USB 2 TERRABYTES !!!
=silent=
2 August 2006
11,357
Homeless
ΑΠΙΣΤΕΥΤΟ!!!:BDGBGDB55:
A Taiwanese research institute has produced a new global memory card standard, called the miCard (Multiple Interface Card), designed to work in smaller consumer gadgets such as digital cameras, mobile phones and any device with a USB plug, which are common on PCs.
The purpose of the card is to make transferring pictures, songs and other data between gadgets and PCs easier. The card won the stamp of approval from the MultiMedia Card Association yesterday and is expected to be available globally starting in the third quarter.
Users will not only benefit from the versatility of the card, but also its speed. The miCard will transfer data at 480Mbit/sec, and throughput will improve over time. The first miCards will be able to store 8GB of data, but the maximum capacity is expected to top out around 2,048GB. The compatibility with both USB and MMC slots means most users won't need separate card readers anymore. MMC cards fit most consumer electronics, while USB connections are built into a wide range of IT hardware, including laptops, desktops, printers and home entertainment gear.
So far, 12 Taiwanese companies have signed on to manufacture the miCard, according to its inventor, the Industrial Technology Research Institute. Officials expect local companies to save $40 million in licensing fees thanks to the card, in addition to profiting from sales. Taiwanese companies will not have to pay royalties to make miCards or related technology.
http://www.computerworld.com/action/article.do?command=viewArticleBasic&articleId=9022598
