Phantom Flex
Alexandros_Wallace
3 June 2007
4,106
Dystopia
άλλη μια μηχανηματάρα ...
http://www.visionresearch.com/Products/High-Speed-Cameras/Phantom-Flex/
μεγάλο της ατού τα άπειρα καρέ:
up to 2,570 fps at 1920x1080, 5,350 fps at 1280x720, and 10,750 fps at 640x480.
Key Features
  • Up to 2,570 fps at 1920x1080 in Standard Mode
  • 12-bit pixel depth
  • ISO (ISO-12232 SAT method): 8,800 T Mono,
  • 1,200 T Color (without OLPF),
  • 1,000 T Color (with blue OLPF)
  • HQ Mode provides ultimate in image stability under changing shooting conditions
  • Phantom CineMag compatible, CineMag interface has field-replaceable pin array
  • 2 x 4:2:2 HD-SDI video ports, can be configured as dual-link 4:4:4 video (4:4:4 not available at 60fps video formats)
  • Global, electronic shutter to 1 μs (shutter angles in HQ mode dependent upon frame rate and resolution)
  • Multi-cine capable via segmented memory
  • Internal mechanical shutter for hands-free and remote Current Session References
  • On-camera controls for camera modes, settings, playback, edit & save
  • Frame synchronization to external signal, allows multiple cameras to be synchronized – essential for stereo 3D recording
  • Three 12VDC, 1.5A auxiliary power outputs for powering external devices (one is on the Viewfinder port), 4A maximum load
  • External trigger signal on camera connector panel and both 12VDC power ports
  • Genlock for synchronizing video playback – essential for 3D video workflows
Σχετικό άρθρο : Locked in a Vegas Hotel Room with a Phantom Flex
Phantom Flex 1080p ProRes file : Download Torrent
