- 17 June 2006
- 10,573
£18k Ferrari Art.Engine speaker system
Description: Bi-amplified, stereo audio system with twin integrated line-source loudspeakers, amplifiers, DSP signal management and digital wireless receiver. Eight custom DWV 75mm (3") carbon fiber high-performance mid/woofers and one ScanSpeak custom 28mm (1.1") soft dome tweeter are used in each of the two channels. At 120 cm (47”) tall and 41 cm (16”) wide, the Art.Engine is a floor standing audio system designed to be placed against the wall. Ideal for home and office use to replace a conventional HiFi system.
Primary signal input is wireless streaming of music files or radio via iTunes (free downloadable software) running on any computer (PC or Mac) with wireless functionality. The Art.Engine may also be used with conventional line level sources such as CD players, tuners, iPods and most other portable devices, via RCA input jacks (accessory cables included).
Frequency Response:
40 Hz – 20 kHz +/- 3 dB
200 Hz – 20 kHz +/- 1 dB
Maximum Sound Pressure:
110 dB @ 1M
Speaker Compliment(each channel):
Low/Mid: 8 X 75mm (3”) wide-range, long stroke carbon fiber (magnetically shielded) Treble: 1 X 28mm (1.1”) soft dome with Neodymium motor (magnetically shielded)
Amplifier:
Four 200 Watt Discrete Digital Amplifier Modules
Amplifier Operating Class:
Enhanced Performance PWM Class D
Signal/Noise Ratio:
> 110 dB
Input Voltage Sensitivity:
1 Volt
Input Impedance:
Analog Input – 10k Ohms
Signal Connections:
Wireless input requires 802.11 WiFi enabled computer. Analog wired connection via side mounted RCA jacks. Input mode selectable via side mounted precision input signal switch. Signal input controlled with rotary volume attenuator.
Input Power Connection:
10 Amp IEC, 3 Pin Grounding. Front Mounted Master Power Switch.
Input Power Requirement:
110 – 240 Volts, 50/60 Hz. Digital Power Supply is Auto Switching.
Status Indicators:
Two Front Panel Mounted LED Master Power Indicators
Side Panel Mounted Multi-Color LED Wireless Status Indicator
Regulatory:
CE Compliant
ENCLOSURE
Materials:
6061 T6 Machined Aluminum
Bonded Carbon Fiber Composite
Painted Part Finish:
Ferrari Inspired Paint & Clear Coat. Available in Rosso Corsa red, Argento Nurburgring silver, Grigio Silverstone grey and Nero black. (Custom Ferrari Colors Upon Request)
Plated Part Finish:
Bright Dip Clear Anodization
Black Anodization
Polished Chrome
22 Karat Gold
Dimensions:
Height: 120.65 cm (47.5")
Width: 40.64 cm (16")
Depth: 16.19 cm (6.375") At Sides: 3.17 cm (1.25”) Deep
Base Plate:
Width: 45.72 cm (18”)
Depth: 33.02 cm (13")
Weight:
48.63 kg (107.2#) Net (Product Only)
INCLUDED ACCESSORIES
Input Cable:
365.76 cm (144”) RCA to RCA cable with Gold Plated Plugs (For CD and other component input devices.)
Input Cable:
137.1 cm (54”) Mini Plug to RCA cable with Gold Plated Plugs (For iPod & other portable input devices.)
Floor Spikes:
Floor Spikes (For installations on carpet.)
Slip Cover:
Techno Fleece Protective Slip Cover
:guitarist:
