Ο δέκτης είναι mips based, δεν είναι κλώνος dreambox αφού απαιτεί τους δικούς του οδηγούς, αλλά είναι 100% συμβατός με enigma2 λόγω μεγάλης ομοιότητας με το hardware των dreambox 800/8000.
Τον υποστηρίζει ήδη το openpli με καθημερινό experimental snapshot. Από αυτά που διαβάζω έχει ακόμα κάποια bugs αλλά λύνονται το ένα μετά το άλλο.
Η δε τιμή του; Στο http://www.sat-shop.co.uk/Digital-R...R-DVB-S2-Satellite-Receiver/product_info.html τον βρίσκει κανείς με 410 λίρες, ή 475 ευρώ.
Crystal clear HD picture, two card readers and two CI slots. Internal and external HDD is possible via SATA connection. One front and two rear USB ports. Rear Ethernet 10/100 connection. Linux operating system using Enigma2 open source. Standby consumption is only 1 watt. Dutch and English language manual menu. Extended EPG (electronic program guide). This receiver is expected to be a real high-end contender and is already building up a BIG third party support.
Specifications:
* Open-source Linux operating system (Enigma2)
* Broadcom Mips processor
* Twin DVB-S2 Tuner
* MPEG2 / H.264 Hardware decoding (DVB compliant)
* 16 digit alphanumeric VFD Display
* 2 x Common Interface slots
* 2 x smartcard reader (Conax Embedded)
* 10/100 Mbps Ethernet interface
* 3 x USB2.0 (1xFront/2xBack)
* 1 x internal SATA connection for HDD (not included)
* 1 x E-SATA
* 1 x V.24/RS232
* HDMI Interface
* 2 x Scart
* 1 x YPrPb
* 1 x optical S / PDIF for digital audio transmission
* Channel change <1 seconds
* EPG (electronic program guide)
* Plugin support (JPEG, MP3, XviD ...)
* Support of Bouquet lists
* Multi language OSD, Skin - Support
* Fully automatic, Manual Channel Search
* Videotext Teletext
* DiSEqC 1.0, 1.1 and 1.2
Video:
* Video resolution (720 x 576 lines), 576p, 720p, 1080i
* Video decoding MPEG-2, MPEG-4 compatible
* Input data rate 2-45 MSymb / s
* S/N> 53 dB
Audio:
* Decoding AC 3, MPEG-4 (AAC-HE), MPEG-1, Layer 1, 2 and 3
* 32/44.1/48 kHz sampling rate
* S/N > 65 dB
Power consumption:
* <25W (in operation, horizontal /) 400mA LNB current
* <20W (in operation, without LNB)
* <1W (Deep-Standby-Mode)
* 100-240 Volts 50-60 Hz
Specifications:
* Twin DVB-S2 Tuner
* 1 x E-SATA
* 1 x V.24/RS232
* HDMI Interface
* 2 x Scart
* 1 x YPrPb
Video:
* S/N> 53 dB
Audio:
* S/N > 65 dB
Power consumption:
