Sony KD XF9005 : Reviews - Εντυπώσεις - Σχόλια
scorpio3
6 August 2012
215
Κάποιος κάτοχος που εχει την συγκεκριμένη τηλεόραση?? Παραλαμβανω σε λίγες μέρες μετά απο μια Panasonic ET5 32'
KD-XF9005 : F.A.L.D. Direct LED LCD,VA panel (RGB-vertical stripe),
100/120Hz με MCFI + αναβόσβησμα του οπίσθιου φωτισμού,X-Motion Clarity
X1 Extreme,
WCG(aka Triluminos Display),PFS
android tv 7.0 ,upgradable to Android tv 8.0 (Oreo) ,
Screen mirroring (Miracast),Airscreen app για mirroring από iOS,PVR Ready,
HDR10,HLG,Dolby Vision,IMAX Enhanced,
DVB-T2 HD(HEVC/H.265),DVB-S2.
49",55",65",75"
Αντικαθιστά την ΧΕ9005 (2017) και η XF9005 συνεχίζει και στη σειρά του 2019,
X-Motion Clarity:combines the light-boosting potential of the FALD system and backlight blinking to achieve high motion resolution without incurring significant increase in flicker or decrease in brightness.The X-Motion Clarity system is activated when [Motionflow] is set to "Smooth", "Standard" or "Custom" with [Clearness] at "1". To curb the amount of soap opera effect (SOE) introduced to 24fps films, it's best to optimise the [Motionflow] "Custom" settings.
802485
True RGB VA-type LCD panel which delivers deep blacks by LED LCD standards. Native ANSI blacks was 0.05 cd/m2 if peak white was set at 120 cd/m2.
802615
Spectral Power of Distribution
Gradation:The [Smooth Gradation] Super Bit-Mapping feature on the Sony KD-55XF9005 works effectively to smooth out in-source posterisation.
HDR:
Peak Brightness
10% window: 1000 nits
Full-field: 685 nits
The combo of full-array local dimming (FALD) and high peak brightness results in an impactful HDR presentation.
Sony KD55XF9005/ XBR55X900F FALD Zone Count
https://www.youtube.com/watch?v=puA185PwgO8
Sony KD55XF9005/ XBR55X900F Screen Uniformity
https://www.youtube.com/watch?v=QAEM4cZbWo0
KD-55XF9005 :
-6 vertical columns x 8 horizontal rows : 48 independently dimmable zones ,
-PFS LED
-DCI-P3 colour gamut coverage : 93,9%
SoC
Platform : Sony BRAVIA ATV3
MediaTek MT5891
Core Architecture: 4x ARM Cortex-A53
CPU Cores: 4
Installed RAM : 2 GB
GPU Renderer : Mali T-860
GPU Cores : 2
Παρακάτω οι διαφορές της XG9505 σε σχέση με την XF9005:
X1 Ultimate vs X1 Extreme
X-Wide Angle 75",85",VA panel + wide angle prism filter
Better and faster operating system-new SoC (CPU,GPU,RAM)
Dolby Atmos support
New sound system-Multi Acoustic Audio (πλευρικά tweeter)
Input Lag reduced
new remote control (RMF-TX600E,Silver )
hands free Voice Control-μικρόφωνα στο λογότυπο Sony)
pre-installed Autocal app
XG9505: 4 full 4K/60 HDMI inputs
metal thinner legs ,αλλά στην XF9005 τα πόδια της βάσης μπορούν να αλλάξουν θέση το αριστερό με το δεξί και έτσι να μικρύνει το μήκος της βάσης
eARC support : yes
new action menu
Netflix calibrated mode
Airplay 2 and HomeKit compatibility will be available via firmware upgrade
Υποστήριξη KD XF900BAEP...https://www.sony.gr/electronics/support/televisions-projectors-lcd-tvs-android-/kd-55xf9005
Οδηγός βοήθειας...https://helpguide.sony.net/tv/faep1/v1/el/index.html
XBR-85X900F_cutsheet...http://www.sonypremiumhome.com/pdfs/XBR-85X900F_cutsheet_ex_view_w_assy.pdf
XBR-75X900F_cutsheet...http://www.sonypremiumhome.com/pdfs/XBR-75X900F_cutsheet_20171110.pdf
XBR-65X900F_cutsheet ...http://www.sonypremiumhome.com/pdfs/XBR-65X900F_cutsheet_20171120.pdf
XBR-55X900F_cutsheet...http://www.sonypremiumhome.com/pdfs/XBR-55X900F_cutsheet_20171120.pdf
XBR-49X900F_cutsheet...http://www.sonypremiumhome.com/pdfs/XBR-49X900F_cutsheet_20171114.pdf
-Αρχικές τιμές στην ελληνική αγορά...https://avclub.gr/forum/showthread....p-2018?p=1058090687&viewfull=1#post1058090687
KD-75XF9005 : 4.649
KD-65XF9005 : 2.599
KD-55XF9005 : 1.849
KD-49XF9005 : 1.549
Reviews - test :
65"...[flatpanelshd.com]...Sony KD65XF9005 review...https://www.flatpanelshd.com/review.php?subaction=showfull&id=1519270866
65"...[lesnumeriques.com]...Sony KD-65XF9005 test...https://avclub.gr/forum/showthread....p-2018?p=1058082393&viewfull=1#post1058082393
65"...[avmagazine.it]...Sony KD-65XF9005 review...https://avclub.gr/forum/showthread....p-2018?p=1058160626&viewfull=1#post1058160626
65"...[soundandvision.com]...Sony XBR-65X900F review...https://avclub.gr/forum/showthread....p-2018?p=1058160626&viewfull=1#post1058160626
Sony KD-55XF9005 (XF90) with X1 Extreme in the test: Better than XE90 and XE93?...https://avclub.gr/forum/showthread....p-2018?p=1058072029&viewfull=1#post1058072029
55"...[hdtvpolska.com]...Sony KD-55XF9005 test...https://avclub.gr/forum/showthread....p-2018?p=1058076641&viewfull=1#post1058076641
55"...[tvtest.pl]...Sony KD-55XF9005 - first impressions...https://avclub.gr/forum/showthread....p-2018?p=1058084684&viewfull=1#post1058084684
55XF90, η απόσταση της βάσης με τα πόδια προς τα μέσα να είναι γύρω στα 65cm.
65XF90, η απόσταση της βάσης με τα πόδια προς τα μέσα να είναι γύρω στα 75cm.
55"...[hdtvtest.co.uk]...Sony KD-55XF9005 unboxing & picture settings...https://avclub.gr/forum/showthread....p-2018?p=1058084684&viewfull=1#post1058084684
55"...[rtings.com]...Sony XBR-55X900F review...https://www.rtings.com/tv/reviews/sony/x900f
55"...[hdtvtest.co.uk]...Sony KD-55XF9005 review...https://avclub.gr/forum/showthread....p-2018?p=1058091788&viewfull=1#post1058091788
https://www.youtube.com/watch?v=HQukiYLA7LU
55"...[homecinemamagazine.nl]...Sony KD-55XF9005 review...https://avclub.gr/forum/showthread....p-2018?p=1058103845&viewfull=1#post1058103845
55"...[avforums.com]...Sony KD-55XF9005 review...https://avclub.gr/forum/showthread....p-2018?p=1058103845&viewfull=1#post1058103845
65"...[avcesar.com]...Sony KD-65XF9005 test...https://avclub.gr/forum/showthread....p-2018?p=1058141261&viewfull=1#post1058141261
55"...[tvtest.pl]...Sony KD-55XF9005 test...https://avclub.gr/forum/showthread....p-2018?p=1058141261&viewfull=1#post1058141261
55"...[referencehometheater.com]...Sony XBR-55X900F review...https://avclub.gr/forum/showthread....p-2018?p=1058160626&viewfull=1#post1058160626
55"...[altadefinizione.hdblog.it]...Sony KD-55XF9005 review...https://altadefinizione.hdblog.it/2018/11/06/sony-xf90-tv-android-dolby-vision-recensione/
μετάφραση google it to en
49"...[audiovision.de]...Sony KD-49XF9005 test...https://avclub.gr/forum/showthread....p-2018?p=1058160626&viewfull=1#post1058160626
In depth comparison review between the Sony XF90 (also marketed as the Bravia X900F in the USA), XE90 (X900E) and XE93 (X930E)...https://avclub.gr/forum/showthread....p-2018?p=1058098901&viewfull=1#post1058098901
Comparison between the Sony X900F (KD-XF90) and the Samsung QN Q8FN (Q8DN Europe models)...https://avclub.gr/forum/showthread....p-2018?p=1058172900&viewfull=1#post1058172900
Calibration settings:
Profile : Cinema Pro
Brightness:
Brightness:15
Contrast:90
Gamma:-1
Black level:50
Automatic local dimming:High
Adv contrast enhancer:Off
X-tended dynamic range:Off
Colors:
Color:50
Color balance:50
Color temperature:Expert 1
Color space:Auto
Color space:Off
Clarity:
Sharpness:50
Reality Creation:Manual
Resolution:20
Mastered in 4K:On
Random noise reduction:Off
Digital noise reduction:Off
Smooth gradation:Off
Motion:
MotionFlow: User : 3/1
Film mode:Off
Video function:
HDR mode:Auto
HDMI video:Auto
Color space:Auto
Note: We only offer calibration settings for SDR, not yet HDR. For our calibration we have not used the ambient light sensor that automatically adjusts the backlight setting according to your environment. Use this if you use your TV during the day, too
source:[flatpanelshd.com]
55"...[rtings.com]...Sony XBR-55X900F calibration settings...https://www.rtings.com/tv/reviews/sony/x900f/settings
Sony KD55XF9005 teardown...:grinning-smiley-043
https://www.youtube.com/watch?v=f36YY84yL3k
YD8S007DND01B
LMY550FF04-A ...panel from Samsung Display
source video : [yotube.com - hxos plus]
Sony XBR65X900F disassebly,total teardown,w
hat's inside?, taking apart,innenleben_180 total LEDs
https://www.youtube.com/watch?v=itahzptQWIc
source:[
Crutchfield]...
:SFGSFGSF::grinning-smiley-043
Sony KD49XF9005 teardown,disassebly
-(λειτουργία ασύρματου πληκτρολογίου και ποντικιού με USB receiver)...Με alt + tab βλέπεις τις ανοικτές εφαρμογές, όχι win key tab.
-Button Mapper: Remap your keys...https://play.google.com/store/apps/details?id=flar2.homebutton
-We show you how to disable the Samba Interactive TV notification on Sony TVs with Android Nougat 7.0 update, & also how to speed up Android TV by disabling apps & limiting the number of background processes...post #554
zisisrock0
11 January 2016
155
Καλημερα φιλε. Εχω την 49xf9005. Απλα οτι καλυτερο σε ποιοτητα εικονας στην κατηγορια της. Ενσωματωνει επεξεργαστη ανωτερης κατηγοριας της sony. Καλες θεασεις και ανεφερε εντυπωσεις για να βοηθησεις και αλλα ατομα που πιθανον να ενδιαφερονται
scorpio3
6 August 2012
215
Ευχαριστώ πολύ φιλε μου!! Πηγα στην 55αρα κ τωρα ψαχνομαι για calibration settings γιατί βλεπω οτι εχει πολλες ρυθμίσεις απο βιντεακια στο youtube....
Rtings και Hdtv βρήκα κάποιες ρυθμίσεις
zisisrock0
11 January 2016
155
Ωραια φιλε. Μιλαμε σε 4κ υλικο μενεις αφωνος ... rtings ειναι ικανοποιητικες οι ρυθμισεις
scorpio3
6 August 2012
215
Παρέλαβα μολις χθες αυτην την πανέμορφη τηλεόραση με τα πολύ δυνατά χαρακτηριστικά!!!
Εχω μείνει άφωνος με το 4k όπως ανέφερε κ ο φίλος πιο πάνω όπως επίσης κ με την ρεαλιστικοτητα της κίνησης!!
Απο επιλογές λειτουργίας οθόνης παρα πολλές αλλα έμεινα στην κανονική λειτουργία αφού μου αρέσει η έντονη αντίθεση που μου προσφέρει κ τα χρώματα..... οι ρυθμίσεις calibration στο rtings δεν με βολεψαν να πω την αλήθεια γιατι δεν μαρεσει αυτο το ζεστό χρωμα που δίνει οπως επίσης χανει κ στην αντίθεση
Το wifi στα 5ghz απίστευτο αφου μου έπαιξε 4κ υλικο χωρίς κανενα κόλλημα η κατεβασμα ανάλυσης στο netflix.
γιάννης Δ
5 May 2017
55
Πολύ καλή .. για μένα καμιά σχέση με την περσινή ΧΕ, έβλεπα να παίζει δίπλα ακριβώς στο 55αρα LG-c8, φανταστική εικόνα ... οι γνωστές διαφορές μικρές σε σχέση με την oled (απόλυτη μαύρη - και όσο μεγαλύτερη ήταν η θέαση χρωμάτων οπότε και η αγορά της, έμεινε 1400 στον Κ χωρίς 5ετή εγγύηση, στο Π 1500 με 5ετή, πιθανότατα θα περιμένω τη Μαύρη Παρασκευή .... Εσύ αν επιτρέπεται πόσο πήρατε; και αν πήρες βάση τοίχου .. από τον ήχο πως πάει;
scorpio3
6 August 2012
215
Απο Π φιλε μου σημαντικό για μένα η εγγύηση.... ο ήχος είναι εξαιρετικός ιδίως στις χαμηλές αν κ δεν μπορω να εχω εικόνα με άλλες λόγω οτι προέρχομαι και απο 32' του 2012 κ εχει πολύ διαφορά στον ήχο... σκεφτόμουν κ για soundbar αλλά μέχρι τωρα με καλύπτει απόλυτα....
edit: σε καλιμπραρισμα μετά απο αλλαγές εχω καταλήξει στα calibration settings του cinema pro που δόθηκαν πιο πάνω αφου εχει ισορροπία στα χρώματα κ στην αντίθεση..... το 4κ ειναι σοκ πραγματικά απίστευτη εικόνα κρύσταλλο οπως επίσης κ το dolby vision που σε αυτο επιθυμώ να κατεβάζω λίγο την φωτεινότητα
mclisme
4 May 2012
637
Το ρωταω και εδώ γιατί κατά λάθος το έγραψα στο άλλο νημα που είναι μεταξύ Sony XF9005 και C7:
Απο γωνίες θέασης πως είναι η Sony; Με ανησυχει λίγο που διαβαζω ότι ολες οι VA γενικά πάσχουνε και αντέχουν μεχρι 20 μοίρες το πολύ σε γωνία. Αυτό στα 2.8μ που ειναι ο καναπες μου είναι 1 μετρο αριστερα και 1 δεξιά άρα "ωφέλιμο" πλάτος 2μέτρα το οποίο ειναι σχετικά περιορισμένο. 3 άτομα ειναι οκ αλλά 4 πιστευω ειναι λίγο στο όριο. Ειμαι ετοιμος να την χτυπησω αλλά ως γνωστόν, ακριβως πριν τετοιες αποφασεις παντα σε πιανουνε δευτερες σκεψεις του στυλ "εισαι σιγουρος" και κολλας σε διαφορα...
giannisant
8 February 2018
77
Θα σου πω όχι συγκεκριμένα για την XF9005 , αλλά γενικότερα για Sony panel της τελευταίας διετίας.
Έχω IPS panel σε 55άρα περσινή Sony και δεν παλεύεται το μαύρο ή καλύτερα η ανυπαρξία μαύρου. Τη συγκρίνω ακόμα και με πολύ βασικό VA panel Sony δεκαετίας και κλαίω τα λεφτά μου.
Θεωρώ υπερβολές αυτά που λέγονται για γωνίες θέασης κλπ. Τρίχες. Όποιος νομίζει ότι θα κάτσει σε IPS panel στα πλάγια και θα απολαμβάνει εικόνα, γελιέται. Βασκά σε IPS panel δεν απολαμβάνεις εικόνα ακόμα και στην ευθεία απέναντι να κάτσεις, γιατί απλά λείπει ένα βασικό: το μαύρο και οι αποδόσεις των σκούρων αποχρώσεων.
Για μένα δεν αξίζει να ανησυχείς. Το VA panel - ως δική μου προτίμηση - είναι μονόδρομος.
7 July 2006
380
Για να σε βοηθήσω, επειδή έχουμε παρόμοια διαρρύθμιση, ο καναπές μου που είναι παράλληλα στην tv, 2,80μ απόσταση και είναι 2,35μ μήκος, δεν υπάρχει απώλεια εικόνας οπουδήποτε καθίσεις.
Ο πλάγιος από την άλλη έχει σοβαρή απώλεια.
Στάλθηκε από το ONEPLUS A3003 μου χρησιμοποιώντας Tapatalk
mclisme
4 May 2012
637
Ευχαριστω παιδιά, την τσεκαρα και στο μαγαζι απο αποψη γωνιων και μου φανηκε μια χαρα, υπερκαλυπτε το πλατος στο οποιο θα καθομαστε, πλεον εχω να ψαχτω με Ρυθμισεις!
mclisme
4 May 2012
637
Πρώτες εντυπώσεις μετά από 2 σκάρτες ημέρες από κάποιον που έρχεται από 42" Full HD LG του 2012:
1) Μέγεθος: Πιθανώς να διαφωνήσουμε με κάποιους αλλά 55" στα 2.8μ και ειδικά σε μη 4Κ περιεχομενο οριακά την αντέχει το μάτι μου (σε ορισμένες περιπτώσεις με κούρασε κιόλας) και όχι το ανάποδο που διάβαζα σε ορισμένα σχόλια, ότι με το ζόρι δηλαδή θα επαρκεί. Ευτυχώς που δεν έκανα το λάθος να παω σε 65" γιατί ειδικά στο κατάστημα η 55" φαινόταν με το ζόρι 40" και είχα αρχίσει να ανησυχώ μήπως είναι μικρή, το αντίθετο ακριβώς, αποδεικνύεται ιδανικό μέγεθος για τις διαστάσεις του σαλονιού μου.
2) Ποίοτητα σε SD και ψευτό-HD (ελληνικά δορυφορικά): Δύσκολα τα πράγματα. Έχω διαβάσει ότι κάνει εξαιρετική δουλειά σε SD υλικό και δεν εχω λόγο να διαφωνήσω γιατί είχα δει SD και σε OLED C7 και δεν ηταν καθόλου καλύτερο. Υποθέτω ότι έχει να κάνει με το γεγονός ότι η χαμηλή ανάλυση "τεντώνεται" για να γεμίσει τις 55" και έτσι οι ατέλειες φαίνονται καθαρά άρα δεν έιναι θέμα του μοντέλου συγκεκριμένα αλλά του μεγέθος. Το πρόβλημα επίσης είναι από τα απαράδεκτα "HD" σήματα που υποτίθεται μας προσφέρουν η Nova και ο ΟΤΕ.
Ένα πράγμα θα πω: Με την μετάβαση από 42" σε 55" επί της ουσίας όλα τα CosmoteSport HD και NovaSport HD μετατρέπονται σε CosmoteSport SD και NovaSportSD και δεν υπερβάλλω καθόλου. Η κατάσταση βελτιώνεται λίγο πάιζοντας με τις ρυθμίσεις εικόνας αλλά και πάλι δε θα έχεις την εικόνα που είχες με τη μικρότερη τηλεόραση η οποία έκρυβε το κακό σήμα. Σε ποδόσφαιρο στο SKY HD που τσέκαρα, το αποτέλεσμα ήταν καλύτερο και άρχιζε να θυμιζει HD άρα έχει να κανει με το σημα των ελληνικών παρόχων. Για όποιον βλέπει αποκλειστικά ή κυρίως ελληνικά κανάλια SD και HD θα συμβούλευα να στραφεί στο μικρότερο δυνατό μέγεθος που να τον καλύπτει (στην περιπτωση των 2.8μέτρων αποστασης σε μια 49").
3) UHD 4K και HDR: Εδώ επιτέλους είναι που καταλαβαίνεις για ποιό λόγο αγόρασες μια τέτοια τηλεόραση. Δεν είναι απλά "πολύ καλύτερη" η ποιότητα σε σχέση με τα HD, είναι 3 κλάσεις παραπάνω, είναι σαν να πρόκειται για διαφορετική τηλεόραση που να ήρθε από το μέλλον. Εδώ οι ρυθμίσεις επηρρεάζουν ακόμα πιο πολύ το τελικό αποτέλεσμα. Τα 2 Cinema mode της στοχεύουν σε ένα εντελώς ουδέτερο και πιο πιστό στο αρχικό χρώμα αποτέλεσμα (ειδικά το Pro) χωρίς να υπερτονίζουν τίποτα το οποίο για κάποιους είναι καλό. Το Vivid είναι απαράδεκτο και το μόνο που πετυχαίνει είναι να σε στείλει στον οφθαλμίατρο μια ώρα αρχύτερα ενώ και το Standard το παρακάνει. Πάιζοντας στο Custom, και χωρίς να είμαι ειδικός με το αντικείμενο απλά δοκιμάζοντας την επιδραση καθε ρυθμισης (και υπαρχουν παρα πολλες) στο ιδιο υλικο, έφτιαξα μία εικόνα που να βασίζεται στο Cinema Pro αλλά να δίνει και λίγη από την έξτρα ζωντάνια και την έντονη αντίθεση που βλέπεις στα demo των μαγαζιών χωρίς να φτάνει στα αστεία-ενοχλητικά-μη αληθοφανή επίπεδα του Vivid.
Στο τέλος, με αυτή τη Ρύθμιση είδα στο Netflix το 1α επεισόδια του Tales of Light και του Salt, Fat, Acid, Heat και το βίντεο: Greece in 4K
(https://youtu.be/DKwemAqzeTA
στο ΥΤ και η εικόνα ήταν σε τέτοια επίπεδα που ξέχασα ότι δεν πήρα OLED... Επίσης τότε μόνο κατάλαβα επιτέλους από που προέρχονταν τα σχόλια στις δοκιμές ότι ειδικά για LED αλλά και γενικότερα, έχει εξαιρετική ποιότητα σε HDR, πολύ έντονα μαύρα και περίσσεια λεπτομέρειας και πιστότητας. Τώρα μάλιστα.
4) Το περιβόητο Android TV για το οποίο είχα φοβηθεί τόσο πολύ: Ναι, έχει τα πάνω του και τα κάτω του. Ναι ορισμένες φορές αργεί εξαιρετικά. ΑΛΛΑ: υπάρχει μια λογική από πίσω από τη συμπεριφορά του και όποιος έχει μια ελάχιστη σχέση με υπολογιστές τουλάχιστον κατανοεί λίγο περισσότερο από που προέρχονται ορισμένες συμπεριφορές. Όταν δηλαδή stream-άρει βαρβάτο 4Κ HDR ναι, κάνει πιο πολύ ώρα να μπει στο μενού της εικόνας. Όταν μόλις έχει ανοίξει επίσης. Γενικά μοιάζει να είναι πολύ load-dependent Όσο πιο βαρια δουλειά κάνει τόσο πιο πιθανό είναι να εμφανιστεί μια καθυστέρηση στην απόκριση. Πόσο με ενοχλεί και αν ειναι λόγος για να μην προτιμήσω μια Android TV αν με καλυπτει στα υπόλοιπα; Αστεία πράγματα. Ναι θα ήθελα να μην χει καθόλου αυτά τα σκαλώματα αλλά browsing στα μενού κάνω κυρίως με τον υπολογιστή. Ειδικά μετα τον πρωτο μηνα που θα τελειωσω με το σκάλισμα, την εξερευνηση και τις Ρυθμισεις στην TV θα βάζω αυτό που θελω να δω και τέλος, δεν έχει τόση σημασία.
Συνολικά είναι μια ιδιαίτερη εμπειρία. Αυτό γιατί μου φανέρωσε με αμείλικτο τρόπο πόσο μέτρια είναι τα ελληνικά HD (υποτιθεται) και στα αθλητικά που είναι ένα μη αμελητεο κομμάτι της θέασης μου δε θα μπορω να παραβλεπω τη μετριότητα αυτή του σήματος αλλά από την άλλη μου ξεκλείδωσε μια πρωτόγνωρη ποιότητα και απόλαυση στο 4Κ περιεχόμενο. Μπορώ να πω με βεβαιότητα ότι η διαφορά στο 4Κ υλικό σε σχεση με το απλό HD είναι μεγαλύτερη από τη διαφορά που είχα παρατηρησει όταν πηρα την πρώτη Full HD μεταξύ του απλού SD και του Full HD υλικού. Δεδομένου ότι έτσι γενική τηλεόραση (δημόσια κανάλια) δε βλέπω παρα μονο ταινίες/σειρες στο Netflix και αγώνες νομίζω ότι συνολικά ήταν σωστή επιλογή η μετάβαση.
scorpio3
6 August 2012
215
Συμφωνώ σε ολα φιλε μου μεγεια!!!Πριν λίγο καιρό κάτοχος κ εγω κ με καλυψαν τέλεια οι 55 ίντσες!!! Το 4κ είναι μαγεία!!
Στο Dolby vision προσπαθώ να βρω ρυθμίσεις ιδανικές ακόμη.....εχει πολυ έντονη αντίθεση κ φωτεινότητα που πονανε τα ματια μου στα 2.5 μέτρα
Επίσης αποφευγω το xtreme dynamic range και το εχω στο off για τον λογο οτι πολλες φορές μου δίνει πολυ εντονους φωτεινούς υπότιτλους
mclisme
4 May 2012
637
Ευχαριστώ. Αν ένα πράγμα είναι ενοχλητικό πλέον (πιθανολογώ και με όλες τις σύγχρονες τηλεοράσεις) είναι αυτή η ανάγκη custom ρυθμισης όλων των δυνατών input σε SD, HD, 4K, sports, γενικό browsing. Επίσης, μόλις τα φτιαξεις πχ. στο HDMI1, πάμε πάλι από την αρχή και στο HDMI2. Και βέβαια, φέρνεις την εικόνα στα μέτρα σου σε μετάδοση HD ελληνικού αγώνα, γυρίζεις σε μετάδοση El Classico από την Ισπανία και είναι "χάλια", άντε να ρυθμίσεις άλλο προφίλ εκεί για να το φτιάξεις λίγο. Δυστυχώς, όσο μαγεία είναι το 4Κ, τόσο δεν ξεφεύγει τίποτα πλέον από τα απλά SD/HD σήματα. Υπομονή μέχρι να τα σετάρουμε όλα ελπίζω...
Ισχύει αυτό με τους υπότιλους, και μένα με κουράσανε σε κάποιες περιπτώσεις με κάποιες ρυθμίσεις. Δεν ξέρω αν οφειλόταν στο X-DR το οποίο όντως δίνει δυνατή αντίθεση ή σε κάτι άλλο. ΕΠίσης εχω παρατηρησει ότι πολλά settings είναι αλληλένδετα, δηλαδή αν ενεργοποιήσεις το Α, πρέπει να κατεβάσεις το Β ώστε να ισορροπηθεί η κατάσταση, γιαυτο λέω ότι (για μενα τουλάχιστον) θέλει κανένα μήνα ψάξιμο ακόμα (με το διαθεσιμο χρονο που έχω) μέχρι να φτάσω σε κάποια μονιμη κατάσταση. Και να σκεφτείς ότι για τη συγκεκριμένη τηλεόραση διαβάζω ότι οι out-of-the-box Ρυθμισεις ειναι αρκετά καλές! Δηλαδή σκέψου σε άλλες που δεν ειναι τι γίνεται...
Καλό θα ήταν να μοιραζόμαστε settings και προτάσεις που έχουμε δοκιμάσει ώστε να βοηθηθούμε όλοι. Αν τυχόν είχαμε και τιμές κάποιου που έκανε καλιμπράρισμα για διαφορετικά modes για μπουσουλα ακόμα καλύτερα, χωρίς να σημαίνει ότι αυτά θα είναι τα ιδανικά για τα γούστα όλων. Ακόμα δε θέλω να ανεβάσω τις δικές μου γιατί εξακολουθώ να τις αλλάζω.
greekgreek
29 June 2008
6,305
Γιαννιτσά
Σκέφτομαι να πάρω thn 55άρα από το plaisio που την έχει προσφορά 1290 ευρώ .
Σήμερα πήγα στο plaisio ,εκτός την έκπτωση , κάνουν έκπτωση 50% και στην επέκταση εγγύησης .
Δυο πράγματα με προβληματίζουν :
1)Αν μέχρι την Black Friday ,την βρω και πιο χαμηλά σε τιμή .
2)Αν μου βγάλει πρόβλημα το android ,O πωλητής στο plaisio μου έλεγε ότι κάποια στιγμή θα βγάλει και μου πρότεινε samsung .
mclisme
4 May 2012
637
Re: Απάντηση: Sony KD XF9005 : Reviews - Εντυπώσεις - Σχόλια
Εγω θα έλεγα να περιμενεις BF. Ο λόγος που βιαστηκα εγώ είναι ότι εδώ Σουηδία την έβρισκα 1000ευρω, πιο χαμηλά και απο την 49άρα (!) και ειχα παρατηρησει ότι προσφατα, εκτός από το καταστημα που την πηρα, ανεβασανε τις τιμες παλι στα 1300 για να ξανακανουνε τεχνητη εκτπωση στα 1100 λογικα οπότε σκεφτηκα ότι δε θα βρω κατι καλυτερο από 1000 ευρω που την πήρα τελικά. Πάντως το υλικό που έδειχνε στο μαγαζί η δικιά μου ήταν αστείας ποιότητας και την αδικούσε πάρα πολύ. Πήγα στα τυφλά εμπιστευόμενος τα reviews και ευτυχως δεν έπεσα έξω.
Αν σου είπε σοβαρά πωλητής ότι "το Android θα βγάλει πρόβλημα" μίλα με άλλον καλύτερα. Ότι δεν είναι το γρηγορότερο μενού ναι, ότι κάποιες φορές τρώει κολλήματα ναι, αλλά ότι θα βγάλει πρόβλημα το λειτουργικό ακούγεται αστείο. Προσωπικά μου αρέσει κιόλας γιατί ως χρηστης Android χρόνια το γνωρίζω καλά και έχω ήδη περάσει εφαρμογές που κανονικά δεν διατίθενται στο store...
greekgreek
29 June 2008
6,305
Γιαννιτσά
Απάντηση: Re: Απάντηση: Sony KD XF9005 : Reviews - Εντυπώσεις - Σχόλια
Για να μην αδικήσω τον πωλητή ,μου είπε για κολλήματα .
Δεν ξέρω αν είναι απλά κολληματάκια ή είναι πιο σοβαρό ,για αυτό μίλησα για πρόβλημα .
mclisme
4 May 2012
637
Re: Απάντηση: Re: Απάντηση: Sony KD XF9005 : Reviews - Εντυπώσεις - Σχόλια
Τι να βγάλει δηλαδή σιγά μην έχει και ημερομηνία αυτοκαταστροφής. Τραβάς ένα Factory reset στη χειρότερη και είσαι όπως στην αρχή. Δεν το λέω ειρωνικά αλλά από απορία του τι μπορεί να εννοούσε που να ηταν τόσο σοβαρό. Για μένα όπως ξαναείπα, Android σημαίνει ευελιξία και ρυθμισιμότητα που δεν έχω σε άλλα λειτουργικά. Δε νομίζω ότι σε καμία τηλεόραση πάντως το λειτουργικό ειναι παράγοντας επιλογής η αποφυγής.
boymanos
23 February 2012
384
μακρυα απο samsung, καλυτερα sony.
fotis1976
6 February 2014
803
Χανιά
το ανδροιδ είναι softwear, τι προβλημα να σου βγάλει δηλαδή;Ο πωλητής στάνταρ ήθελε να σπρώξει samsung. Εσυ αποφάσισε όπως νομίζεις αλλά πρωτα αφαίρεσε από την εξίσωση το (ανδροιδ= πιθανό πρόβλημα).
