Dune HD Pro
Status
Not open for further replies.
vadergr
17 August 2007
28,194
Μεταμορφωση
Nεο media player απο την hdi με τιμη κοντα στο χιλιαρικο!
Θα κανει τα παντα (χωρις απαραιτητα να συμφερει) και θα εχει hi grade audio components για τους μουσικοφιλους...
Hi-End Features
Hi-End power supply: high-performance large toroidal power transformer ensures a low level of interference in the power supply section and prevents possible distortions in the analog audio output, making the sound more clear and transparent, making music images articulated, precise and focused, and making the video more vivid and intense.
Hi-End audio outputs: the highest quality balanced XLR stereo outputs as well as the analog 7.1 multichannel RCA outputs, served by a high performance stereo DAC WM8741 from Wolfson Microelectronics (supports from 16 to 32 bits and sampling rates up to 192 kHz).
Balanced AES/EBU digital output: AES/EBU supporting PCM-encoded audio at 48 kHz or CD-audio at 44.1 kHz can be used to deliver digital stereo sound of the highest quality.
High-quality music playback: play very high-quality (up to 192 Khz / 24-bit) music files in various formats (FLAC, Monkey's Audio APE, WAV/PCM, DTS, etc).
Big weight: big weight of the chassis and solid body provides a low vibration level of the optical disc in the drive as well as the internal HDD, minimizing the level of the disc tremor, and allowing to read data with higher accuracy.
IR input: get more flexibility for player installation (connect an external IR eye) or connect the player to external control platforms.
RS-232 control port and 12V trigger input: even more flexibility for integration of the player with external control platforms.
PURE AUDIO button on the front panel: listen to the music directly, with video output electronics disabled, that helps to get even better audio quality.
DIMMER button on the front panel: control the brightness of the built-in display or turn it off completely.
Detachable 19" rack brackets: put the player into a standard rack mount.
Πιο πολλα εδω...
http://dune-hd.com/hd_players/current/146-hdi-dune-pro.html
Φοβάμαι πως θα μείνει όνειρο για αρκετό κόσμο (κυρίως εδώ στην Ελλάδα) καθώς ανακοινώθηκε ...
"MSRP of EUR 1990 (incl. VAT)" :bigcry:
Τώρα τελευταία μου φαίνεται πολύ καλή η αγορά ενός Dune 3.0 (είτε Base είτε Prime) !!! :a0210:
Ωχ...Με βόλευε καλύτερα το ...: "κοντά στο χιλιάρικο" ...
Με αυτή την τιμή ΑΠΟΚΛΕΙΕΤΑΙ να πιάσει τί λέμε τώρα... Με τα ίδια φλεφτά φτιάχνεις ένα HTPC τούμπανο που φτιάχνει καφέ, πάει τα παιδιά στο σχολείο, κουρεύει το γκαζόν και ψίνει και τα μπριζολίδια!!!!!
Μπορεί το 8642 να υποστηρίξει 3D και μάλιστα με HDMI 1.3?
Media Player Features
* The newest Sigma Designs 8642 media processor: enjoy excellent playback and performance of interactive features.
* Blu-ray and DVD player: play Blu-rays and DVDs (plus Audio CD and data discs with video/music/photo files).
* HDD player: connect an HDD to the player and play content directly from the HDD.
* Network player: connect the player to a local network and play content directly from PC or NAS (UPnP, SMB, NFS).
* MKV player: play HD and SD video in a popular MKV format and other modern video file formats, including top quality HD video with very high bitrate.
* RealD: watch 3D video in this ultra modern format used in cinema for the latest movies.
* HD audio: enjoy top-quality audio tracks (Dolby True HD, DTS HD Master Audio, LPCM, FLAC).
* 4 USB ports: conveniently connect HDDs, USB flash drives, USB card readers and other USB storage devices.
* HDD rack with hot swap function: easily and quickly insert and exchange internal 3.5" SATA HDD.
* SD card slot: easily play media files on SD memory cards from your camera or other devices, or use an SD memory card as a local or system storage (required for BD Live function).
* HDMI 1.3: ensure the best possible quality of HD video and HD audio.
* A rich set of standard A/V connectors: use S/PDIF optical audio, stereo audio, component video, composite video outputs to easily connect any A/V equipment.
* Extended support for Dolby True HD and DTS HD Master Audio: output bitstream (up to 7.1 channels) or decode (up to 7.1 channels) for maximum flexibility when connecting audio equipment, and for extended support of advanced playback features (such as Picture-in-Picture).
* High-quality music playback: play very high-quality (up to 192 Khz / 24-bit) music files in various formats (FLAC, Monkey’s Audio APE, WAV/PCM, DTS, etc).
* Playlists: build playlists from your folders, use your own playlists, use repeat and shuffle functions.
* Video output flexibility: output video in any resolution and format (from SD to 1080p, 24p/PAL/NTSC).
* Upscaling: high quality upscaling of DVD and any other SD video content to Full HD (1080p) or other HD resolution.
* File browser: convenient file browser with powerful file management (copy, move, delete, rename, organize, sort).
Μπράβο στη Dune. Νομίζω ότι καλύπτει ένα κενό στην αγορά. Δηλαδή την ύπαρξη ενός Hi End media player. Με κορυφαία υλικά στον ήχο , στην εικόνα στον εξοπλισμό , ποιότητα κατασκευής κλπ. Τα Χριστούγεννα θα είναι καλή περίοδος για να αποκτηθεί , μιας και θα είναι ήδη στην κυπλοφορία για 1-1,5 μήνες (με τις καθυστερήσεις) και όλες οι πρώτες απορίες θα έχουν λυθεί ή θα έχει κατασταλάξει μια πρώτη εικόνα και άποψη σχετικά με τις επιδόσεις του , τα αρνητικά και τα θετικά του γενικότερα.
Αλλά πρέπει να ρωτήσω παρά το ότι όλη η κουβέντα θα είναι θεωρητική =
1. Στον τομέα της εικόνας θα είναι καλύτερο του Dune max?
2. Το τσίπ που φοράει είναι τελευταίας γενιάς , αλλά σύντομα δε θα βγούν τα νέα τσιπάκια? Εάν ναι θα επιδέχεται αναβάθμιση?
3. Στο τομέα του ήχου στις ταινίες θα είναι καλύτερο του Dune max? (για τον ήχο στο μουσικό μέρος είναι ξεκάθαρο ότι θα είναι)
4. Γενικότερα σε τι θα είναι καλύτερο του dune max , απο πλευρας επιδόσεων και εξοπλισμού?
Ευχαριστώ
Αντε να δούμε την απάντηση των άλλων εταιριών του χώρου σε κάτι τόσο αξιόλογο , αλλιώς καλώς εχόντων των πραγμάτων θα γίνω κάτοχος του μηχανήματος πρός το τέλος της χρονιάς.
Status
