So, do sensors outresolve lenses? It depends on the lens you use, the properties of the light, the aperture and the format. Small format sensors may have surpassed the limit, this is, in most cases they are lens-limited in terms of resolution. It is easier to correct aberrations for a smaller light circle though, so you can approach diffraction-limited resolutions for lower f-numbers. The signal-to-noise ratio, however, imposes an inflexible limit to the effective resolution of the whole system, mostly due to photon shot noise.
