Ο DENON 2313 του οποίου είμαι κάτοχος τον έχω δοκιμάσει με απλά στικάκια μόνο των 4 Γίγα και παίζει απροβλημάτιστα τουλάχιστον μουσική και μάλιστα με όλες τις πληροφορίες, εξώφυλλα κ.λ.π. Στο εγχειρίδιο γράφει τα παρακάτω:
• Only USB memory devices conforming to mass storage class and MTP (Media Transfer Protocol)
standards can be played on this unit.
• This unit is compatible with USB memory devices in “FAT16” or “FAT32” format.
• This unit is compatible with MP3 files conforming to “MPEG-1 Audio Layer-3” standards.
• File types that this unit can play back and specifications are shown below.
GSupported file typesH
Supported file types USB memory devices z1
WMA (Windows Media Audio) Pz2
MP3 (MPEG-1 Audio Layer-3) P
WAV P
MPEG-4 AAC Pz3
FLAC (Free Lossless Audio Codec) P
JPEG P
z1 USB memory device
• This unit is compatible with MP3 ID3-Tag (Ver. 2) standard.
• This unit can show the artwork that was embedded by using MP3 ID3-Tag Ver. 2.3 or 2.4.
• This unit is compatible with WMA META tags.
• If the image size (pixels) of an album artwork exceeds 500 × 500 (WMA/MP3/WAV/FLAC) or 349 ×
349 (MPEG-4 AAC), then music may not be played back properly.
• WAV format Quantization bit length: 16 bits.
• FLAC format Quantization bit length: 16 or 24 bits.
z2 Copyright-protected files can be played on certain portable players compatible with MTP.
z3 Only files that are not protected by copyright can be played on this unit.
Content downloaded from pay sites on the Internet are copyright protected. Also, files encoded in
WMA format when ripped from a CD, etc. on a computer may be copyright protected, depending on
the computer’s settings.
NOTE
File types that this unit does not support are not displayed.
GCompatible formatsH
Sampling frequency Bit rate Extension
WMA (Windows Media Audio) 32/44.1/48 kHz 48 – 192 kbps .wma
MP3 (MPEG-1 Audio Layer-3) 32/44.1/48 kHz 32 – 320 kbps .mp3
WAV 32/44.1/48 kHz – .wav
MPEG-4 AAC 32/44.1/48 kHz 16 – 320 kbps
.aac/
.m4a/
.mp4
FLAC (Free Lossless Audio Codec) 32/44.1/48/88.2/96 kHz – .flac
nnMaximum Number of Playable Files and Folder
The limits on the number of folders and files that can be displayed by this unit are as follows.
Media
Item USB memory devices
Memory capacity FAT16 : 2 GB, FAT32 : 2 TB
Number of folder directory levels z1 8 levels
Number of folders 500
Number of files z2 5000
z1 The limited number includes the root folder.
z2 The allowable number of files may differ according to the USB memory device capacity and the file
