Sideload apps σε Sony 65 xe9005
Iorgo
24 February 2010
30
Παιδιά υπάρχει καποιο οδηγός για το πώς να προσθέσω εφαρμογές στο αντροιντ της τηλεόρασης μεσω x plore?
Έχω κατεβάσει το x plrore...αλλά δεν γνωρίζω την διαδικασία.
Προσπάθησα να κατεβάσω και το es explorer αλλά όπως και να σας φαίνεται αστείο κολλάει στη αρχική οθόνη και δεν μου επιτρέπει να πατήσω το click terms and services and continue.Με πάει συνέχεια στο αναλυτικό μενού των terms όπου επίσης εκει δεν μπορώ να πατήσω κάτι.
[FAQ] How To Sideload Apps on Android TVs...https://community.sony.co.uk/t5/android-tv/faq-how-to-sideload-apps-on-android-tvs/td-p/2347365
As you may be aware, on your Android based Sony TV there is an app for Googles Play Store. This lists all the apps that have been through Googles certification program on compatibility for use on the Android TV system.
Unfortunately the quantity of apps in the Google Play TV store is rather lacking compared to the full Play Store available on your Android Smartphone or Tablet. To over-come this you can ‛sideload’ an app that is not officially certified for your Android TV. Please note that many apps simply cannot be side-loaded either for various reasons.
Listed below are 5 ways in which you can side-load these apps:
1.Installation via a computer
2.Download .apk file from PC and using ES File Explorer on TV
3.Using X-plore and Google Drive
4.Using File Commander and Google Drive
5.Using ADB commands from a PC
Note:
In order to install and run sideloaded apps, you firstly need to do two things:
Enable Unknown Sources In the Security and Restrictions menu of Settings
Install Sideload Launcher Android TV in order to run the apps you have sideloaded. This is available from Googles Play store : HERE
Some sideloaded apps have the orientation fixed to either Portrait or Landscape. You can correct this by sideloading an app called "Set Orientation"
source:[community.sony.co.uk]
-Hands-on with TV App Repo: Create a shortcut for any non-Leanback app on your Android TV...https://www.androidpolice.com/2018/...-create-shortcut-non-leanback-app-android-tv/
source:[androidpolice.com]
-Force landscape mode in Android TV Sony Bravia with some setting...https://github.com/mapillary/mapillary_issues/issues/2669...Screen.Rotation.Android.TV-7.9.apk
source:[github.com]
-Επίσης υπάρχει νήμα κατόχων ΧΕ9005 ,ρωτάτε και εκεί, και όχι στο νήμα αγορά τηλεόρασης.
