- 20 May 2009
- 5,856
A Y A Z I
High Resolution 384kHz DXD DAC
OVERVIEW
The Ayazi was conceived, designed, and sonically fine-tuned by a team of audiophiles and music lovers with professional, engineering knowhow.
The aim: bring out the musical magic encoded in the numbers stored within the digital medium, and make it user-friendly and affordable.
In other words,to create a device that we,music and audiophiles alike, would wish for.
The Ayazi offers support for up to24-bit/384kHz audio via USB and 24-bit/192kHz over S/PDIF.
DSD64 and DSD128 playback is supported via USB (all via on-the-fly software conversion 352.8/24).
FEATURES
Coax and USB digital inputs,switchable from front panel
Class 2 USB input with electrostatic protection
Support for up to 32-bit/384kHz DXD audio via USB, and up to 24-bit/192kHz via Coaxial
DSD64 and DSD128 playback support on USB (via on-the-fly software conversion to 352.8/24)
Time domain jitter eliminator technology DAC chip
Low jitter, re-clocking S/PDIF input
Dedicated high speed asynchronous dual clock audio USB processor
New clocking architecture femto clock from Crystek used.
Clocking architecture pushes jitter and noise floor below perceptible levels in our circuit.
In house designed ultra low-noise power supply, custom-made transformer
High capacity main DC filter, selected audiophile series capacitors
SPECS
OUT F.SCALE
2.0V RMS
POWER
230 OR 120 V AC, 1A, 20W max
SNR
(DC to 20kHz) >112dB
ENVIR
Operating Temp 32-95 degrees F
Relative Humidity 5%-95% Non Cond.
THD N
(1kHz FS 96 kS/s) <0.002%
CROSSTALK
-110dB
Dimensions
29cm x 17cm x 8cm
USB
Transfer mode
Asynchronous (dual clock)
Device class
Type 2 or above
Bit depth
32
Sampling rates
44.1, 48, 88.2,96, 176.4, 192, 352.8, 384 kHz
SPDIF /COAXIAL
INPUT
Bit depth
24
Sampling rates
44.1, 48, 96, 192 kHz
OUTPUT
Stereo unbalanced
Impedance
250Ω
PRICE: 990
OVERVIEW
FEATURES
SPECS
OUT F.SCALE
2.0V RMS
POWER
SNR
ENVIR
THD N
CROSSTALK
-110dB
Dimensions
29cm x 17cm x 8cm
USB
Transfer mode
Device class
Type 2 or above
Bit depth
32
Sampling rates
SPDIF /COAXIAL
INPUT
Bit depth
24
Sampling rates
OUTPUT
Stereo unbalanced
Impedance
250Ω
PRICE: 990
