The Hansen Audio Grand Master
Πρώτη ανακοίνωση:
HANSEN AUDIO
THE GRAND MASTER
A Magical Listening Experience
The Hansen Audio Exclusive Drivers – A Technological Break Through
THE GRAND MASTER is a 10 driver, 3 way, floor standing speaker using Hansen Audio’s proprietary
hand assembled drivers. The four Woofers and the four Mid Band drivers are engineered, designed
and manufactured by Hansen Audio to match perfectly the two High Precision Tweeters. All Hansen
Audio manufactured drivers use exotic Multi-Layer Composite Sandwich cones, resulting in the best
Sound Wave Deformation Prevention in driver technology today. The inert composite sandwich
material has no sonic signature and therefore is completely neutral in sound. The finished driver,
utilizing our amazing powerful motor assembly, has the fastest attack time, the quickest recovery
time and most accurate tracking possible.
The Hansen Audio Enclosure – A New Standard
Having designed and engineered the finest drivers and crossovers available, the task of designing the
perfect enclosure begins. The traditional “panel construction” enclosure had to be abandoned. The
result had to be a free flowing organic design to prevent any diffraction distortion. To accomplish this,
the graceful enclosure incorporates the exclusive Hansen Audio Sound Wave Diffraction Distortion
Elimination technology. The enclosures had to be “Dispersion Coherent”. The finished speaker
had to be “Phase Coherent” both acoustically and electrically. The material had to be harder, stronger
and more durable than conventional wood products. Most important, the material had to be inert,
unlike all conventional wood products. The Hansen Composite Matrix material, with a final layer of
material known as the Cloaking Device, is the result of this long and extensive research. The Hansen
Composite Matrix material meets all of the desired sonic parameters. A New Standard had been set.
The elegant GRAND MASTER is then finished in the beautiful Hansen Audio Class “A” finish.
Specifications
Time Coherent Dispersion Coherent Tonal Accurate True Dynamic
Frequency Response: 15 Hz to 23,000 Hz Sensitivity: 90 db Nominal Impedance: 8 ohms
Finishes: Hansen Audio Silver / Hansen Audio Black Grilles: Driver Protection Grilles Included
Woofers: Hansen 269 mm (X 4) Mid Band: Hansen 182 mm (X 4) Tweeters: 25 mm Dome (X 2)
Crossover: Hansen DAT (Driver Assimilation Technology)
Size: Height - 74 inches; Width – 25 inches; Depth – 31 inches
www.hansenaudio.com
. Distortion level has been reduced to
such a minute level that the typical loudspeaker
“listening fatigue” has now been eliminated.
THE GRAND MASTER leaves the listener experiencing
pure joy. While listening to your favourite well-recorded
musical piece, pure magic happens.
The result is nothing short of a revelation, an
unforgettable musical experience.
Re: Απάντηση: The Hansen Audio Grand Master
βρε ας καταφερουμε να παρουμε την πριγκηπέσσα και θα ειμαστε ..:Banane0:
Φίλε μου σωστό κι αυτό.....στο επίπεδο του Prince V2 -με τα κατάλληλα συνοδά- έχεις πολύ μεγάλο ήχο και μάλιστα ελέω δολλαρίου σε πολύ καλύτερη τιμή από ότι φαντάζεσαι...
Τώρα βέβαια και μετά την γνωριμία με τα The Knight μπορώ να πω ότι το αδελφάκι του (PrinceV2) είναι εντυπωσιακότατο και ίως πολύ πιο κατάλληλο για το μέσο Ελληνικό σπίτι-ηχοσύστημα, για όλα τα ακούσματα, πλήρως ισορροπημένο και απολαυστικό.
Στην έκθεση το οδηγήσαμε μόνο με 22 watts για να ακούσουμε όλοι τις χροιές του νέου Viva solista mk2, στο showroom του δώσαμε κι άλλα ρεύματα και τα δυναμικά του απογειώθηκαν, ενώ η ενέργεια του δίνει αυτό τον live ήχο που ψάχνουμε όλοι.
Πραγματικά μεταμορφώνεται σε ότι του δώσεις από πίσω και μπορείς να επιτύχεις ακριβώς το ηχητικό αποτέλεσμα που θέλεις.
Σημειωτέον ότι η τεχνολογία του Grand master ενσωματώνεται πλήρως σε όλα υπόλοιπα μοντέλα, αφού περιλαμβάνει ίδια ποιότητα μεγαφώνων, ταχύτητες, δυναμικά και χροιές, αλλά σε αντίστοιχους χώρους. (υποκειμενικά τα Elixir, The Knight, Prince V2 & Emperor είναι και πολύ πιο ωραία σε εμφάνιση if looks matters.....έχουν και καμπύλες..)
Η πρώτη επίσημη του Hansen Grand master με τη συνοδεία των dCS & Tenor σε λίγες μέρες στην CES του Λας Βέγκας...-bye-
