Αγορά νέου ενισχυτή
vale2000
26 May 2009
88
Παλλήνη
Καλησπέρα
Έχετε να μου κάνετε κάποια πρόταση για την αγορά νέου ενισχυτή Home Cinema μέχρι 1000 Euro max.
Αυτή τη στιγμή έχω έναν Yamaha RXV 440 και τα ηχεία μου είναι τα Elac Cinema I ESP.
Αυτό που με ενδιαφέρει είναι να έχει τουλάχιστον 3 και πάνω HDMI εισόδους.
Έχω δει τον Pioneer VSX-LX51 (933 Euro).Υπάρχει κάποια καλύτερη πρόταση που να συμβαδίζει και με τα ηχεία μου;
Ευχαριστώ πολύ
The TX-SR806 occupies a unique position in the Onkyo line-up.We class it as a mid-range A/V receiver. But with its advanced capabilities and THX Ultra2 Plus certification, it’s a worthy challenger for high-end status. Built with high-definition entertainment in mind, the TX-SR806 accommodates up to five HDMI™ sources that can handle both 1080p video and studio master-quality surround sound.That’s more high-def sources than you’ll find on any other Onkyo A/V receiver. If that weren’t enough, onboard Faroudja DCDi Cinema™ scales all standard definition sources to 1080p for HDMI output, or to 1080i for component video output. Endowed with the amplification power and dependability expected from an Onkyo A/V receiver, the TX-SR806 stands out as a natural choice for highperformance home theatre.
ADVANCED FEATURES
  • THX Ultra2 Plus Certified with THX Loudness Plus
  • DTS-HD Master Audio, DTS-HD High Resolution Audio, Dolby TrueHD, Dolby Digital Plus Decoding
  • HDMI to Support Deep Color, x.v. Color, LipSync, Dolby TrueHD, DTS-HD Master Audio, DVD-Audio, Super Audio CD
  • HDMI Audio and Video Processing (1080p; 5 Inputs and 1 Output)
  • HDMI Video Upscaling to 1080p with Faroudja DCDi Cinema
  • Component Video Upscaling to 1080i with Faroudja DCDi Cinema
  • RIHD (Remote Interactive over HDMI) for System Control
  • HDMI Switching
  • Component Video Switching (2 Inputs and 1 Output)
  • Push-Pull Amplification Design with Three-Stage Inverted Darlington Circuitry
  • 192 kHz/24-Bit Cirrus Logic DACs for All Channels
  • Two TI 32-Bit DSP Chips for Advanced Processing
  • Audyssey MultEQ to Correct Room Acoustic Problems and to Calibrate Speakers
  • Audyssey Dynamic EQ for Loudness Correction
  • Bi-Amping Capability for Music and Movie Surround Effects
AUDIO FEATURES
  • 180 W/Ch Minimum into 6 Ω, 1 kHz, IEC (1 Channel Driven)
  • DTS®-ES™ Discrete/Matrix, DTS® Neo:6, DTS® 96/24, Dolby® Digital EX®, Dolby® Pro Logic® IIx Decoding
  • H.C.P.S. (High Current Power Supply) Massive High Power Transformer
  • WRAT (Wide Range Amplifier Technology)
  • 6 Digital Inputs (3 Optical [1 Front]/3 Coaxial)
  • Subwoofer Pre Out
  • Direct Mode
  • A-Form Listening Mode Memory
  • Optimum Gain Volume Circuitry
  • Music Optimizer for Compressed Music Files
  • Non-Scaling Configuration
  • Tone Control (Bass/Treble) for Front L/R Channels
  • Double Bass Function
  • Color-Coded 7.1-Multichannel Inputs and Pre Outs
  • Independent Crossover Adjustment for F/C/S/SB (40/50/60/70/80/90/100/120/150/200 Hz)
OTHER FEATURES
  • Powered Zone 2 and Zone 2 Pre-Out for Playback in Another Room (Separate Source)
  • Banana Plug-Compatible Speaker Posts
  • A/V Synchronization Function (Up to 250 ms in 5 ms Steps)
  • 40 FM/AM Radio Presets
  • RDS (PS/RT/PTY/PT)
  • IntelliVolume
  • 5 S-Video Inputs and 2 Outputs
  • 5 A/V Inputs and 1 Output
  • 2 Audio Inputs and 1 Output
  • Phono Input
  • RS232, IR and 12V Trigger Connectivity
  • Display Dimmer (Normal/Dim/Dimmer)
  • Headphone Jack
  • Aluminum Front Panel
  • Newly Designed GUI for System Set-up
  • Compatible with RI (Remote Interactive) Dock for the iPod
  • Newly Designed Preprogrammed RI (Remote Interactive) Remote Control with Mode-Key LEDs
ADVANCED FEATURES
  • HDMI Switching
AUDIO FEATURES
  • Subwoofer Pre Out
  • Direct Mode
OTHER FEATURES
  • IntelliVolume
  • Phono Input
  • Headphone Jack
Φαίνεται πολυ δυνατός.....θα τον τσεκάρω εκτενώς...ευχαριστώ πολύ
Για τον Pioneer λέτε όχι δηλαδή ε;
Ο 876 ειναι φοβερος (αυτον εχω) απλα στο συγκεκριμενο καταστημα εχει 1100 συν μεταφορικα αν δεν κανω λαθος.
Το συγκεκριμενο καταστημα εχει το πλεονεκτημα οτι παραδιδει με αντικαταβολη οποτε τσεκαρεις τι σου ερχεται και σε τι κατασταση.
Οσο για τον Pioneer ειναι δυνατο ονομα στο χωρο αλλα νομιζω οτι οι Οnkyo εχουν εξελιχθει σε best buy.
Συμφωνω με τον Jack (Nickolson !!) Ειναι best buy για τα λεφτα του !-bye-
[*]180 W/Ch Minimum into 6 Ω, 1 kHz, IEC (1 Channel Driven)
/QUOTE]
Ο τροπος μετρησης ειναι που τον κανει να φαινεται πολυ δυνατος.
Aν η μετρηση ηταν στα 8Ω ,20HZ-20KHZ και all channels driven ,νομιζω πως δεν θα δειχνε πανω απο 70w στο καναλι.
Αυτο δεν σημαινει οτι ειναι κακος ενισχυτης.
