This weekend it is so far, we will release the new Gemini-Images!
Gemini 5.0 Images for the DM800, for the DM8000 and the first Time for the DM500HD.
Essential is the switch to the OE Version 1.6 - where is a newer Kernel used, which ie. shortens the boot time a lot. Because of this reason, we also did a version jump to 5.0.
Because till now there is no newer Kernel available for the DM7025, wi made no 5.0 for the DM7025. But no Panic, if DMM provides a newer Kernel for the 7025, we will make DM7025 images again!
New:
* Adaptions for 500HD
* Change to OE1.6, new kernel version
* FTP-Mounts - Mounts FTP-Servers as directories into the system (BP->Extras->FTP-Mount)
* new widget, animations (GIFs) in the skin
* The expert line in the infobar can be configured now
* Standby for USB-Harddisks (Attention: Doesn't work with all conrtolers)
* Device-Manager partially very strong revised
Fixes + Updates:
* Email-Checker fixed, can handle Googlemail accounts again, and no Enigma2 crash if no SSL-Connection can be done.
* The Stream-Traffic-Info should work better now on HD-Channels
* Weather
* Selectable quickbuttonfunctions extended
* see CVS
Important:
Attention on some harddisks the new kernel may cause problems.
On the DM8000 from the beta-series, a security chip update will maybe make a second boot necessary.
New:
Fixes + Updates:
* Weather
* see CVS
Important:
