Philips DSR 9005
STELIOS
27 August 2006
2,072
Philips DSR 9005 schwarz-silber
High Definition TV (HDTV) in 1080i Auflφsung, Kompatibel zu "HD Ready" LCDund Plasma TVs, HDMI-Ausgang, Koaxiale und optische Audio-Digital-Ausgδnge, inkl. 5-in-1 Fernbedienung, fόr Premiere geeignet, Sat-Receiver
Main Specifications
Product Description Philips DSR9005 - Satellite TV receiver
Dimensions (WxDxH) 36 cm x 22 cm x 5.5 cm
Weight 2 kg
Product Type Satellite TV receiver
Sound Output Mode Stereo
Remote Control Remote control - infrared
Timer Event Qty 8
TV Tuner 5000 channel(s)
TV System
Features Parental control, software upgrade via satellite
Programme Guide Features Programme Guide
Timer Event Qty 8
Dolby Digital Sound Capability Yes
Frequency Range 950 - 2150 MHz
TV Tuner - 5000 channel(s)
Slots
Expansion Slots Total (Free) 1 Common Interface slot
Remote Control
Type Remote control - infrared
Features Multi-brand compatibility
Connections
Connector Type 1 x HDMI - rear
1 x component video output (RCA phono x 3) - rear
2 x SCART (RGB) (21 PIN SCART) - rear
1 x audio line-out (RCA phono x 2) - rear
1 x SPDIF output (RCA phono) - rear
1 x SPDIF output (TOS Link) - rear
1 x serial (9 PIN D-Sub) - rear
1 x USB - rear
Power
Power Device Power supply - internal
Voltage Required AC 230V (50 Hz)
Power Consumption Operational 15 Watt
Power Consumption Stand by /
Sleep 1 Watt
Miscellaneous
Cables Included 1 x HDMI cable
1 x HDMI-DVI cable
General
Width 36 cm
Depth 22 cm
Height 5.5 cm
Weight 2 kg
Produkteigenschaften
Hard Disk No
Further Options DVB-S
Further Options HDTV
Further Options Premiere certified
Further Options HDMI
γνωριζετε κατι για αυτον τον HD δεκτη?
Larry
Μέλος Δ.Σ.
20,658
δυστυχως η philips Ελλας δείχνει να αγνοει την υπαρξη αυτου του μοντελου εκ τουτου μονο τα specs μπορουμε να γνωριζουμε τα οποια ειναι ακρως ικανοποιητικα
STELIOS
27 August 2006
2,072
Και εμενα τα χαρακτηριστικα του μου τραβηξαν την προσοχη μου και επισης η τιμη του οπου σε ελληνικο e-shop το εχουν στα 340 ευρω οχι ασχημα για High Definition δεκτη και με πολυ καλα reviews.
Λες να αφησω τον DB8000 και να παω για αυτό!:damnyou:
