- 17 June 2006
- 10,575
[h=2]A 3LCD Reflective laser home theater projector featuring 4K Enhancement.[/h] The elite Pro Cinema LS10000 home theater projector combines revolutionary 3LCD Reflective laser projection and 4K Enhancement Technology[SUP]2[/SUP] for the ultimate movie theater experience. Immerse yourself in stunning, crystal-clear images with unbelievable detail, even close to the screen. Offering 1500 lumens of color brightness and 1500 lumens of white brightness[SUP]1[/SUP], the LS10000 also boasts an unprecedented Absolute Black contrast ratio, wider color gamut, richer colors and smoother gradations. Full HD 1080p and 4K content come alive in amazing 2D and 3D with Super Resolution and frame interpolation technologies. ISF® calibration tools ensure color accuracy. And, installation is easier and more flexible than ever.
- Experience 4K Enhancement — revolutionary 4K Enhancement Technology[SUP]2[/SUP] for unbelievable sharpness, clarity and detail
- One measurement of brightness is not enough — look for both high color brightness and high white brightness.
The Pro Cinema LS10000 has:- Color Brightness: 1500 lumens[SUP]1[/SUP]
White Brightness: 1500 lumens[SUP]1[/SUP]
- Laser light source — lamp-free design ensures high-speed contrast control and wider color gamut with rapid warm-up and cool down
- 3LCD Reflective technology — improved pixel density, increased aperture ratio and fast performance for incredibly smooth, film-like picture quality
- Absolute Black contrast ratio — together, the 3LCD Reflective system and laser light source deliver unprecedented black levels, displaying zero lumens during full-black scenes
- Full HD 1080p in 2D and 3D — Super Resolution with Detail Enhancement and frame interpolation technology deliver a stunning viewing experience; RF 3D glasses included
- Superior image quality — ISF calibration tools and THX® Display Certification ensure accurate and exceptional performance, the way filmmakers intended
- Easy installation and image adjustments — 2.1x power zoom, power focus and extraordinary lens shift (90 percent vertical, 40 percent horizontal)
- Lens position memory — store up to 10 settings in the projector memory, including zoom and focus positions for standard 16:9 or 4:3 projection areas, and 2.35:1 wide cinema ratio
- Expansive color space — get broad color reproduction with DCI and Adobe RGB modes
[h=3]Specifications[/h]
Projection System: 3LCD Reflective 3-chip technology
Projection Method: Front / rear / ceiling mount
Product Color: Black
Driving Method: Epson Poly-silicon TFT Active Matrix, 0.74-inch wide panel Reflective HTPS
Projected Output: HD, 2D, 3D, 1080p
Pixel Number: 2,073,600 dots (1920 x 1080) x 3
Color Brightness (Color Light Ouput): 1500 lumens[SUP]1[/SUP]
White Brightness (White Light Output): 1500 lumens[SUP]1[/SUP]
Aspect Ratio: 16:9 widescreen (4:3 resize) Compatible with 4:3 and 2.35:1 video formats with Normal, Full or Zoom Modes
Native Resolution: 1080p (1920 x 1080)
Resize: 16:10, 4:3
Laser Type: Laser Diode 41.9 mW (Output)
Light Source Life: Up to 30,000 hours (ECO Mode)[SUP]2[/SUP]
Throw Ratio Range: 1.28 (Zoom: Wide), 2.73 (Zoom: Tele)
Size (projected distance): 100" diagonal (wide: 9.3' – tele: 19.8')
Keystone Correction: ±30 degrees
Contrast Ratio: Absolute Black (Full White 1500 lumens / Full Black 0 lumens)
Color Reproduction: Up to 1.07 billion colors
Color Processing: 10 bit (Partial 12 bit)
[h=3]Projection Lens[/h]
Type: Powered Optical zoom/ Powered focus
F-number: 2.5 – 3.7
Focal Length: 21.3 mm – 44.7 mm
Zoom Ratio: 1.0 – 2.1
Lens Shift:
- Vertical: 90% max (up and down with horz. centered)
- Horizontal: 40% max (left and right with vertical centered)
[h=3]Other[/h]
Lens Position: the following 3 items are saved in memory: Lens Shift Position / Zoom Position / Focus Position
Memory Positions: 10 (Memory 1 – 10)
Picture-in-Picture: Yes (HDMI® only)
Display Performance: 1920 x 1080 native 1080p; HD, 2D, 3D, 2D to 3D conversion
Color Modes: Dynamic, Living room, Natural, THX, Cinema, B&W Cinema, Adobe RGB, Digital Cinema, 3D Dynamic, 3D Cinema, 3D THX
Lens Iris: Fine adjustments
Super Resolution: 4K Enhancement Off / 1 / 2 / 3 / 4 / 5 / 4K-1 / 4K-2 / 4K-3 / 4K-4 / 4K-5
Deinterlacing: Film / Auto, Video, Off
Frame Interpolation: Off / Low / Normal /High (2D and 3D Mode)
Pull Down: (1080/24p) 10:10 pull down
Epson Super White: Controlled automatically adjusting to HDMI source (Available at Natural / THX / Cinema / B&W Cinema / 3D Cinema / 3D THX, User selectable On/Off on OSD)
Input Signal: HDMI: 480i/576i/480p/576p/720p/1080i/1080p/ 4K x 2K
Terminal Outputs: (2 x) configurable as Screen Power or Anamorphic Lens - Trigger On/Off (3.5 mm mini-stereo jack) each - 12 VDC 200 mA (max.)
Computer Compatibility: PC, Mac®
Interfaces:
- HDMI x 2
- RS-232c x 1
- RCA (composite) x 1
- RCA (component) x 3
- VGA D-sub 15 pin (computer input) x 1
- Wired LAN (RJ45, 100 Mbps) for command and Control only x 1
Power Supply Voltage: 100 – 240 VAC ±10% , 50/60 Hz
Power Consumption:
- ECO mode: Laser on 267 W
- Standby mode: 0.29 W
Security: Kensington Security Lock Port
[h=3]Notes[/h]
[SUP]1[/SUP] Color brightness (color light output) and white brightness (white light output) will vary depending on usage conditions. Color light output measured in accordance with IDMS 15.4; white light output measured in accordance with ISO 21118.
[SUP]2[/SUP] 30,000 hours is the estimated projector life when used in ECO Mode. Actual hours may vary depending on usage environment. The projector comes with a three-year limited warranty, described in the warranty statement.
4K Enhancement Technology shifts each pixel diagonally by 0.5 pixels to double the resolution to 3840 x 2160 and surpass Full HD image quality. Resolution is 1920 x 1080 in 3D Mode.
www.epson.com
Review απο το projectorcentral
http://www.projectorcentral.com/epson_ls10000_projector_review.htm?em
