τα specs
Features:
* Max sample rate - 5M/s (AUTO mode),8 bits
* Sample memory depth - 256 bytes
* Analog bandwidth - 1MHz
* Vertical sensitivity - 100mV/Div - 5V/Div
* Vertical position adjustable with indicator
* Input impedance - 1MΩ
* Max input voltage - 50Vpp
* DC/AC coupling
* Horizontal - 2μs/Div - 10m(minute)/Div
* Auto, normal and single trig modes
* Rising/falling edge trigger
* External trig available
* Trig level adjustable with indicator
* Hold/run feature
* Save up to 6 captures to EEPROM and retain after power down
* Retrieve and display saved captures
* Transfer its screen to PC as bitmap file via serial connection
* Built-in 500Hz/5Vpp test signal
* Frequency counter (only for TTL level input signal)
* 9 DC power supply
* Dimension: 110mm X 65mm X 25mm (without case)
τιμη 33$ !!!
http://www.seeedstudio.com/depot/di...scope-diy-kit-with-panels-p-515.html?cPath=11
με κολλημένα τα smd... 39$
http://www.seeedstudio.com/depot/smtexempt-digital-storage-oscilloscope-diy-kit-p-446.html?cPath=11
και για όσους βαριούνται το κόλλημα....49 $
http://www.seeedstudio.com/depot/digital-storage-oscilloscope-with-panels-p-514.html?cPath=11
Features:
* DC/AC coupling
* Hold/run feature
* 9 DC power supply
τιμη 33$ !!!
