- 2 November 2007
- 889
At this point, you can expect 2.0 to be locked and jailed. This means you will only be able to use contract carriers such as AT&T. You will not be able to unlock. The upgrade process will likely be a one-way trip for now also. This means if you “accidentally” upgrade, you will not be able to go back (for now).Jailbreak: 2.0 may not be jailbroken anytime soon. But even if it is, you will still stand to lose a lot (read further). For now, let’s assume it is not jailbroken and that means you are stuck with whatever Apple and AppStore provides you.
What else will you lose on 2.0? All the apps must be ported. Not one GUI app will work. Not even Jiggy apps. Nothing, notta. This means you lose 500+ 3rd party apps.
What about installer? Nope, there’s no installer 2.0. (Cydia will be available, but there will not be anything to install yet).
What about AppStore?: AppStore is all about purchasing and paying for software. It’s not called iApps or iInstaller. It’s called AppStore. At this point, the best source of free apps will remain to be 1.1.4 and installer.
I already upgraded. What now? You can downgrade to 1.1.4 and bootneuter using the new baseband with 1.1.4. This should get you back to an unlocked state with the new baseband. Downgrade requires DFU mode, restore to 1.1.4, when you get error 1011, 1013, or 1015, use iLiberty+ to boot phone out of recovery mode. Worst case, if the new baseband cannot work with 1.1.4 you could use ienew or such and get back to the 1.1.4 baseband. This would require some steps such as ieraser (3.9) / ienew (4.6) then use bbupdater to program the 1.1.4 baseband back on. We’ll see where we’re at. I’ll make a guide if needed.
Then what should I do? Wait a bit. A solution will surely come. I will update this site with news as I get it. Check back daily.
What about pwnage? While pwnage should work on 2.0, it appears that the latest 2.0 betas have not been jailbroken. We will need to wait and see what happens
Source: Sleepers.net
