Βασικές Αρχές Φωτογραφίας και εμβάθυνση σε τεχνικές λήψεις.
Reactions: leonkoum and cacau
Carmine Bee Eaters | Bird Photography Tips And Tricks​
Pangolin Wildlife Photography
Is Your Photography a Victim of Diffraction? Fight Back with These Tips!​
Visual Education
Improve Your Photography Storytelling: Jonny Roams' 5 Tips​
B&H Photo Video Pro Audio
Chiaroscuro Lighting Technique
What is the difference between Chiaroscuro and Tenebrism?
Many people confuse these two lighting styles as they share similar traits. The main difference between the two is that the subject is clearly in an environment in Chiaroscuro. Tenebrism surrounds the subject with absolute blackness. In both cases, the subject is in a pool of light. Still, in Chiaroscuro, the environment also has either an underexposed overall light or a series of light pools.
What is the most important characteristic of chiaroscuro lighting?
What makes Chiaroscuro powerful is the use of transition and contrast to produce depth and space. Balancing light to create evenly lit photos is thrown out the window in pursuit of emotion and depth. If we removed our knowledge of the subject from a Chiaroscuro image, the image would still be powerful. Even in the abstract, transition and contrast make for a striking image.
What kind of mood does chiaroscuro lighting make?
You can use Chiaroscuro to evoke many emotions, from grief to power. If I were to pick a single mood often related to Chiaroscuro, I would say mystery. The use of transition and pools of light will clearly show our subject. However, it usually takes a few seconds for our eyes and minds to dig into the darker parts of the image. This process draws us in. And since the light has created depth and three-dimensionality, we can fall into the images completely. We are then immersed in the subject’s world, if only for a short time.
Conclusion​
Unlike Rembrandt, split, butterfly, broad, or short lighting, Chiaroscuro is not beholden to a fixed formula. Yes, we need pools of light and transition. However, we can achieve and use these in our work in many ways. When we reach the point where we begin to explore these types of styles as creators, we have reached the “next level.” The level where the emotional content of our work takes precedence over some posing guide or lighting diagram. Create emotion, create scenes, and create worlds with Chiaroscuro lighting.
Reactions: evanfotis
Reactions: toupia
  • Love
Reactions: Highpriest
Κυκλοφόρησε η καινούρια 5η έντυπη έκδοση της "Ελληνικής φωτογραφικής βίβλου" του Τάσου Σχίζα: "Η ΤΕΧΝΙΚΗ ΤΗΣ ΑΝΑΛΟΓΙΚΗΣ ΚΑΙ ΤΗΣ ΨΗΦΙΑΚΗΣ ΦΩΤΟΓΡΑΦΙΑΣ"
Η παρουσίαση:
"Μετά την εξάντληση και της 4ης επιτυχημένης έκδοσης, έρχεται η νέα, στην οποία προστέθηκαν 16 νέες σελίδες, ενημερώθηκε η ύλη που αφορά τα προγράμματα επεξεργασίας με τις πιο πρόσφατες εκδοχές τους, προστέθηκαν φωτογραφίες και έγιναν ανανεώσεις, διορθώσεις και σημαντικές προσθήκες στο σύνολο της ύλης.
«Η τεχνική της αναλογικής και της ψηφιακής φωτογραφίας» αποτελεί ένα σύγχρονο σύγγραμμα, που έχει σκοπό να καλύψει με τη μεγαλύτερη δυνατή πληρότητα τις ανάγκες ενός ερασιτέχνη ή σπουδαστή ή επαγγελματία φωτογράφου. Η φωτογραφία αντιμετωπίζεται μικτά (ψηφιακή και αναλογική μαζί), όπως άλλωστε είναι η σημερινή μορφή της. Στην ύλη περιλαμβάνονται: Οι οριοθετήσεις, για την καλύτερη κατανόηση του περιεχομένου, ο εξοπλισμός που χρειαζόμαστε, η χρήση της φωτογραφικής μηχανής με α-πλό τρόπο, για την εύκολη εισαγωγή του νέου στη φωτογραφία, η λήψη, στην οποία δίνεται ιδιαίτερη βαρύτητα στη φωτομέτρηση, που αποτελεί και τον σημαντικότερο παράγοντά της, οι φωτογραφικές τεχνικές, για όσους αναζητούν περισσότερα εκφραστικά μέσα, ο φωτισμός, που οι περισσότεροι παραμελούν παρά τη σπουδαιότητά του, ο σκοτεινός θάλαμος (ασπρόμαυρος και έγχρωμος), για όσους επιθυμούν να διατηρήσουν τις βάσεις του παρελθόντος και να αποχτήσουν κλασική φωτογραφική ταυτότητα και τέλος η ψηφιακή επεξεργασία, εστιασμένη κυρίως στο Photoshop και δοσμένη στα μέτρα της φωτογραφίας, με τέτοιον τρόπο, που να αφορά παράλληλα τον αρχάριο, αλλά και τον προχωρημένο φωτογράφο."
Ως γνωστόν υπάρχει και η ηλεκτρονική έκδοση η οποία διατίθεται δωρεάν. Και τις δύο μπορείτε να τις βρείτε εδώ.
Reactions: kosmous
