- 6 August 2012
- 264
Κάποιος κάτοχος που εχει την συγκεκριμένη τηλεόραση?? Παραλαμβανω σε λίγες μέρες μετά απο μια Panasonic ET5 32'
KD-XF9005 : F.A.L.D. Direct LED LCD,VA panel (RGB-vertical stripe),
100/120Hz με MCFI + αναβόσβησμα του οπίσθιου φωτισμού,X-Motion Clarity
X1 Extreme,
WCG(aka Triluminos Display),PFS
android tv 7.0 ,upgradable to Android tv 8.0 (Oreo) ,
Screen mirroring (Miracast),Airscreen app για mirroring από iOS,PVR Ready,
HDR10,HLG,Dolby Vision,IMAX Enhanced,
DVB-T2 HD(HEVC/H.265),DVB-S2.
49",55",65",75"
Αντικαθιστά την ΧΕ9005 (2017) και η XF9005 συνεχίζει και στη σειρά του 2019,
X-Motion Clarity:combines the light-boosting potential of the FALD system and backlight blinking to achieve high motion resolution without incurring significant increase in flicker or decrease in brightness.The X-Motion Clarity system is activated when [Motionflow] is set to "Smooth", "Standard" or "Custom" with [Clearness] at "1". To curb the amount of soap opera effect (SOE) introduced to 24fps films, it's best to optimise the [Motionflow] "Custom" settings.
True RGB VA-type LCD panel which delivers deep blacks by LED LCD standards. Native ANSI blacks was 0.05 cd/m2 if peak white was set at 120 cd/m2.
Spectral Power of Distribution
Gradation:The [Smooth Gradation] Super Bit-Mapping feature on the Sony KD-55XF9005 works effectively to smooth out in-source posterisation.
HDR:
Peak Brightness
10% window: 1000 nits
Full-field: 685 nits
The combo of full-array local dimming (FALD) and high peak brightness results in an impactful HDR presentation.
Sony KD55XF9005/ XBR55X900F FALD Zone Count
Sony KD55XF9005/ XBR55X900F Screen Uniformity
KD-55XF9005 :
-6 vertical columns x 8 horizontal rows : 48 independently dimmable zones ,
-PFS LED
-DCI-P3 colour gamut coverage : 93,9%
SoC
Platform : Sony BRAVIA ATV3
MediaTek MT5891
Core Architecture: 4x ARM Cortex-A53
CPU Cores: 4
Installed RAM : 2 GB
GPU Renderer : Mali T-860
GPU Cores : 2
Παρακάτω οι διαφορές της XG9505 σε σχέση με την XF9005:
X1 Ultimate vs X1 Extreme
X-Wide Angle 75",85",VA panel + wide angle prism filter
Better and faster operating system-new SoC (CPU,GPU,RAM)
Dolby Atmos support
New sound system-Multi Acoustic Audio (πλευρικά tweeter)
Input Lag reduced
new remote control (RMF-TX600E,Silver )
hands free Voice Control-μικρόφωνα στο λογότυπο Sony)
pre-installed Autocal app
XG9505: 4 full 4K/60 HDMI inputs
metal thinner legs ,αλλά στην XF9005 τα πόδια της βάσης μπορούν να αλλάξουν θέση το αριστερό με το δεξί και έτσι να μικρύνει το μήκος της βάσης
eARC support : yes
new action menu
Netflix calibrated mode
Airplay 2 and HomeKit compatibility will be available via firmware upgrade
Υποστήριξη KD XF900BAEP...https://www.sony.gr/electronics/support/televisions-projectors-lcd-tvs-android-/kd-55xf9005
Οδηγός βοήθειας...https://helpguide.sony.net/tv/faep1/v1/el/index.html
XBR-85X900F_cutsheet...http://www.sonypremiumhome.com/pdfs/XBR-85X900F_cutsheet_ex_view_w_assy.pdf
XBR-75X900F_cutsheet...http://www.sonypremiumhome.com/pdfs/XBR-75X900F_cutsheet_20171110.pdf
XBR-65X900F_cutsheet ...http://www.sonypremiumhome.com/pdfs/XBR-65X900F_cutsheet_20171120.pdf
XBR-55X900F_cutsheet...http://www.sonypremiumhome.com/pdfs/XBR-55X900F_cutsheet_20171120.pdf
XBR-49X900F_cutsheet...http://www.sonypremiumhome.com/pdfs/XBR-49X900F_cutsheet_20171114.pdf
-Αρχικές τιμές στην ελληνική αγορά...https://avclub.gr/forum/showthread....p-2018?p=1058090687&viewfull=1#post1058090687
KD-75XF9005 : 4.649
KD-65XF9005 : 2.599
KD-55XF9005 : 1.849
KD-49XF9005 : 1.549
Reviews - test :
65"...[flatpanelshd.com]...Sony KD65XF9005 review...https://www.flatpanelshd.com/review.php?subaction=showfull&id=1519270866
65"...[lesnumeriques.com]...Sony KD-65XF9005 test...https://avclub.gr/forum/showthread....p-2018?p=1058082393&viewfull=1#post1058082393
65"...[avmagazine.it]...Sony KD-65XF9005 review...https://avclub.gr/forum/showthread....p-2018?p=1058160626&viewfull=1#post1058160626
65"...[soundandvision.com]...Sony XBR-65X900F review...https://avclub.gr/forum/showthread....p-2018?p=1058160626&viewfull=1#post1058160626
Sony KD-55XF9005 (XF90) with X1 Extreme in the test: Better than XE90 and XE93?...https://avclub.gr/forum/showthread....p-2018?p=1058072029&viewfull=1#post1058072029
55"...[hdtvpolska.com]...Sony KD-55XF9005 test...https://avclub.gr/forum/showthread....p-2018?p=1058076641&viewfull=1#post1058076641
55"...[tvtest.pl]...Sony KD-55XF9005 - first impressions...https://avclub.gr/forum/showthread....p-2018?p=1058084684&viewfull=1#post1058084684
55XF90, η απόσταση της βάσης με τα πόδια προς τα μέσα να είναι γύρω στα 65cm.
65XF90, η απόσταση της βάσης με τα πόδια προς τα μέσα να είναι γύρω στα 75cm.
55"...[hdtvtest.co.uk]...Sony KD-55XF9005 unboxing & picture settings...https://avclub.gr/forum/showthread....p-2018?p=1058084684&viewfull=1#post1058084684
55"...[rtings.com]...Sony XBR-55X900F review...https://www.rtings.com/tv/reviews/sony/x900f
55"...[hdtvtest.co.uk]...Sony KD-55XF9005 review...https://avclub.gr/forum/showthread....p-2018?p=1058091788&viewfull=1#post1058091788
55"...[homecinemamagazine.nl]...Sony KD-55XF9005 review...https://avclub.gr/forum/showthread....p-2018?p=1058103845&viewfull=1#post1058103845
55"...[avforums.com]...Sony KD-55XF9005 review...https://avclub.gr/forum/showthread....p-2018?p=1058103845&viewfull=1#post1058103845
65"...[avcesar.com]...Sony KD-65XF9005 test...https://avclub.gr/forum/showthread....p-2018?p=1058141261&viewfull=1#post1058141261
55"...[tvtest.pl]...Sony KD-55XF9005 test...https://avclub.gr/forum/showthread....p-2018?p=1058141261&viewfull=1#post1058141261
55"...[referencehometheater.com]...Sony XBR-55X900F review...https://avclub.gr/forum/showthread....p-2018?p=1058160626&viewfull=1#post1058160626
55"...[altadefinizione.hdblog.it]...Sony KD-55XF9005 review...https://altadefinizione.hdblog.it/2018/11/06/sony-xf90-tv-android-dolby-vision-recensione/
μετάφραση google it to en
49"...[audiovision.de]...Sony KD-49XF9005 test...https://avclub.gr/forum/showthread....p-2018?p=1058160626&viewfull=1#post1058160626
In depth comparison review between the Sony XF90 (also marketed as the Bravia X900F in the USA), XE90 (X900E) and XE93 (X930E)...https://avclub.gr/forum/showthread....p-2018?p=1058098901&viewfull=1#post1058098901
Comparison between the Sony X900F (KD-XF90) and the Samsung QN Q8FN (Q8DN Europe models)...https://avclub.gr/forum/showthread....p-2018?p=1058172900&viewfull=1#post1058172900
Calibration settings:
Profile : Cinema Pro
Brightness:
Brightness:15
Contrast:90
Gamma:-1
Black level:50
Automatic local dimming:High
Adv contrast enhancer:Off
X-tended dynamic range:Off
Colors:
Color:50
Color balance:50
Color temperature:Expert 1
Color space:Auto
Color space:Off
Clarity:
Sharpness:50
Reality Creation:Manual
Resolution:20
Mastered in 4K:On
Random noise reduction:Off
Digital noise reduction:Off
Smooth gradation:Off
Motion:
MotionFlow: User : 3/1
Film mode:Off
Video function:
HDR mode:Auto
HDMI video:Auto
Color space:Auto
Note: We only offer calibration settings for SDR, not yet HDR. For our calibration we have not used the ambient light sensor that automatically adjusts the backlight setting according to your environment. Use this if you use your TV during the day, too
source:[flatpanelshd.com]
55"...[rtings.com]...Sony XBR-55X900F calibration settings...https://www.rtings.com/tv/reviews/sony/x900f/settings
Sony KD55XF9005 teardown...:grinning-smiley-043
YD8S007DND01B
LMY550FF04-A ...panel from Samsung Display
source video : [yotube.com - hxos plus]
Sony XBR65X900F disassebly,total teardown,what's inside?, taking apart,innenleben_180 total LEDs
https://www.youtube.com/watch?v=itahzptQWIc
source:[Crutchfield]...:SFGSFGSF::grinning-smiley-043
Sony KD49XF9005 teardown,disassebly
![Sony KD49XF9005 teardown_main av board_1-983-249-21.jpg Sony KD49XF9005 teardown_main av board_1-983-249-21.jpg](https://d1det0hdqz4sg.cloudfront.net/data/attachments/137/137447-5ad13c649d082bbd913af66755dc27c0.jpg)
-(λειτουργία ασύρματου πληκτρολογίου και ποντικιού με USB receiver)...Με alt + tab βλέπεις τις ανοικτές εφαρμογές, όχι win key tab.
-Button Mapper: Remap your keys...https://play.google.com/store/apps/details?id=flar2.homebutton
-We show you how to disable the Samba Interactive TV notification on Sony TVs with Android Nougat 7.0 update, & also how to speed up Android TV by disabling apps & limiting the number of background processes...post #554
X1 Extreme,
49",55",65",75"
![sony-xe90-2.jpg](https://www.giz.ro/wp-content/uploads/2018/02/sony-xe90-2.jpg)
![xf90-spd1.jpg](https://hdtvtest.co.uk/static_data/columns/xf90-spd1.jpg)
HDR:
Peak Brightness
![xf90-pb.jpg](https://hdtvtest.co.uk/static_data/columns/xf90-pb.jpg)
KD-55XF9005 :
-PFS LED
SoC
MediaTek MT5891
CPU Cores: 4
GPU Cores : 2
![Sony_XF90_20-768x429.jpg](https://hdtvpolska.com/wp-content/uploads/2018/02/Sony_XF90_20-768x429.jpg)
![Sony_XF90_23-768x429.jpg](https://hdtvpolska.com/wp-content/uploads/2018/02/Sony_XF90_23-768x429.jpg)
![sony_xf9005_edit_1000.jpg](https://www.avcesar.com/source/plasma/179/sony_xf9005_edit_1000.jpg)
![IMG_20180606_082736_resize.jpg](https://www.matrixlife.gr/ghj/wp-content/uploads/2018/07/IMG_20180606_082736_resize.jpg)
![IMG_20180606_082746_resize-768x576.jpg](https://www.matrixlife.gr/ghj/wp-content/uploads/2018/07/IMG_20180606_082746_resize-768x576.jpg)
![IMG_20180606_091128_resize.jpg](https://www.matrixlife.gr/ghj/wp-content/uploads/2018/07/IMG_20180606_091128_resize.jpg)
Dolby Atmos support
Input Lag reduced
eARC support : yes
new action menu
KD-75XF9005 : 4.649
KD-65XF9005 : 2.599
KD-55XF9005 : 1.849
KD-49XF9005 : 1.549
Reviews - test :
![Sony-55XF9005-w-sklepie-01.jpg](http://www.tvtest.pl/wp-content/uploads/Sony-55XF9005-w-sklepie-01.jpg)
Brightness:
Brightness:15
Contrast:90
Gamma:-1
Black level:50
Colors:
Color:50
Color balance:50
Color space:Auto
Color space:Off
Clarity:
Sharpness:50
Resolution:20
Mastered in 4K:On
Motion:
Film mode:Off
Video function:
HDR mode:Auto
HDMI video:Auto
Color space:Auto
