Amp modules
Browser
10,573
HFX® classic class.d module 2-250W
[FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]Features: [/FONT][/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]>> 2 channels analog input with stereo phono jack[/FONT][/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]>> 2 channels output with 125W each[/FONT][/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]>> bridges mode with 1x500W[/FONT][/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]>> includes ICEpower modules from B&O[/FONT][/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]>> cooled fanless with heatpipes inside[/FONT][/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]>> includes remote on/off module[/FONT][/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif] [FONT=Verdana, Arial, Helvetica, sans-serif]Specification: [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]>> 450W @ 1% THD+N, 20Hz-20kHz, 4Ohm, BTL[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]>> 2x120W @ 1% THD+N, 20Hz-20kHz, 4Ohm, SE[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]>> 121 dBA (BTL), 117 dBA (SE) dynamic range[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]>> THD+N=0.002% @ 1W (8 Ohm, 1kHz)[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]>> total efficiency @ 250W, 8Ohm is 86,4%[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]>> thermal and overcurrent protection[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]>> sound optimized soft clipping[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]>> dimensions: 4(w)x18(d)x10(h)cm double height slot card[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]>> net weight: 0.6kg
http://www.mcubed-store.com/catalog/product_info.php?cPath=21_38_47&products_id=254
:ernaehrung004:
[/FONT]
[/FONT]
[/FONT]
Καλο αλλα και παρα πολυ ακριβο.
Μονο για οσους εχουν σοβαρο προβλημα χωρου.
Διαφορετικα αγοραζεις ενυσχηταρες με 245.(δικαναλους)
