 due to the new kernel and drivers
NEW: Better image performance (your Solo2 will fly).
Fixes and changes:
- Black Hole Speed Up integrated into start wizard.
- OpenWebif: install only pictures of your box (this will save even more flash space)
- [wlan] re-introduced RT3070 and RT2800USB drivers instead of the RT5572 issued driver
- Autoshutdown: plugin now defaults to inactive
- Fix tty0 > ttyS0 in populate-volatile.sh
Languages update:
- Czech
- Slovak
- French
- Greek
- hr
Warning: due to Kernel update and structural changes the Personal Backup of previous Black Hole images are not compatible with the 2.0.3 version.
makists
26 November 2010
75
Black Hole 2.0.4 Greek mod for Vu+ Solo 2 by Kalemis
Bootlogos:
Thanks to Βlack Ηole Team for very good stable image
What more installed ?
A) Greek language and EPG providers
B) 4 very good panels Black Hole , New menu , TRR Plugin & Ts panel
C) SDG Vu+ image downloader
D) 1 skin Default and MX_RedZ active
E) Greek net tv thanks to athoik
F) GST_SUBTITLE_ENCODING added for you can use more more subtitle formats than UTF-8, big thanks to athoik
G) 2 cams cccam 2.1.3 and mgcamd 1.38
E) Cool TV Guide
F) Vu+ Solo2 CI High Bitrate Fix thanks to buyukbang
G) and many Greek plugins
Here is some fotos from image
All Kalemis Greek mod images there in SDG image downloader plugin in Kalemis Greek Images
Επειδή το TRR Plugin μερά την αναβάθμιση εξαφανίστηκε, κάντε ένα κόπο να το περάσετε χειροκίνητα.
korn
27 March 2008
2,901
Satdreamgr image v4.0-O.E. 2.0 for VU+ receivers
Satdreamgr image v4.0-O.E. 2.0 for vu+ duo
Η ομάδα του Sat Dream Gr βρίσκετε στην ευχάριστη θέση να σας παρουσιάσει το νέο της O.E. 2.0 image το οποίο είναι βασισμένο στο νέο OpenPLi 4
εκτός από το image του Dreambox 800 hd που είναι βασισμένο σε OpenPLI 3
Αυτή εδώ είναι η πρώτη έκδοση και αποτελεί την βάση του νέου μας λογισμικού.
πάνω σε αυτήν θα συνεχίσουμε και με τις δικές σας προτάσεις - παρατηρήσεις πιστεύουμε πως θα το κάνουμε ακόμα καλύτερο
ο αρχικός μας στόχος είναι να φτιάξουμε ένα ελαφρύ και γρήγορο λογισμικό
το οποίο να έχει τα απολύτως απαραίτητα χωρίς να καταλαμβάνει μεγάλο χώρο μνήμης του δέκτη
έτσι ωστε ο χρήστης να μπορεί να προσθέσει ότι επιπλέον εκείνος θέλει.
Τo image θα ανανεώνεται από online αναβαθμήσεις και συχνές καινούργιες εκδόσεις
Προσθήκες που έγιναν από την ομάδα του Sat Dream Gr
-προσθήκη του Panel+ μέσα στο οποίο θα βρείτε αρκετά βασικά εργαλεία για τον δέκτη σας
αλλά και τα πρόσθετα των Ελληνικών ελεύθερων καναλιών και Ελληνικών ραδιοφώνων
-Πλήρης Ελληνική Γλώσσα στο Enigma2
-επεξεργασία του προεπιλεγμένου θεματος (skin)
-προσθήκη της διαχείρισης συσκευών (Device Manager)
-Extra Feeds
-pluginsort για να τακτοποιησετε τα προσθετα με την σειρα που εσεις θελετε
μπλε = softcam manager
πράσινο = Plugins
Ευχαριστούμε την ομάδα της OpenPLi για τον ανοιχτό βασικό κώδικα
Download SatDreamGr Images
Sat Dream Gr Τeam is pleased to present its new OE 2.0 image which is based on the new OpenPLi 4
apart from the image of the Dreambox 800 hd is based on OpenPLI 3
This here is the first edition and is the basis of our new software.
on it will continue with your own suggestions - comments we believe will do even better
our initial goal is to build a lightweight and fast software
which has the bare essentials without taking up much memory space receiver
so the user can add that extra he wants .
To image will be updated by online upgrade and frequent new editions
Additions made ​​by the Sat Dream Gr Τeam
- addition of the Panel+ in which you will find several basic tools for your receiver
and many Greek free transmission channels and radios
Full - Greek Language in Enigma2
- edit the default skin (skin)
- Add Device Manager (Device Manager)
-Extra Feeds
-Pluginsort to put plugins in the order that you want
blue = Panel+
green = Plugins
Thanks to OpenPLi for open basic code
zorro1
12 September 2010
148
μπράβο φιλε κόrn αξίζετε συγχαρητήρια.....η προσφορα σας είναι με έργα και όχι με λόγια..σαν κάποιους άλλους.
korn
27 March 2008
2,901
Ευχαριστούμε για τα καλά σου λόγια.
makists
26 November 2010
75
OpenPLi 4.0 Greek mod for Vu+ Solo 2 by Kalemis (25-10-2013)
Bootlogos:
B) 3 very good panels New menu , TRR Plugin & Ts panel
C) 2 skin, Pli-HD active and MX_RedZ
D) Greek net tv thanks to athoik
E) GST_SUBTITLE_ENCODING added for you can use more more subtitle formats than UTF-8, big thanks to athoik
F) 2 cam, cccam 2.1.3 and mgcamd 1.38c
G) Cool TV Guide
H) Vu+ Solo2 CI High Bitrate Fix thanks to buyukbang
I) Contain all the latest drivers and plugins for Solo 2
J) Many Greek plugins
Download OpenPLi 4.0 Greek mod for Vu+ Solo 2 by Kalemis
hercoulis
7 September 2008
2,388
@ makists
ανέβασε σε παρακαλώ και για τα άλλα μοντέλα, και όχι μόνο για ένα δέκτη.
makists
26 November 2010
75
Black Hole 2.0.7 Greek mod for Vu+ Solo 2 by Kalemis
Bootlogos:
D) 1 skin Default and MX_AdriaticBlue active
G) 2 cams Cccam 2.1.3 and Mgcamd 1.38c
E) Cool TV Guide
G) Latest drivers (20131023) and plugins for Solo 2
H) E2-satelltes.xml (27-10-13) by [email protected]
I) Many Greek plugins and some good things.
Download Black Hole 2.0.7 Greek mod for Vu Solo 2 by Kalemis
Black Hole 2.0.7 Greek mod for Vuplus Ultimo by Kalemis
makists
26 November 2010
75
Vti 6.0.2 Greek mod for Vuplus Ultimo by Kalemis
Bootlogos:
Thanks to Vti Team for very good stable image
B) 2 very good panels Vti , New menu
D) Greek Stream Tv thanks to athoik
E) 2 cams cccam and mgcamd
F) Vti panel black icons by ramiMAHER
G) and many Greek plugins from Satdreamgr
Download Vti 6.0.2 Greek mod for Vu+ Ultimo by Kalemis
Also ready for download from SDG image downloader for Vu+
makists
26 November 2010
75
Vti 6.0.3 Greek mod for Vuplus Solo2 by Kalemis
Bootlogos:
B) 3 very good panels Vti , New menu, Ts Panel
G) E2-satelltes.xml by [email protected]
H) many Greek plugins from Satdreamgr and some good things......
DOWNLOAD
makists
26 November 2010
75
Black Hole 2.0.8 Greek mod for Vu+ Solo 2 by Kalemis
Bootlogos:
E) Cool TV Guide
F) E2-satelltes.xml by [email protected]
G) Many Greek plugins and some very good things.
Download Black Hole 2.0.8 Greek mod for Vu Solo 2 by Kalemis
makists
26 November 2010
75
Black Hole 2.0.8.1 Greek mod for Vuplus Duo² by Kalemis
Bootlogos:
Thanks to Black Hole Team for very good stable image
A) 4 very good panels Black Hole , New menu , TRR Plugin & Ts panel
B) SDG Vu+ image downloader
C) Greek Stream Tv thanks to athoik
D) Cool tv guide
E) XBMC addons
F) 2 cams cccam and mgcamd
H) Tsmedia plugin
Download Black Hole 2.0.8.1 Greek mod for Vuplus Duo² by Kalemis
thenetpoet
Ευχαριστώ, αλλά αυτό το έχω περάσει στον vu μου κανένα χρόνο τώρα.
Δυστυχώς φαινετει δεν βγάζουν ελληνικά Mods για τον "παλιό" μας δεκτη.
Επεξεργασία:
Τελικά πέρασα την Original BH 2.0.8.
Μήπως γνωρίζετε από που μπορώ να κατεβάσω το tspanel για το image αυτό (λογικα mispel32 ?) γιατί με είχε βολεψει πολύ στην προσθήκη plugins και extensions?
Επεξεργασία 2η:
Τελικά θυμήθηκα από που το είχα κατεβάσει (tunisiasat). Γεραματα...
