Αγόρασα το X96 Air Smart Android 9.0 TV Box. Τι γνώμη έχετε?
  • Φωτογραφική συνάντηση στην Αθήνα!
    Αυτό το Σάββατο, στις δέκα το πρωϊ (10:00) στο Πάρκο Τρίτση. Λεπτομέρειες και συμμετοχές εδώ.
Newest X96 Air Amlogic S905X3 mini Smart Android 9.0 TV BOX 4GB 64GB 32GB wifi 4K 8K 24fps Netflix X96Air 2GB 16GB Plex Set Top Box
Features:
- CPU: Amlogic S905X3 64-bit quad core ARM® Cortex™ A55
- GPU: G31™ MP2
- Android 9.0 OS
- RAM/ROM: 2GB/16GB, 4GB/32GB, 4GB/64GB
- Support HD: 8K@ 24fps, 4K @60fps, UHD, HDR+, Airplay, Miracast
- Support HD 2.1, USB3.0, USB2.0
- Support 2.4GHz Wifi/2.4G+5.8GHz Dual Wifi, BT4.1
- Support Firmware Online Upgrade
- There are 3 Options for X96Air:
A: 2GB+16GB+2.4G Wifi+100M(No Bluetooth)
B: 4GB+32GB+2.4G&5GHz Dual Wifi+BT4.1+100M
C: 4GB+64GB+2.4G&5GHz Dual Wifi+BT4.1+100M
Package Include:
--1 x X96 AIR TV Box
--1 x Remote control
--1 x Power Supply
--1 x HD Cable
--1 x User Manual
​FAQ
1,is this support netflex?
Yes
2,What internet speed need for android tv box?
Better 10mbs for smooth steaming 4K video
3,Will it work with a computer mouse (with a wire or wireless)?
Yes
4,Does it support harddisk HDD(NTFS)
Yes
5,Does the menu support Russian language?
Yes,it supports Russian/English/French/German/Spanish/Italian/ etc multilateral languages
6,Does it support to connect to old tv with 3 ports (red-white-yellow) AV cable
Yes,but AV cable is not included
7,Does it have bluetooth?
Yes,bluetooth 4.0 built in
8,Have Google play store built in...?
Yes
9,Can install on it an IPTV App?
Yes you can install any IPTV app.
10,Does it have wholesale price
Yes,if you buy 10pcs,20pcs,50pcs,we have wholesale price for you,just contact us
1520191010_160351_00120191010_160351_00220191010_160351_00320191010_160351_00420191010_160351_00520191010_160351_00620191010_160351_00720191010_160351_00820191010_160351_00920191010_160351_010
Software:
Operating system: Android 9.0
Video:
AMLOGIC video engine (AVE) with dedicated hardware decoder and encoder
Multi video decoder supporting up to 4x1080p 60fps
Supports multiple "secure" video decoding sessions, decoding and encoding at the same time
Video / picture decoding:
VP9 profile-2 up to 8kx4k 24 fps
H.265 hevc mp-10 l5.1 Max 8kx4k 24 fps
Avs2-p2 profile up to 8kx4k 24 fps
H.264 AVC HP l5.1 up to 4kx2k 30fps
MPEG-4 ASP L5 up to 1080p 60fps (iso-14496)
Wmv / VC-1 SP / MP / AP up to 1080p 60fps
Avs-p16 (AVS +) / AVS-P2 jizhun profile up to 1080p 60fps
MPEG-2 MP / HL up to 1080p 60fps (iso-13818)
MPEG-1 MP / HL up to 1080p 60fps (iso-11172)
Realvideo 8 / 9 / 10 up to 1080p 60fps
Subtitle video support in multiple languages and formats
MJPEG and JPEG infinite pixel resolution decoding (ISO / iec-10918)
Supports JPEG thumbnail, zoom, rotate and transition effects
Support *. MKV, *. Wmv, *. Mpg, *. MPEG, *. DAT, *. Avi, *. MOV, *. ISO, *. MP4, *. RM and *. JPG file formats "
Audio:
Supports MP3, AAC, wma, RM, FLAC, Ogg and can be programmed through 7.1 / 5.1 downward mixing
Low power VAD
Built in serial digital audio SPDIF / iec958 I / O and PCM
I / O:
3 internal TDM / PCM / I2S ports, up to 384khz x 32bits x 16CH or 96KHz x 32bits x 32ch TDM / PCM mode and up to 384khz x 32bits x 16CH I2S mode
PDM input of digital microphone with programmable CIC, LPF and HPF, supporting up to 8 DMIC
Built in stereo audio DAC
Simultaneous dual audio stereo channel output supported by combination of analog + PCM or I2S + PCM
Image: HD JPEG, BMP, GIF, PNG, TIF
Language: English, French, German, Spanish, Italian and many other languages
Scope of application:
Online: browse all video websites, support Netflix, Hulu, Flixster, youtube, etc.
Application: the application can be downloaded free of charge from Android Market, Amazon store, etc.
Medium: local media play, support hard disk, USB flash disk, tfcard.
Online conversation: support Skype video call, MSN, Facebook, twitter, QQ, etc.
Others: support email, office clothes, etc. DLNA support
Support 2.4G wireless mouse / keyboard
Μετά από σχεδόν ένα μήνα που το έχεις ίσως εσύ θα έπρεπε να μας πεις την γνώμη σου τι προβλήματα ίσως αντιμετώπισες, πως είναι η αναπαραγωγή αρχείων βίντεο μέσω Κόντι, πως τα πηγαίνει στα παιχνίδια,
αν έχει πρόβλημα υπερθέρμανσης.
Το να σου πω εγώ τι γνώμη έχω που δεν το έχωείναι άστοχο ενώ εσύ που το έχεις μπορείς να βοηθήσεις όλους μας λέγοντας τα υπέρ και τα κατά.
