antalagi klipsch-rf35 me bose acoustimas 10
CROSSOVER FREQUENCY: 2600Hz
DIMENSIONS: 40.9" (103.9cm) x 9.25" (23.5cm) x 14.8" (37.6cm)
ENCLOSURE MATERIAL: MDF
ENCLOSURE TYPE: Bass reflex via rear-firing port
FINISHES: Black Ash, Light Cherry wood-grain vinyl
FREQUENCY RESPONSE: 37Hz-20kHz (+-)3dB
HIGH FREQUENCY HORN: 6" square 90x60 Tractrix Horn
INPUT CONNECTIONS: 2 sets of binding post speaker terminals (connected via brass strap jumpers)
NOMINAL IMPEDANCE: 8 ohms compatible
POWER HANDLING: 125 w max continuous (500 w peak)
SENSITIVITY: 98dB @ 2.83 volts/1 meter
TWEETER: K-137 1" (2.54cm) Titanium dome compression driver
WEIGHT: 54 lbs. (24.5kg)
WOOFER: Two K-1122-OB 8" (20.32cm) Cerametallic cone / cast polymer frame
