- 22 June 2006
- 364
Πωλείται το Matrix του παρακάτω link στο Ebay στα 35 ευρώ.
http://www.ebay.com/itm/New-4x2-108...litter-with-HIFI-Home-Office-US-/391436787456
Περιλαμβάνει remote.
Έχει χρησιμοποιηθεί ελάχιστα και υπάρχει πλήρης συσκευασία.
Χαρακτηριστικά:
-Support HDCP protocol and applicable to source device and high definition display device such as DVD and HDTV which have
HDMI ports or digital ports, and are compliant with HDCP protocol.
-Any one of the signal terminals can be achieved independent audio output through optical fiber or stereo headphones.
-HDMI to achieve the synchronization of audio signal separation. There are ADV/ 2.0CH / 5.1CH three kinds of audio mode options.
-Support high resolutions up to 4Kx2K@24/30, including 480i/480p, 720i/720p, 1080i/1080p @50/60, etc.
-Support HDMI 1.4
-Support Full HD 1080P, Full 3D
-Support 4K*2K resolution
-Support deep color 24bit, 30bit, 36bit, 48bit
-Support Blue-Ray 24/50/60fs/HD-DVD/xvYCC
-Digital audio format, as DTS-HD/Dolby-trueHD/LPCM7.1/DTS/Dolby-AC3/DSD/HD(HBR)
-Adopted AWG24 HDMI standard cable, which transmission distance is up to 15 meters and the output transmission distance is up to 25 meters.
-The Input signal can be switched by infrared remote control, or can be switched directly by pressing buttons.
-Extend the transmission distance and improve transmission signal.
-Plug-and-play.
-Save space.
-LED indicates signal and power mode.
Χαρακτηριστικά:
-Support HDMI 1.4
-Plug-and-play.
-Save space.
